POV-Ray : Newsgroups : povray.binaries.images : Some macros I wrote ... Server Time
31 Mar 2026 09:54:57 EDT (-0400)
  Some macros I wrote ... (Message 1 to 9 of 9)
Subject: Some macros I wrote ...
Date: 29 Jan 2000 11:59:43
Message: <38931c7f@news.povray.org>
Some images created to illustrate these macros. They are available at
  http://www.primenet.com/~vanukoff/3d/povray/
AngOfDist -> returns the angle of a distance on a circumference, specify
radius, and distance, returns the angle. The angle is calculated to evenly
divide into 360, so you can create rings of evenly spaced objects with no
uneven gaps.
RGBfromHue -> returns an RGB vector specifying a color of the hue you have
passed it. Hue is specified from 0 - 1, where 0 is red, 1/6 is yellow, 1/3
is green, 1/2 is cyan, 2/3 is blue, 5/6 is magenta, and 1 is red again. An
invalid hue value will return gray.
Comments welcome.
Paul Vanukoff
van### [at] primenetcom
Download 'Sinesque.jpg' (71 KB) Download 'ColoredRings.jpg' (52 KB)
Preview of image 'Sinesque.jpg'
Preview of image 'ColoredRings.jpg'
Subject: Re: Some macros I wrote ...
Date: 29 Jan 2000 13:28:29
Message: <38933080.6E7A937F@pacbell.net>
The image is pretty impressive. Will you be offering these at this address
for a while so that I can link to them from the POV-Ray links page ?
Date: 29 Jan 2000 15:19:11
Message: <38934b3f@news.povray.org>
Yeah I'll keep 'em there .. If I ever move them, I'll let you know. Thanks!
Paul Vanukoff
Date: 29 Jan 2000 15:23:55
Message: <38934C33.A6111809@faricy.net>
> uneven gaps.
Not sure what this means... could you post a little graphical example?
Ooh! Why don't you make a RGB<->CMYK converter? (j/k)
Date: 29 Jan 2000 17:07:17
Message: <38936495@news.povray.org>
David Fontaine wrote in message <38934C33.A6111809@faricy.net>...
evenly
>> uneven gaps.
The 2nd image I posted above (ColoredRings) is the example. Each ring is
composed of spheres 0.5 units apart on the circumference. The macro simply
calculates the angle between one sphere and the next for a given ring. The
angle given is rounded to the nearest value that will divide into 360, so
objects can be placed evenly around the circumference, with no uneven gaps.
I don't know how else to explain it, you can look at the source code in the
same www folder the macros are in, if you'd like. :)
Paul Vanukoff
Date: 29 Jan 2000 23:12:59
Message: <3893BA20.F1094000@faricy.net>
Oh! I get it. I was confised; the second picture shows both macros in use, what
is the point of the first one then?
Date: 30 Jan 2000 06:57:05
Message: <38942711@news.povray.org>
Paul
This looks really great.  Regretablly I am unable to access
your web site at the present time.
This should not be a problem for me in the future.
Nonetheless I might suggest that you post these
most excellent looking macros to povray.binaries.scene-files.
It couldn't hurt.
I look forward to exploring them.
Peter Warren
war### [at] hotmailcom
Date: 30 Jan 2000 10:42:38
Message: <38945bee@news.povray.org>
David Fontaine wrote in message <3893BA20.F1094000@faricy.net>...
what
Well, the first one is probably kind of pointless ... it uses the rgb macro
only ... I thought it looked neat though, so I posted it .. probably
slightly confusing ... sorry .. :)
Paul Vanukoff
Date: 30 Jan 2000 10:43:10
Message: <38945c0e@news.povray.org>
Peter Warren wrote in message <38942711@news.povray.org>...
>Paul
>It couldn't hurt.
I can do that ...
Paul Vanukoff
