POV-Ray : Newsgroups : povray.binaries.images : A Lamp and a Question <21k jpg> Server Time
29 Apr 2026 12:38:23 EDT (-0400)
  A Lamp and a Question <21k jpg> (Message 1 to 10 of 16)
Subject: A Lamp and a Question <21k jpg>
Date: 24 Jan 2000 12:07:25
Message: <388c86cd@news.povray.org>
Hey all,
I'm working on a lamp that I saw in a waiting room the other day.  The
problem is the lamp shade.  It should be opaque in that you can't see thru
it but transparent in that it lets light out.  Is such a thing possible?  Is
this a job for media???  I'm clueless.
Eric
"A wise and frugal government, which shall restrain men from injuring one
another, which shall leave them otherwise free to regulate their own
pursuits of industry and improvement, and shall not take from the mouth of
labor the bread it has earned.  This is the sum of good government."
     - Thomas Jefferson
     - First inaugural address, 1801
http://www.ametro.net/~ericfree
Download 'lamp.jpg' (21 KB)
Preview of image 'lamp.jpg'
Subject: Re: A Lamp and a Question <21k jpg>
Date: 24 Jan 2000 12:55:55
Message: <388c922b@news.povray.org>
You are reffering to translucency. This can only be achieved by using
blurred transparency available in... what a second... it isn't available...
oh, Chriiiis...!
Date: 24 Jan 2000 13:04:34
Message: <DJSMOCL2npCXLk7LH8e010QZbD7T@4ax.com>
On Mon, 24 Jan 2000 12:56:26 -0500, "TonyB"
>oh, Chriiiis...!
Try double_illuminate and radiosity in MegaPOV.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 24 Jan 2000 14:19:57
Message: <388CA328.1370AA9D@aol.com>
no_shadow
Hurts, don't it?
-Mike
Date: 24 Jan 2000 15:07:08
Message: <slrn88pc70.v8.ron.parker@ron.gwmicro.com>
On Mon, 24 Jan 2000 11:06:57 -0600, Eric Freeman wrote:
>Hey all,
As well as the other solutions others have offered, media might do the trick
if used (im)properly.  Render this and see if it approximates the effect you're
looking for.  In this case, it's not so much that the shade isn't translucent
as it is that the scattered light overwhelms anything you might see through
the shade.  Real lampshades are like this, too, I think.
difference {
  cone {0,1,y,.75}
  cone {-.01*y,.95,1.01*y, .70}
  hollow
  texture {pigment {color rgbf <1,.9,.7,1>}}
  interior {
    media {
      scattering {2,rgb <20,18,14>}
      absorption 1
      samples 10,20
torus { 1,.02 pigment {color rgb 0}}
torus { .75,.02 pigment {color rgb 0} translate y}
light_source { .5*y rgb 2*<1,.9,.6> }
plane {y,-1 pigment {color rgb 1}}
plane {-z,-1.01 pigment {color rgb 1}}
cylinder {-y,.2*y,.1 pigment {color red 1}}
camera { location .5*y-10*z look_at 0 }
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 24 Jan 2000 16:40:14
Message: <388CC731.212C30C@peak.edu.ee>
Yes, scattering media can do the job.
See also my post 'Translucency demonstration (97 K)' from 12.04.99
It's more realistic, but significantly slower than double_illuminate.
Margus
Date: 24 Jan 2000 17:01:06
Message: <chrishuff_99-28CC24.17014324012000@news.povray.org>
In article <388c922b@news.povray.org>, "TonyB"
> available...
> oh, Chriiiis...!
Ok, ok. I will fix up a version using a more standard syntax than my
current patch and post the changed files...when I get the time. :-)
I will put this on my to-do list. I may not have time until the
weekends, though.
I have released a patch which implements it, but it is an older syntax
which I have thought of improvements for.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 24 Jan 2000 17:54:11
Message: <388CD56E.6051AF8A@faricy.net>
If you have something right up behind the shade you can see the outline. I think
that the light coming through is scattered so much that you can't tell where it's
coming from.
Date: 24 Jan 2000 20:10:52
Message: <388CFA43.D8586A75@aol.com>
It seems a lot like blurred reflection; is it just as slow?
> weekends, though.
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Samuel Benge
E-Mail: STB### [at] aolcom
Visit the still unfinished isosurface tutorial:
http://members.aol.com/stbenge
Date: 24 Jan 2000 20:43:54
Message: <chrishuff_99-651F7D.20443024012000@news.povray.org>
In article <388CFA43.D8586A75@aol.com>, "SamuelT." <STB### [at] aolcom>
Yes. I actually just copied over some of the blurred reflection code
into Refract() and made some very slight modifications, I didn't
actually write much.
I have gotten started on a new transparence patch, the syntax might
eventually be like this:
finish {
    transparence {
        transparence_blur AMOUNT
        blur_samples SAMPLES
        filter_pigment {PIGMENT}
        transmit_pigment {PIGMENT}
I will release the code when I have the blur done, I will then make an
attempt at the filter_pigment and transmit_pigment. Those last two will
simply allow you to specify a color for the filter or transmit by using
a pigment. It might take a while, though, I have to re-learn much of the
lighting code, and account for dispersion, photons, etc.(it is based on
MegaPOV 0.3, and there are a lot of changes from the official version)
Chris Huff
