POV-Ray : Newsgroups : povray.binaries.images : A Lamp and a Question <21k jpg> Server Time
16 Jun 2026 05:08:27 EDT (-0400)
  A Lamp and a Question <21k jpg> (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: A Lamp and a Question <21k jpg>
Date: 24 Jan 2000 17:01:06
Message: <chrishuff_99-28CC24.17014324012000@news.povray.org>
In article <388c922b@news.povray.org>, "TonyB"
<ben### [at] panamaphoenixnet> wrote:
> You are reffering to translucency. This can only be achieved by using
> blurred transparency available in... what a second... it isn't
> available...
> oh, Chriiiis...!
Ok, ok. I will fix up a version using a more standard syntax than my
current patch and post the changed files...when I get the time. :-)
I will put this on my to-do list. I may not have time until the
weekends, though.
I have released a patch which implements it, but it is an older syntax
which I have thought of improvements for.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 24 Jan 2000 17:54:11
Message: <388CD56E.6051AF8A@faricy.net>
> In this case, it's not so much that the shade isn't translucent
> as it is that the scattered light overwhelms anything you might see through
> the shade.  Real lampshades are like this, too, I think.
If you have something right up behind the shade you can see the outline. I think
that the light coming through is scattered so much that you can't tell where it's
coming from.
Date: 24 Jan 2000 20:10:52
Message: <388CFA43.D8586A75@aol.com>
It seems a lot like blurred reflection; is it just as slow?
> weekends, though.
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Samuel Benge
E-Mail: STB### [at] aolcom
Visit the still unfinished isosurface tutorial:
http://members.aol.com/stbenge
Date: 24 Jan 2000 20:43:54
Message: <chrishuff_99-651F7D.20443024012000@news.povray.org>
In article <388CFA43.D8586A75@aol.com>, "SamuelT." <STB### [at] aolcom>
Yes. I actually just copied over some of the blurred reflection code
into Refract() and made some very slight modifications, I didn't
actually write much.
I have gotten started on a new transparence patch, the syntax might
eventually be like this:
finish {
    transparence {
        transparence_blur AMOUNT
        blur_samples SAMPLES
        filter_pigment {PIGMENT}
        transmit_pigment {PIGMENT}
I will release the code when I have the blur done, I will then make an
attempt at the filter_pigment and transmit_pigment. Those last two will
simply allow you to specify a color for the filter or transmit by using
a pigment. It might take a while, though, I have to re-learn much of the
lighting code, and account for dispersion, photons, etc.(it is based on
MegaPOV 0.3, and there are a lot of changes from the official version)
Chris Huff
Date: 24 Jan 2000 22:02:41
Message: <388d1251@news.povray.org>
>finish {
>    transparence {
This just got me thinking (actually the idea has been floating around in my
head for a while), the way reflection has been growing, wouldn't it be nice
if instead of
finish
 reflection_type
 reflection_min
 reflection_max
 reflect_metallic
 etc.
we could have
finish
 reflection
 val / min, max
 type
 metallic
 etc.
wouldn't it be shorter and less bothersome than reflection_x? I think that
the number of reflection parameters have gotten to a point where this would
be a good idea.
Date: 25 Jan 2000 03:35:12
Message: <388D6040.2AD50275@ica.uni-stuttgart.de>
Eric Freeman wrote:
> Hey all,
> I'm working on a lamp that I saw in a waiting room the other day.  The
> problem is the lamp shade.  It should be opaque in that you can't see thru
> it but transparent in that it lets light out.  Is such a thing possible?  Is
> this a job for media???  I'm clueless.
> Eric
I would use those patches in povray that are translucent, like the
bicubic patch.
Here's a example code. Have a look at the texture statement. It's only
rgb ... not rgbt.
camera {location <0,5,0>
        look_at  0}
light_source {y*0.5 rgb 4}
bicubic_patch{
  type 0
  flatness 0.001
  u_steps 4
  v_steps 4
  <0,0,0>,<1,1,0>,<2,1,0>,<3,0,0>,
  <0,1,1>,<1,1,1>,<2,1,1>,<3,1,1>,
  <0,1,2>,<1,1,2>,<2,1,2>,<3,1,2>,
  <0,0,3>,<1,1,3>,<2,1,3>,<3,0,3>
  texture{pigment{rgb<1.0,1.0,0.8>}
          finish {ambient 0
                  diffuse 0.4
                  reflection 0}
  translate <-1.5,0,-1.5>
Hope this one helps.
Marc Schimmler
Download 'bezier.jpg' (6 KB)
Preview of image 'bezier.jpg'
Date: 25 Jan 2000 06:36:30
Message: <chrishuff_99-881196.06370625012000@news.povray.org>
In article <388d1251@news.povray.org>, "TonyB"
> my
> nice if instead of
> finish
>  reflection_type
>  reflection_min
>  reflection_max
>  reflect_metallic
>  etc.
> we could have
> finish
>  reflection
>  val / min, max
>  type
>  metallic
>  etc.
> that
> would be a good idea.
I have done something similar to this in my reflectivity patch, which
mostly just gave a new syntax to blurred/angle-dependant reflections.
The syntax for this patch is pretty strange,though. Several things are
controlled by patterns instead of float values.
But it wouldn't be difficult at all to simply add an alternate syntax. I
don't really care for the current one...
Chris Huff
Date: 25 Jan 2000 12:28:46
Message: <388DDD2D.56646D56@spiritone.com>
You could try adding no_shadow to the shade, then give the shade some amient
value to make it look like it's glowing from the inside, but that won't make a
defined shadow against the wall, so make a slightly smaller version that is grey
with high transmit value (but not 1) to create the shadow effect.
Just a guess at a workaround
Eric Freeman wrote:
> Hey all,
> Eric
> "A wise and frugal government, which shall restrain men from injuring one
> another, which shall leave them otherwise free to regulate their own
> pursuits of industry and improvement, and shall not take from the mouth of
> labor the bread it has earned.  This is the sum of good government."
>      - Thomas Jefferson
>      - First inaugural address, 1801
> http://www.ametro.net/~ericfree
Josh English
eng### [at] spiritonecom
Date: 25 Jan 2000 17:42:07
Message: <388E23FA.CAD64C4D@faricy.net>
Maybe keep the shadow but give it a texture with high ambience and use a gradient y
to make it brighter (more ambient) where it's closer to the bulb.
Date: 26 Jan 2000 01:20:04
Message: <388e9214@news.povray.org>
I sure appreciate everybody's input.  I'm going to try all of your
suggestions and see which one (or maybe something else) works.
Eric
     - Thomas Jefferson
