POV-Ray : Newsgroups : povray.binaries.images : A Lamp and a Question <21k jpg> Server Time
16 Jun 2026 05:08:27 EDT (-0400)
  A Lamp and a Question <21k jpg> (Message 11 to 16 of 16)
Subject: Re: A Lamp and a Question <21k jpg>
Date: 24 Jan 2000 22:02:41
Message: <388d1251@news.povray.org>
>I have gotten started on a new transparence patch, the syntax might
>eventually be like this:
>finish {
>    transparence {
>        transparence_blur AMOUNT
>        blur_samples SAMPLES
>        filter_pigment {PIGMENT}
>        transmit_pigment {PIGMENT}
This just got me thinking (actually the idea has been floating around in my
head for a while), the way reflection has been growing, wouldn't it be nice
if instead of
finish
 reflection_type
 reflection_min
 reflection_max
 reflect_metallic
 etc.
we could have
finish
 reflection
 val / min, max
 type
 metallic
 etc.
wouldn't it be shorter and less bothersome than reflection_x? I think that
the number of reflection parameters have gotten to a point where this would
be a good idea.
Date: 25 Jan 2000 03:35:12
Message: <388D6040.2AD50275@ica.uni-stuttgart.de>
Eric Freeman wrote:
> Hey all,
> I'm working on a lamp that I saw in a waiting room the other day.  The
> problem is the lamp shade.  It should be opaque in that you can't see thru
> it but transparent in that it lets light out.  Is such a thing possible?  Is
> this a job for media???  I'm clueless.
> Eric
I would use those patches in povray that are translucent, like the
bicubic patch.
Here's a example code. Have a look at the texture statement. It's only
rgb ... not rgbt.
camera {location <0,5,0>
        look_at  0}
light_source {y*0.5 rgb 4}
bicubic_patch{
  type 0
  flatness 0.001
  u_steps 4
  v_steps 4
  <0,0,0>,<1,1,0>,<2,1,0>,<3,0,0>,
  <0,1,1>,<1,1,1>,<2,1,1>,<3,1,1>,
  <0,1,2>,<1,1,2>,<2,1,2>,<3,1,2>,
  <0,0,3>,<1,1,3>,<2,1,3>,<3,0,3>
  texture{pigment{rgb<1.0,1.0,0.8>}
          finish {ambient 0
                  diffuse 0.4
                  reflection 0}
  translate <-1.5,0,-1.5>
Hope this one helps.
Marc Schimmler
Download 'bezier.jpg' (6 KB)
Preview of image 'bezier.jpg'
Date: 25 Jan 2000 06:36:30
Message: <chrishuff_99-881196.06370625012000@news.povray.org>
In article <388d1251@news.povray.org>, "TonyB"
> my
> nice if instead of
> finish
>  reflection_type
>  reflection_min
>  reflection_max
>  reflect_metallic
>  etc.
> we could have
> finish
>  reflection
>  val / min, max
>  type
>  metallic
>  etc.
> that
> would be a good idea.
I have done something similar to this in my reflectivity patch, which
mostly just gave a new syntax to blurred/angle-dependant reflections.
The syntax for this patch is pretty strange,though. Several things are
controlled by patterns instead of float values.
But it wouldn't be difficult at all to simply add an alternate syntax. I
don't really care for the current one...
Chris Huff
e-mail: chr### [at] yahoocom
Date: 25 Jan 2000 12:28:46
Message: <388DDD2D.56646D56@spiritone.com>
You could try adding no_shadow to the shade, then give the shade some amient
value to make it look like it's glowing from the inside, but that won't make a
defined shadow against the wall, so make a slightly smaller version that is grey
with high transmit value (but not 1) to create the shadow effect.
Just a guess at a workaround
Eric Freeman wrote:
> Hey all,
> Eric
> "A wise and frugal government, which shall restrain men from injuring one
> another, which shall leave them otherwise free to regulate their own
> pursuits of industry and improvement, and shall not take from the mouth of
> labor the bread it has earned.  This is the sum of good government."
>      - Thomas Jefferson
>      - First inaugural address, 1801
> http://www.ametro.net/~ericfree
Josh English
eng### [at] spiritonecom
Date: 25 Jan 2000 17:42:07
Message: <388E23FA.CAD64C4D@faricy.net>
Maybe keep the shadow but give it a texture with high ambience and use a gradient y
to make it brighter (more ambient) where it's closer to the bulb.
Date: 26 Jan 2000 01:20:04
Message: <388e9214@news.povray.org>
I sure appreciate everybody's input.  I'm going to try all of your
suggestions and see which one (or maybe something else) works.
Eric
     - Thomas Jefferson
