POV-Ray : Newsgroups : povray.binaries.images : home Server Time
16 Jun 2026 05:06:13 EDT (-0400)
  home (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: home
Date: 20 Jan 2000 03:58:27
Message: <3886CB88.63087B0D@aol.com>
> Beautiful earth ... but where are the stars?
Thanks.  I forgot the stars.  Was hoping no one would notice. ;)
-Mike
Subject: Re: home
Date: 20 Jan 2000 04:10:00
Message: <3886CEB2.F54C6A8F@pacbell.net>
Mike wrote:
> > The other picture did turn up here, as you may have already seen.
> My newsreader didn't pick it up for some reason, so I can only see this
> thread...unless I mistakenly posted it to another group?  Hmm...confused
It showed up posted to an earlier thread titled "home" started by TonyB
a few months ago. Name collisions happen on a server where the messages
do not expire - I have seen this happen a few times in the past.
Subject: Re: home
Date: 20 Jan 2000 07:01:47
Message: <3886F922.8194877D@stud.ntnu.no>
Neat. Aren't those clouds at too high altitude?
sig.
Mike wrote:
> didn't show up the first time so here it is again...
Subject: Re: home
Date: 20 Jan 2000 10:18:44
Message: <slrn88e9rc.v8.ron.parker@ron.gwmicro.com>
Only if your newsreader doesn't do proper threading.  They're supposed
to thread off the References: header.  Perhaps there's a switch you can
turn on somewhere to fix this behavior.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Subject: Re: home
Date: 20 Jan 2000 10:53:29
Message: <38872F72.8EDD6D92@spiritone.com>
Very nice. Compared to images of Earth (like at
http://planetscapes.com/solar/raw/earth/earthafr.jpg ) your atmosphere is too
high, but you know what? I don't care. It looks much more artistic this way.
In fact, this is an example of art looking better than real life. This is how
I want it to be..
Hope it doesn't get to distorted with stars in the back ground
Josh English
eng### [at] spiritonecom
ICQ: 1946299
"Stress is when you wake up screaming and realize you haven't fallen asleep
yet."
Subject: Re: home
Date: 20 Jan 2000 20:36:34
Message: <3887B585.D786991A@faricy.net>
Ooh
Aah
Your atmosphere is waaaaay to thick but I understand it is for visibility so
that's fine. Maybe you could use the Piqueres technique to give the clouds
more depth... is that a hurricane I see in the upper-right?
Subject: Re: home
Date: 21 Jan 2000 04:01:49
Message: <3888207d@news.povray.org>
Which one is your house?
Subject: Re: home
Date: 22 Jan 2000 01:22:39
Message: <3887FD5D.5DC5534C@earthlink.net>
Wow Beauty Full How Was It Done...?
Source...?
Mike wrote:
> going to upload a short animation to p.b.a I think once this one is up.
This is my reply to the first post somewhere back in 12/25... is where it got
stuck there is another response there too...
from rico:
        My only negative comment is that the oceans are not usually
transparent, or calm!  <smile>  In other words, you really shouldn't be
able to see the underwater contours from this far away.  It looks great
otherwise!
Rich
took the liberty of posting this cuz i do not see it here...
Subject: Re: home
Date: 22 Jan 2000 04:46:47
Message: <388979D6.E47ADB85@aol.com>
Yup there's a little problem with the image as far the contours go.  I need to
touch it up to remove those and improve the land colors a bit.  I'm going to put
the source in the binary scene files group but be warned that it isn't ready to
render without some other files.
-Mike
Subject: Re: home
Date: 22 Jan 2000 14:28:48
Message: <8EC3725B6spammindspringcom@204.213.191.228>
pov### [at] aolcom (Mike) wrote in <388979D6.E47ADB85@aol.com>:
>need to touch it up to remove those and improve the land colors a bit.
>I'm going to put the source in the binary scene files group but be
>warned that it isn't ready to render without some other files.
>-Mike
If you're using an image_map (it looks like a TGA I have of the world) you
can paint the oceans a uniform blue color.  It should also be possible to
use a solid ocean color to apply a bit more reflection to just that part of
the texture.
Rich
