POV-Ray : Newsgroups : povray.binaries.images : home Server Time
16 Jun 2026 05:06:13 EDT (-0400)
  home (Message 11 to 15 of 15)
Subject: Re: home
Date: 20 Jan 2000 20:36:34
Message: <3887B585.D786991A@faricy.net>
Ooh
Aah
Your atmosphere is waaaaay to thick but I understand it is for visibility so
that's fine. Maybe you could use the Piqueres technique to give the clouds
more depth... is that a hurricane I see in the upper-right?
Subject: Re: home
Date: 21 Jan 2000 04:01:49
Message: <3888207d@news.povray.org>
Which one is your house?
Subject: Re: home
Date: 22 Jan 2000 01:22:39
Message: <3887FD5D.5DC5534C@earthlink.net>
Wow Beauty Full How Was It Done...?
Source...?
Mike wrote:
> going to upload a short animation to p.b.a I think once this one is up.
This is my reply to the first post somewhere back in 12/25... is where it got
stuck there is another response there too...
from rico:
        My only negative comment is that the oceans are not usually
transparent, or calm!  <smile>  In other words, you really shouldn't be
able to see the underwater contours from this far away.  It looks great
otherwise!
Rich
took the liberty of posting this cuz i do not see it here...
Mike wrote:
> didn't show up the first time so here it is again...
Subject: Re: home
Date: 22 Jan 2000 04:46:47
Message: <388979D6.E47ADB85@aol.com>
Yup there's a little problem with the image as far the contours go.  I need to
touch it up to remove those and improve the land colors a bit.  I'm going to put
the source in the binary scene files group but be warned that it isn't ready to
render without some other files.
-Mike
Subject: Re: home
Date: 22 Jan 2000 14:28:48
Message: <8EC3725B6spammindspringcom@204.213.191.228>
pov### [at] aolcom (Mike) wrote in <388979D6.E47ADB85@aol.com>:
>need to touch it up to remove those and improve the land colors a bit.
>I'm going to put the source in the binary scene files group but be
>warned that it isn't ready to render without some other files.
>-Mike
If you're using an image_map (it looks like a TGA I have of the world) you
can paint the oceans a uniform blue color.  It should also be possible to
use a solid ocean color to apply a bit more reflection to just that part of
the texture.
Rich
