POV-Ray : Newsgroups : povray.binaries.images : a recent painting (147k before encoding 800x600) Server Time
31 Dec 2025 22:26:35 EST (-0500)
  a recent painting (147k before encoding 800x600) (Message 1 to 6 of 6)
Subject: a recent painting (147k before encoding 800x600)
Date: 14 Jan 2000 15:34:42
Message: <387f8862@news.povray.org>
This is a scene using a recent painting I did. It is of an african violet
that suffered from my not watering it over winter break since I was out of
town. I tried to maintain some detail in this image...
some problems:
1) I forgot to change the picture frame from glass to what it was supposed
to be. I kind of like it this way though.
2) the color of the back glass didn't turn out right. Maybe I need to make
the water object slightly smaller than the glass object for the color to be
visible from the side.
3) the water in the second glass, closer to the front, looks not right for
some reason. it looks like there is a circular something or other on the
surface. the glass/water objects are just csg cones.
comments on this image or the painting :)
ross
Download 'africanvioloet.jpg' (148 KB)
Preview of image 'africanvioloet.jpg'
Subject: Re: a recent painting (147k before encoding 800x600)
Date: 14 Jan 2000 18:14:24
Message: <387FAB51.54E8BF31@faricy.net>
I like the swirls in the painiting, they are reminiscent of Van Gogh.
Date: 14 Jan 2000 20:43:37
Message: <387fd0c9@news.povray.org>
Was the water object used in a 'merge'?  If in a 'union' instead it should show
that color on all sides otherwise you're removing those sides physically by
merging.
Not sure what you meant about the foreground glass water except the hilighting
seems to be cutoff.
Like the painting, btw.
"Ross Litscher" <lit### [at] osuedu> wrote in message
news:387f8862@news.povray.org...
> some problems:
> ross
Date: 16 Jan 2000 15:13:52
Message: <38822680@news.povray.org>
omniVERSE <inv### [at] aolcom> wrote in message
news:387fd0c9@news.povray.org...
show
by
> merging.
hilighting
> seems to be cutoff.
> Bob
no, no merge was used. I don't really know what i mean about the water in
the foreground. it just doesn't look right. maybe if I put a subtle normal
on it. thanks :)
Date: 17 Jan 2000 02:56:58
Message: <3882cb4a@news.povray.org>
This is a bad image. I mean it's good. I like the
way it incorporates "real life" (the fine impasto painting)
with classic ray traced imagery (liquid, glass, etc.)
It is bad because it reminds me of a stack of unfinished
paintings that have been  abandoned by this ray tracing
junky (me:).
Peter Warren
war### [at] hotmailcom
Date: 17 Jan 2000 04:15:07
Message: <3882dd9b@news.povray.org>
news:38822680@news.povray.org...
show
That's interesting then.  Got that snippet of script available so to see here?
Shouldn't be losing the sides of another object unless differenced, intersected,
or merged.
The top water surfaces should be clinging to the side of the glass btw, I just
thought of that, although this is distant view enough to not really matter I
guess.  That clear water hilight is unusual so maybe that's what you meant, cut
off partway across.  I wouldn't think a 'normal' could go on there though since
it's motionless.
