POV-Ray : Newsgroups : povray.binaries.images : hf question/help - Melly Server Time
20 Sep 2025 21:52:24 EDT (-0400)
  hf question/help - Melly (Message 1 to 2 of 2)
Subject: hf question/help - Melly
Date: 10 Jan 2000 07:16:19
Message: <3879cd93@news.povray.org>
My problem is this - I want a hf of a slanted hill/cliff with a
different texture on top to the bare rock shown at the sides (the
exposed cliff).
At the moment I am doing it by having two copies of the hf, one of them
scaled slightly higher in the Y direction and set slightly back and
left. This isn't very satisfactory for a variety of reasons (I can't get
any turbulence in to the edge apart from anything else, which leads to
an over-regular thickness of the two materials).
Is there a better way to do this?
Current code and image below.
height_field // white cliff
 tga
 "c1.tga"
 smooth
 scale <300, 75, 400>
 translate <-175,-5,-50>
  pigment {rgb<1,1,1>}
height_field // green cliff
 tga
 "c1.tga"
 smooth
 scale <300, 80, 400>
 translate <-176,-5,-49>
 pigment {rgb <0,1,0>}
// An infinite planar surface
// plane {<A, B, C>, D } where: A*x + B*y + C*z = D
plane
  y,  -1.0
  pigment{rgb<1,1,0>}
Download 'iso-8859-1' (2 KB)
Subject: Re: hf question/help - Melly
Date: 10 Jan 2000 09:52:53
Message: <3879f245@news.povray.org>
"Tom Melly" <tom### [at] tomandluforce9couk> wrote in message
news:3879cd93@news.povray.org...
My problem is this - I want a hf of a slanted hill/cliff with a different
texture on top to the bare rock shown at the sides (the exposed cliff).
    I use two images, duplicates of the same original, then convert one to
greyscale and blur it , then rescale the other so that the image_map drapes
over the height_field a little.
    Here is a quick example (read:quality very limited)
height_field
  tga "cliff-3.tga"
  water_level 0.2
  smooth
  texture
    pigment
      image_map { tga "cliff-1.tga" map_type 0 interpolate 2 once  }
      rotate x*90
      scale .98
Download 'Cliff001.jpg' (15 KB) Download 'Cliff-2.jpg' (4 KB) Download 'Cliff-1.jpg' (12 KB)
Preview of image 'Cliff001.jpg'
Preview of image 'Cliff-2.jpg'
Preview of image 'Cliff-1.jpg'
