POV-Ray : Newsgroups : povray.binaries.images : Macro Trees :-) Server Time
16 Jun 2026 10:49:46 EDT (-0400)
  Macro Trees :-) (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Macro Trees :-)
Date: 10 Oct 1999 10:05:00
Message: <38009d0c@news.povray.org>
www.shhh.com Thank you...
Date: 10 Oct 1999 13:20:47
Message: <3800CB38.FB90B459@isd.net>
#declare Reputation[Ross] = Reputation[Ross] * 0;
Ross Litscher wrote:
> aS someone mentioned sUPertit in rEfeRence to the image of some recursive
> ball thingie posteD recently, somethIng much more vuLgar and sexually
> disturbing comes to minD. but alas, i need to keep a gOod reputation around
> here so I won't say anything.
Date: 10 Oct 1999 15:04:46
Message: <3800E4DE.485F@pacbell.net>
Has a distinctly coral fell to it.
Ken Matassa
Date: 11 Oct 1999 07:05:36
Message: <38012F69.3C407597@ndirect.co.uk>
Larry
This has already been done.  Check Giles Trand's tree macro
on his web site The Book Of Beginnings, I don't have the
URL, but it'll be on Ken's page.
web http://www.ndirect.co.uk/~sjeln/
Date: 11 Oct 1999 12:05:50
Message: <38020ADC.85A705B@spiritone.com>
Good work. I'm sure you can see that even with the randomness it is not
enough. Smaller parts of the tree are still too similar to the whole. There
needs to be more randomness in the lengths and diameters of each branch, and
then you get the very fun job of putting leaves on the whole thing.
I'm sure you will get a more realistic texture on it as well. I've been
playing with recursive macros for a while, but I haven't got the hang of them
myself.
Don't be detracted by people saying that Gilles has made the ultimate tree
macro (Well, he has, in my opinion) but the purpose is to do it yourself,
right?
Keep up the good work.
Josh English
eng### [at] spiritonecom
icq 1946299
"Stress is when you wake up screaming and realize you haven't fallen asleep
yet."
Larry Fontaine wrote:
> I'm working on a blob-tree-generating macro. I'm surprised I was
> actually able to write the basic shell in so little time! It has the
> same number of limbs branching off at each joint. You can specify the
> recursion level, the angle offset of a limb from its parent, the number
> of branches at each joint, the extent of randomization for the end
> vertex of each limb, the ammount of "bumpiness" on the limbs, the ratio
> of the radius for child limbs, the ratio of the length for child limbs,
> the ratio of the  diameters at the start and end of a limb "cone value",
> the number of components in each limb, the start-coords and end-coords
> of the the trunk, and the starting seed values. With no randomization
> settings, the child limbs would be evnly rotated, ie, if the parent limb
> sticks straight up, then at 3 children the child limbs would point to
> 12:00, 4:00 and 8:00, 120 degrees apart on y-rotation. All of these are
> then rotated by a random amount, regardless of rand. values sent, but
> stay evenly spaced, ie they may end up pointing to 3:00, 7:00 and 11:00.
> I would like to implement random curviness in the limbs (you may have
> seen my post in general) and, of course, leaves and possibly roots. It
> would also be nice if I could avoid branch intersection, but I think
> that may be a tad too difficult.
> This particular tree is 4 levels, 4 braches, 0.6 "cone value", 0.6 on
> both ratios, 50 degrees from parent, 0.4 end-position-randomness, 20
> components per limb, 0.3 bumpiness, 0.3 trunk radius, and 0 for all
> seeds.
> DAF
Date: 11 Oct 1999 16:05:58
Message: <38024355.DA5EC5A1@xs4all.nl>
Steve wrote:
> Larry
So?
Gilles is not the only one who's allowed to have fun, is he?
> Cheers
> Steve              email mailto:sjl### [at] ndirectcouk
Tree macro's can be fun to make and are a very good learning subject.
Remco
Date: 11 Oct 1999 16:09:30
Message: <38024428.CD4E8D5F@xs4all.nl>
> myself.
> right?
> Josh English
> icq 1946299
> yet."
I have tried Gilles tree macro and it _is_ fabulous.
About blob trees I wonder: what'll happen if you have branches crossing?
Obviously they'll blob together. I've tried to make a macro based on a principle
that should avoid this: work from the outside inwards. It was a lot of work to
get it right and it needs a lot of parsing time but when you finally see the
tree it doesn't make any difference. Still, it was fun to do.
Everyone should/could make his or her own tree.
Cheers,
Remco
Date: 11 Oct 1999 16:49:31
Message: <38024D98.3A5159E8@isd.net>
Yes and I don't care
Steve wrote:
> Larry
> Cheers
> %HAV-A-NICEDAY Error not enough coffee  0 pps.
> or  http://start.at/zero-pps
Date: 11 Oct 1999 16:52:14
Message: <38024E3C.810FAF41@isd.net>
Gilles has not made THE ultimate tree macro. The ULTIMATE treemaker is Tree
Designer, but you have to buy it :-(
(OK, I guess Tree Designer isn't a macro, so you're right...)
> myself.
> right?
> Josh English
> icq 1946299
> yet."
Date: 12 Oct 1999 11:38:29
Message: <38035694.DBC8873C@inapg.inra.fr>
> right?
...and there were already many tree macros when I did mine (which I'm in the
process of updating) and there is also Tom Aust's wonderful macro
(http://www.aust-anfertigungen.de/), TreeDesigner and a long list of commercial
programs used by the big boys. To be frank, I don't think there's such a thing as
an ultimate tree macro, because the sheer number of parameters and the parsing
time required for such a macro would make it quite impractical. But tree macros
are fun to create (I learnt a lot while doing mine) and to use, and give good
results if you don't compare them to the real thing.
The following paper was written by the people who make xfrog and may be of
interest for anyone who is interested in the implementation of realistic plant
structures (individual plants or plantations)
http://graphics.stanford.edu/papers/ecosys/
Welcome to the club !
G.
