POV-Ray : Newsgroups : povray.binaries.images : Photon mapping - prism.jpg (~47K) Server Time
28 Jun 2026 18:19:44 EDT (-0400)
  Photon mapping - prism.jpg (~47K) (Message 1 to 3 of 3)
Subject: Photon mapping - prism.jpg (~47K)
Date: 9 Oct 1999 08:08:10
Message: <37ff302a@news.povray.org>
I've created a test image with UVPOV using Photon Mapping. It is an
illustration of a standard class-room experiment showing refraction and
reflection. I wanted to see whether Photon mapping actually could do this,
and the results were quite surprising.
The only problem is that the rays are a bit splotchy and I cannot find good
settings for them.
It was amazing to see that the photons are refracted through the prism and
reflected on the inside, creating a zig-zag pattern as one would expect from
the real world. Rendering time was about 8 mins; 6 mins mapping photons. :/
But I am not quite happy yet. There seems to be some strange phenomena, for
example the forst refracted the stripe suddenly ends!
Any comments welcome!
Simen.
// beginnig of source for prism1.jpg
// settings for photon gathering; as in example in the docs. Lower
// phd gives better results and longer tracing time.
#declare phd=0.35;
global_settings{
        photons{
                gather 20, 100
                radius 0.1*phd, 2, 0.1*phd
                //autostop 0
                jitter .01
                expand_thresholds 0.2, 40
        max_trace_level 20
// an ambient light source
light_source { <-50, 50, -50> color White*0.45 }
// camera - placed on the z-axis then rotated
        location -z*30
        direction z
        up y
        right 4/3*x
        angle 40
        look_at 0
        rotate <47, 30, 0>
// some settings:
#declare w = 0.41; // witdh of constraining container
#declare l = 30; // length of containter - bigger gives narrower spreading angle on
the ray
#declare stre = 10; // strenth of light - do not increase this if l is increased -
automatic adjustment here
#declare h = 10; // height of container. Just a formality
union {
        light_source {
                <0, 2, 0> color White*l*stre
                difference {
  box { <-(w/2+0.5), 0, -(w/2+0.5)>, <l,  h+1, w/2+0.5> }
                        box { <-(w/2),    -1, -(w/2)>,     <l+1, h+2,
w/2> }
                                color Green
        translate x*-l
        rotate y*70
        translate <-7, 0, 15>
// the prism
box {
        -1, 1
        scale <5, 1, 3>
        translate y*1
                color rgbf <1, 1, 1, 0.78>
        finish {
                phong 1
                phong_size 150
                reflection 0.22
                ambient 0.4
                diffuse 0.6
        interior {
                ior 1.44
        photons {
                separation 0.02*phd
                refraction on
                reflection on
                //ignore_photons
// graph paper
plane {
        y, 0
                        gradient x
                        color_map {
                                [0.0, 0.021 color Blue color Blue]
                                [0.021, 1.0 color White color White]
                        gradient z
                        color_map {
                                [0.021, 1.0 color Clear color Clear]
                finish {
                        ambient 0.01
                        diffuse 0.99
// end of source.
Download 'prism1.jpg' (52 KB)
Preview of image 'prism1.jpg'
Subject: Re: Photon mapping - prism.jpg (~47K)
Date: 9 Oct 1999 13:21:09
Message: <37ff7985@news.povray.org>
Try these photon settings:
        photons{
                gather 40, 100
                radius 0.3*phd, 1  // increased radius decreases
splotchiness
                autostop 1.5
                jitter .9  // jitter helps remove that lines effect
                range_divider 1000 // there must be a bug... but this is a
work-around for now
                adc_bailout 1/(256*40)
To greatly decrease trace time, add
 photons { reflection off refraction off}
to your ambient light source.  You can take it off again for the final,
high-quality, trace once all testing is done, if you so desire.
-Nathan
Simen Kvaal <sim### [at] studentmatnatuiono> wrote in message
news:37ff302a@news.povray.org...
good
> settings for them.
from
for
> Simen.
> #declare phd=0.35;
al_settings{
>         photons{
>                 gather 20, 100
>                 file://autostop 0
>                 jitter .01
>                 expand_threshol
ds 0.2, 40
>         max_trace_level 20
> camera {
>         location -z*30
>         direction z
>         up y
>         right 4/3*x
>         angle 40
>         look_at 0
>         rotate <47, 30, 0>
> // some settings:
angle on the ray
increased - automatic adjustment here
> union {
>         light_source {
>                 difference {
> w/2> }
>                         pigment {
>                                 color Green
>         translate x*-l
>         rotate y*70
> // the prism
> box {
>         -1, 1
>         scale <5, 1, 3>
>         translate y*1
>         pigment {
>         finish {
>                 phong 1
>                 phong_size 150
>                 reflection 0.22
>                 ambient 0.4
>                 diffuse 0.6
>         interior {
>                 ior 1.44
>         photons {
>                 separation 0.02*phd
>                 refraction on
>                 reflection on
>                 file://ignore_photons
> // graph paper
> plane {
>         y, 0
>         texture {
>                 pigment {
>                         gradient x
>                         color_map {
>         texture {
>                 pigment {
>                         gradient z
>                         color_map {
>                 finish {
>                         ambient 0.01
>                         diffuse 0.99
> // end of source.
Date: 9 Oct 1999 18:13:02
Message: <37ffbdee@news.povray.org>
>-Nathan
Thanks! I knew the ambient light sucked up about ten times the rendering
time compared to the "ray-source." But I didn't realize that I could simply
turn photons off for the *light_source.* I thought it only worked on objects
that should *recieve* photons... But great! I'll give it a go!
Simen.
