POV-Ray : Newsgroups : povray.binaries.images : No pointlight-atmospheric media interaction here. (43kb) Server Time
18 Jan 2026 00:41:35 EST (-0500)
  No pointlight-atmospheric media interaction here. (43kb) (Message 1 to 10 of 11)
Subject: No pointlight-atmospheric media interaction here. (43kb)
Date: 8 Oct 1999 20:08:11
Message: <37fe876b@news.povray.org>
So what am I doing wrong?
#include "textures.inc"
#include "stones.inc"
#include "metals.inc"
//global_settings { max_trace_level 12 }
//background {Black+Blue/5}
sphere {<0,400,0>,13
        rotate<0,0,0>
        pigment {White}
        rotate<0,0,20>
        pigment {White}
        rotate<0,0,-20>
        pigment {White}
        rotate<0,0,40>
        pigment {White}
        rotate<0,0,-40>
        pigment {White}
        rotate<0,0,60>
        pigment {White}
        rotate<0,0,-60>
        pigment {White}
        rotate<0,0,80>
        pigment {White}
        rotate<0,0,-80>
        pigment {White}
        rotate<0,0,100>
        pigment {White}
        rotate<0,0,-100>
        pigment {White}
#declare f=.084;    // was 0.08
#declare R=399;
#declare funk=
isosurface {          function
          {noise3d(x*f,y*f,z*f)}
         accuracy 0.01
         threshold 0.0
         bounded_by {
         sphere{0,500*(.40+clock)}
        rotate <0,0,90>
//pigment{functionabs((noise3d(x*2,y*4,z*4)*.875)&(noise3d(x*4,y*2,z*4)*.875)&(noise3d(x*4,y*4,z*2)*.875))
poly_wave}
        pigment{Green}
        finish{ambient 0.20 reflection .0}
        normal {crackle}
//object {funk }
  location <0,170,-400>*3.1
  look_at <0,100,0>
  angle 48
light_source{<0.005,0.00081,0.00081>  color White*14
media_interaction on}
  light_source {  <0,0,0>
    color White*14
    spotlight
    radius 90
    falloff 89//28
    tightness 1
    point_at x
#declare j=10;
media {                         //media scattering
  intervals 10
  scattering { 2, red 0.05 blue 0.001 green 0.02}
  samples 1, 10
  confidence 0.9999
  variance 1/1000
  ratio 0.9
Download 'junk.jpg' (43 KB)
Preview of image 'junk.jpg'
Subject: Re: No pointlight-atmospheric media interaction here. (43kb)
Date: 8 Oct 1999 20:40:20
Message: <37FE8EE5.986C97BC@enst.fr>
>         rotate<0,0,0>
>         pigment {White}
>         rotate<0,0,20>
>         pigment {White}
>         rotate<0,0,-20>
>         pigment {White}
>         rotate<0,0,40>
>         pigment {White}
>         rotate<0,0,-40>
>         pigment {White}
>         rotate<0,0,60>
>         pigment {White}
>         rotate<0,0,-60>
>         pigment {White}
>         rotate<0,0,80>
>         pigment {White}
>         rotate<0,0,-80>
>         pigment {White}
>         rotate<0,0,100>
>         pigment {White}
>         rotate<0,0,-100>
>         pigment {White}
> #declare R=399;
> #declare funk=
>          accuracy 0.01
>          threshold 0.0
>          bounded_by {
>         rotate <0,0,90>
> poly_wave}
>         pigment{Green}
>         normal {crackle}
> //object {funk }
> camera {
>   look_at <0,100,0>
>   angle 48
>     color White*14
>     spotlight
>     radius 90
>     falloff 89//28
>     tightness 1
>     point_at x
> #declare j=10;
>   intervals 10
>   samples 1, 10
>   confidence 0.9999
>   variance 1/1000
>   ratio 0.9
	There is, but it doesn't appear because there's nothing to stop the
rays (except for the spheres, but the media here is white anyway).
	If you add a plane { -z, -100 pigment { rgbt 1 } hollow } the media
appears...
		Jerome
PS: if you render at higher res, you'll see the media appear for a few
pixels in the pic...
* they'll tell you what can't * mailto:ber### [at] inamecom
* be done and why...          * http://www.enst.fr/~jberger
* Then do it.                 *
Date: 8 Oct 1999 20:48:24
Message: <37FE90C9.A95DEA68@enst.fr>
Attached is a render with your parameters at 640x480. One of the sphere
has a blue pigment, one is red and one is green, the other are still
white  but the media effect washes them out completely and all appear
white...
		Jerome
PS: jpeg played havoc with most of the blue dots from the media but some
still remain to show it's here...
* Then do it.                 *
Download 'test.jpg' (45 KB)
Preview of image 'test.jpg'
Date: 8 Oct 1999 21:39:46
Message: <37FE9CD3.311984AD@enst.fr>
If you up the quality settings, you can make the media appear, but it
will cost you a lot of time... This one rendered at 10PPS on a PII 266
  intervals 100
  samples 10, 100
  confidence 0.999999
  variance 1/100000
  ratio 0.9
		Jerome
* Then do it.                 *
Download 'test.jpg' (14 KB)
Date: 9 Oct 1999 01:18:46
Message: <37fed036@news.povray.org>
grumble
GrimDude
gri### [at] netzerocom
Date: 9 Oct 1999 10:20:03
Message: <37ff4f13@news.povray.org>
Thanks for the effort.  What I eventually am trying to get is a "christmas bulb in
a wiffle ball in the fog," except my wiffle ball is an isosurface.
This whole effect renders quickly, is intuitively set up, and only requires a
White*14 intensity SPOTLIGHT.
When i go to POINTLIGHT, I have to put that plane in there and raise the intensity
several orders of magnitude to get it to work. And as you said, requires a long
render time.
What's the difference between spot & point lights???  Is this "intentional"??
> white...
>                 Jerome
> * Then do it.                 *
Date: 9 Oct 1999 15:21:48
Message: <37ff95cc@news.povray.org>
Greg M. Johnson <"gregj;-)56590"@aol.c;-)om> wrote in message > What's the
Spotlight works like a spotlight, er search light if you will. :)
Assuming, of course, that you define it properly.
If you are using Pov 4 Windows, just click on the area indicated in the
included image, while your Pov F.E. is up and running. ;)
GrimDude
Download 'Start.jpg' (2 KB)
Preview of image 'Start.jpg'
Date: 9 Oct 1999 18:36:33
Message: <37ffc371@news.povray.org>
Haha! I almost got a heart-attack there! Have I missed something, I thought.
;o)
Simen.
Date: 9 Oct 1999 20:54:05
Message: <37ffe3ad@news.povray.org>
heh
GrimDude
Date: 9 Oct 1999 23:20:22
Message: <380005f6@news.povray.org>
huh
