POV-Ray : Newsgroups : povray.binaries.images : Re: 12-sided die Server Time
21 Jul 2026 15:28:02 EDT (-0400)
  Re: 12-sided die (Message 1 to 2 of 2)
Subject: Re: 12-sided die
Date: 4 Oct 1999 04:01:36
Message: <37F85EBD.5332E662@jps.net>
Ian Burgmyer wrote:
> NOT a regular polyhedron?  Odd. . .
> Larry Fontaine <lfo### [at] isdnet> wrote
> > The 10-sided isn't a regular polyhedron, either. ...
All a fair die needs to be is a dual of an (extended) Archimedean
polyhedron - all vertices alike.  That way all the faces will be alike,
but not necessarily regular.  The 10-die is the dual of the pentagonal
prism or antiprism.
"How'd ya like to climb this high without no mountain?" --Porky Pine
Anton Sherwood  *\\* +1 415 267 0685 *\\* http://www.jps.net/antons/
Date: 10 Oct 1999 23:39:16
Message: <38015786.56F8449A@jps.net>
> alike, but not necessarily regular.
I'll put that another way.  Dice can be made like this:
	intersection {
		plane { V0, 1 }
		plane { V9, 1 }
For a fair die, there must be a rotation group S relating all the
vectors.  For each (i,j) there must be a rotation in S such that the
image of Vi is Vj; and every image of Vi must be a member of the set V.
The vertices of a semiregular (Archimedean) solid satisfy this
condition, but so do some nonregular intermediate forms.  For example:
take two pentagons and place them parallel, so that their vertices are
those of a prism.  Now rotate one of the pentagons on the axis of the
prism: the symmetry group remains the same, and thus the vertices of the
two pentagons remain a valid set V, as described above, for a fair 10-die.
> The 10-die is the dual of the pentagonal prism or antiprism.
Or something between.  The one I have is anti.
