POV-Ray : Newsgroups : povray.binaries.images : Attempt at "Photo-Realism" Server Time
16 Jun 2026 13:46:47 EDT (-0400)
  Attempt at "Photo-Realism" (Message 11 to 17 of 17)
Subject: Re: Attempt at "Photo-Realism"
Date: 4 May 1999 23:09:37
Message: <372FA7D9.796E4F8E@pacbell.net>
GrimDude wrote:
>   Somewhere around here I have the specifics, if you really want them
> (specific to which model of the 51?) :)
Just curiosity. It is probably equivelant in length to a 1/4 wave antenna
just by guessing and no one else around here would care one way or another.
If it's in front of you drop the number off. If you have to rumage for it
don't waste your time. If I really want to know bad enough I could find
out in fairly short order on one of the ham groups.
>   Double negatives are so confusing! Did you mean you really want another
> image, or that you are not so impressed? :)
> GrimDude
> vos### [at] arkansasnet
 I meant to say I like the model work from what I can see so far but the
image you posted was lacking in size, clarity, and sharpness. I would of
course prefer to evaluate anothers art using the best medium for that
evaluation and feel I have not yet had that advantage.
Ken Tyler
mailto://tylereng@pacbell.net
Subject: Re: Attempt at "Photo-Realism" 800x600 ~ 50k
Date: 5 May 1999 00:09:59
Message: <372fb687.0@news.povray.org>
heh, okay.
  14'-1/4" for the D-model Mustangs stationed in Europe. I understand they
were a little longer for the Pacific theatre. The frequencies in use at the
time are probably well known, but were not included in this reference
("Detail and Scale"; issue 8251, volume 51; Squadron Signal Publications,
1997). I could find out more, but the rest of my volumes are packed away too
deep. <G>
  Some of the problems I am seeing in the model I created are:
1) Close ports and seams seem to be swamped by ambient light. Check out the
bright radiator inlet, and rudder hinge line. Perhaps a problem with
distance_maximum?
2) I applied the decals (image_maps) only to the opposite side of the
aircraft, without clipping. Big mistake. I should remove them or do them
right.
3) The painted surfaces are darkening unrealistically, or so I feel. If
anyone has a clue as to why this is, let me in on it :)
4) The aircraft panel lines have been ignored by choice. The model has
already exceeded 8megs, and that's enough. If, I ever get things looking
good, I may go back and clip out the individual panels.
5) Wingtips are a b****. <G> Nuff said.
Further criticisms welcome.
GrimDude
Download 'Rad51-3.jpg' (47 KB)
Preview of image 'Rad51-3.jpg'
Date: 5 May 1999 03:53:15
Message: <372FEA53.E3AAABAC@pacbell.net>
GrimDude wrote:
>   heh, okay.
> deep. <G>
  Thanks for the input.
> distance_maximum?
  "distance_maximum?" ?
   Perhaps the amount of diffused finish used but more likely caused
 by phong highlighting in the metallic finish statement or a combination
 of the two. Remove the phong if it's in there and try specular instead.
 I like to try amounts starting with specular 0.6 roughness 0.001 to
 0.0001 for really tight highlights.
> right.
  Yup !
    How far is the light source from the object. I have noticed a more
 uniform lighting model when the light source is greater than say 200
 -300 pov units from the object. It seems to give more proximity related
 traits inside the 100-200 pov unit range and even more so from 100-0.
    Try different light source distances and evaluate the changes they
 make in the appearence of the model. Also try a silver colored fill
 light to add to the reflected color from the aircrafts surface.
 Couldn't hurt to experiment a bit at this point.
   Finish statements are of course always suspect when a texture, or
 pigment with finish, does not perform as expected.
  I'll fix the roof as soon as it stops raining. (cough)
  Tapered swept wingtips are a serious B**** !!! Nuff indeed.
I've had my say thank you.
> GrimDude
Ken Tyler
Date: 5 May 1999 03:57:29
Message: <372FEBD8.FCE03852@ica.uni-stuttgart.de>
GrimDude wrote:
>   T-Storms and Tornadoes are keeping me from getting this done, but I
> thought I'd risk my modem to share this with you all.
>   Obviously, I don't have everything set exactly right yet, but radiosity is
> really helping this scene. I cropped this down to the P51, so as not to
> reveal too many details. I don't want to spoil everything! :)
> GrimDude
Very well done!
Marc
Marc Schimmler
Date: 5 May 1999 04:10:31
Message: <372feee7.0@news.povray.org>
GrimDude wrote in message <372f8829.0@news.povray.org>...
>fin. The vertical mast is actually another radio, intended to be a
>directional finder.
Eek, poor edit again.
The vertical mast is actually *for* another radio,...
Sorry.
GrimDude
Date: 5 May 1999 04:30:47
Message: <372ff3a7.0@news.povray.org>
Ken wrote in message <372FEA53.E3AAABAC@pacbell.net>...
>GrimDude wrote:
>>   heh, okay.
>>   14'-1/4" for the D-model ...
No problem! Should you need any further information of this kind (relative
to the Mustang I, II, III, P51, P51A, B, C, D, K, H or F-82 Twin Mustang)
don't hesitate to ask!
>> Perhaps a problem with distance_maximum?
Well, I thought I had tried enough variations that I might have discovered a
bug somewhere. Still testing...
Actually, my texture is similar to your suggestion here. I used a high
brilliance, which I am testing now.
I was inside of 100 units with the light_source, but relative to what? My
model spans .1x.08x.03 (or so) units, and the light_source is 39 units
distance. I'm testing a much greater distance now.
Primitives are much easier to deal with then those sloping roofs.
  Additionally, I think there may be a bug in the program I used to convert
from TruSpace's .dxf output into Pov's smooth triangles. I'm looking into
this too, but I've noticed that the finish on the wing surface, and anywhere
I've done a sharp clip, has been dulled severely. I'm hoping it's just a
coincidence and I'll find something else that fixes this.
  The more I work on these planes (and no, not just 51's), the more I find
there is to add detail-wise.
Thanks for the suggestions! :)
GrimDude
Date: 5 May 1999 15:42:19
Message: <373086D2.84BB16B2@ndirect.co.uk>
I don't know much about planes, but I'm sure that the finished
article will be impressive.
Steve
> GrimDude
