POV-Ray : Newsgroups : povray.binaries.images : Space filling curves (~50Kb) Server Time
16 Jun 2026 15:02:28 EDT (-0400)
  Space filling curves (~50Kb) (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Space filling curves (~50Kb)
Date: 2 May 1999 02:36:21
Message: <372be455.0@news.povray.org>
If who is Mr Truchet interests anyone :
Father Sebastien Truchet : He was born at Lyon in 1657, and is known for his
work in the definition of the metrics of fonts (that we still use !).
The drawing saw in the same thread is known as the Truchet-tiling.
I suppose they are the same people but not sure
Philippe
Date: 2 May 1999 04:50:10
Message: <372c03b2.0@news.povray.org>
For those of you who were interested, the results of this posting:
Thanks to Philippe for the information on the origins of this curve. I took
a look at the Truchet tiling, and it seems to be a bit simpler than the
space-filling-curve (SFC) that I submitted. I also looked into Dragon Curves
and confirmed that this is not of that classification. I was fooling around
with SFC's back in the early 80's and after so many years, my neurons are
all cross-linked between Hilbert, Sierpinsky, Peano, Dragon, etc.
This SFC is actually a simple contouring algorithm. I'd been tinkering with
this at the same time I was messing with the SFC's and subsequently merged
it in with the the other regular patterns.
In response to Bob Hughes suggestion that this has a "fractal" quality, I
have to agree. This is a fractal in the same sense that a plasma is a
fractal, i.e., the details are random, but the structure is coherent.
"Regular" SFC's such as Hilbert, Peano, etc., are recursive and predictable.
Philippe had suggested animating this, but I have to humbly admit that I
don't know how this might work. Philippe, please elaborate, se vous plez...
Last, but not least, thanks for everyone's comments and suggestions!
David Cook <nos### [at] homecom> wrote in message
news:372b2123.0@news.povray.org...
> I've always referred to this type of space-filling curve as a Dragon
Curve.
> I'm not sure if that's its true mathematical name or not. Can anyone out
> there identify this class of curves?
Date: 2 May 1999 18:48:03
Message: <372CB523.D2E3782C@bahnhof.se>
Now theese look really cute... Hmm, lead water through them, an excellent heat
exchanger... (is that the name in english?) If they all were connected. that is.
David Cook wrote:
> I've always referred to this type of space-filling curve as a Dragon Curve.
//Spider    --  [ spi### [at] bahnhofse ]-[ http://www.bahnhof.se/~spider/ ]
And the meek'll inherit what they damn well please
	Get ahead, go figure, go ahead and pull the trigger
		Everything under the gun
			--"Sisters Of Mercy" -- "Under The Gun"
Date: 2 May 1999 20:26:38
Message: <372CDF29.6B21FE12@aol.com>
Heat pump is what is commonly said around here. Heat exchanger sounds more
New England to me. I wondered about the animation aspect myself. Seems
impossible, how would the torii stay linked and yet move, aside from the
usual way? :)
> >  [Image]
 mailto://inversez@aol.com?Subject=PoV-News
Date: 3 May 1999 12:23:19
Message: <372dbf67.0@news.povray.org>
Philippe sent me an example of what he had in mind for animation. It was
simply re-randomizing the pattern, which isn't what I would consider
animation - the pattern just jumps around. I'm still thinking about it, but
I'm not sure a smooth animation can be done.
Bob Hughes <inv### [at] aolcom> wrote in message
news:372CDF29.6B21FE12@aol.com...
> usual way? :)
excellent heat
that is.
Curve.
out
> > >  [Image]
> > file://Spider    --
>   http://members.aol.com/inversez/homepage.htm
Date: 3 May 1999 23:02:21
Message: <372E54B4.7B8AB346@pacbell.net>
Radiator.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 4 May 1999 09:02:31
Message: <372EE083.7F72AF6D@bahnhof.se>
Thanx :-)
> Radiator.
> Ken Tyler
Date: 4 May 1999 21:11:44
Message: <372f8cc0.0@news.povray.org>
excellent heat
that is.
>> Radiator.
Although heat exchangers ARE a real thing :) I know - I've build some for
industrial pumping engines :)
Date: 4 May 1999 21:24:28
Message: <372F8F33.D2E4FD90@pacbell.net>
> excellent heat
> that is.
> >> Radiator.
Air conditioning systems rely upon them quite heavily as do industrial
HV transformers. Quite a few computer CPU's would die without them.
Ken Tyler
Date: 4 May 1999 21:25:22
Message: <372F8EA0.EC227F93@bahnhof.se>
Hmm.. Perhaps I wasn't clear enough to waht I meant then... I meant those inside
powerplants, that convert the energy from burning coal/GROT (Swedish name is
"Grenar Ris Och Toppar", ie. waste from clearings) into water, and then once
again into the warm water system that supplies the town. (in this case) yep,
there are two different water systems due to different water qualities and so
on.
Theese things tend to be pretty large tubes carrying the water at a relative
high speed. (Ken's not the only "injuneer" around :-)
> excellent heat
> that is.
> >> Radiator.
