POV-Ray : Newsgroups : povray.binaries.images : Fractal Ooze Server Time
7 May 2026 15:15:04 EDT (-0400)
  Fractal Ooze (Message 12 to 21 of 31)
Subject: Re: Fractal Ooze
Date: 30 Apr 1999 16:35:43
Message: <3729FE8E.C37C21BD@ndirect.co.uk>
Are you sure about this?  Administrators can delete messages, but
I would think that if I post a message here and go away, turn off
and come back tomorrow, I might not be able to remove even my own
messages.  I'm on DHCP via my ISP, and tomorrow would probably
have a different unique identifier.
Just thinking.....
Steve
Thomas Willhalm wrote:
> Marc Schimmler <sch### [at] icauni-stuttgartde> writes:
> > Lewis wrote:
> > > Thanks! But what if someone tries to cancel my messages?
> > This is not possible! I would have been tempted to do that with -@--
> > posts! :-)
> > Only the poster can cancel it. And only from the same address if I
> > remember right.
> Since you can fake your address, it is possible to cancel articles of
> other users. I haven't tried it, but I know that it is possible at least
> on other newsservers.
> Thomas (hoping that Nick won't read this)
> http://www.fmi.uni-konstanz.de/~willhalm
Date: 30 Apr 1999 23:46:03
Message: <3729DE83.244645F6@bahnhof.se>
interesting images, what was the formulae, again?
(*hint*)
Alex Vandiver wrote:
> With all of these fractals flying around, I decided to dig through a
> book I had lying around.  There's an interesting passage in the book,
> where it is discussing these figures, called 3d dragon curves, and I
> quote,
> "..he uses IBM's computer resources to plot a million or more points in
> three dimensions to generate a three-dimensional dragon curve.  He then
> runs a ray tracing program which determines the illumination of every
> point and the positioning of it on a two-dimensional display.  Needless
> to say, this is beyond the capability of our personal compters."
> The book is a little out of date, apparently.. (published in 1990)  I
> didn't quite use a million points, but I did use 1 out of every 5 of my
> 288000 calculated points.  57600 blobs still makes a pretty funky image,
> tho..
> -Alex V.
>  [Image]  [Image]  [Image]
//Spider    --  [ spi### [at] bahnhofse ]-[ http://www.bahnhof.se/~spider/ ]
And the meek'll inherit what they damn well please
	Get ahead, go figure, go ahead and pull the trigger
		Everything under the gun
			--"Sisters Of Mercy" -- "Under The Gun"
Date: 1 May 1999 01:55:36
Message: <372A88B7.FAA61FCB@pacbell.net>
Marc Schimmler wrote:
> I guess you have serious problems to answer to the right posting! :-)
> You can cancel the ones that have gone wrong with
> EDIT -> cancel message   in your netscape menu.
I just press the delete key. Saves steps and works exactly the same.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 1 May 1999 03:14:55
Message: <372a9bdf.0@news.povray.org>
anyone know how to delete your own messages in IE5?
Rygad
Marc Schimmler <sch### [at] icauni-stuttgartde> wrote in message
news:37299B55.D1DB3ACF@ica.uni-stuttgart.de...
> Have a nice day,
> Marc
> Marc Schimmler
Date: 1 May 1999 03:49:54
Message: <372aa412.0@news.povray.org>
Umm, under "Compose" I think. Cancel message.
GrimDude
vos### [at] arkansasnet
Date: 1 May 1999 07:54:58
Message: <372ADD73.3990FC30@tiac.net>
> (*hint*)
Unfortunatly, I'm not all that clear on the formula, myself, I just thought it looked
interesting.. ;>
Originally, I wrote the code to export the points in Turbo Pascal, but here's the POV
translation of it; make sense of it what you will.  I'm not posting this as a real
macro, though, as it would take way too long to get any number of points.  POV just
doesn't like the serious number crunching..  As soon as I can throw one together, I'll
post a .. *gasp* .. 2d .. image of the dragon curve, which will probably make it more
clear why it's called that..  Hrm.  Actually, as posting of 2d images is unlawful
around
here, I just may have to TGAmosaic it.. *g*
-Alex
---- Code follows ----
-- Oooh! Indention! --
#declare detail = 400;   // Lower numbers make more blobs..
#declare Qval = 0.97064; // Main parameter to change to get different shapes.
                         // Note that Qval=0 doesn't work.. this is actually the
                         // imaginary part of a complex number; P is the real
                         // part.
#declare R = seed(42);
blob {
#declare k = 3;
#while (k >= -3)
  #debug concat(str(k,5,5),"\n")
  #declare tx = 0.50001;
  #declare ty = 0;
  #declare magnitude = (k*k + Qval*Qval);
  #declare Q = (-4*Qval/magnitude);
  #declare P = (4*k/magnitude);
  #declare i = 1;
  #while (i <= 12000)       // Iteration part.  Each iteration is more accurate.
    #declare temp_x = (tx*P - ty*Q);
    #declare ty = (tx*Q + ty*P);
    #declare temp_y = ty;
    #declare tx = (1- temp_x);
    #declare magnitude = sqrt(tx*tx + ty*ty);
    #declare ty = sqrt((-tx+magnitude)/2);
    #declare tx = sqrt((tx+magnitude)/2);
    #if (temp_y < 0)
      #declare tx = (-tx);
    #if (rand(R) < 0.5)  // 50-50 chance of using the negative square root
      #declare ty = (-ty);
    #declare tx = ((1-tx)/2);
    #declare ty = (ty/2);
    #declare tz = (P/2);
    #if (mod(i,detail) = 0)
      sphere {<tx,ty,tz>,0.0625,1  pigment {rgb vnormalize(<tx,ty,tz>)} finish {phong
1/(1+sqrt(tx*tx + ty*ty))}}
    #declare i = (i+1);
  #declare k = (k - 0.025);
Date: 1 May 1999 09:54:05
Message: <372AF957.6C4C4415@tiac.net>
Here's the promised 2d image.  It uses the same function, but only takes a
crossection.  If
you stretch your imagination, it *might* look like a dragon..
-Alex
Download '2ddrag.jpg' (45 KB)
Preview of image '2ddrag.jpg'
Subject: Looks like julia (82k)
Date: 1 May 1999 17:58:28
Message: <372B6AE8.C5B43480@home.com>
Interesting. Now I know almost nothing about fractals so I don't know if this has
anything to
do with it but the outline of this "dragon curve" looks a bit like the outline of a
julia
fractal. I've posted a julia fractal from Fractint.
crossection.  If
> -Alex
Download 'fract001.gif' (82 KB)
Preview of image 'fract001.gif'
Subject: Re: Looks like julia (82k)
Date: 2 May 1999 09:44:16
Message: <372c48a0.1@news.povray.org>
I think you might be on to something here!
I love Fractint, anybody else ever play with it?
Thomas Lake <tla### [at] homecom> wrote in message
news:372B6AE8.C5B43480@home.com...
this has anything to
outline of a julia
a crossection.  If
> > -Alex
> >  [Image]
Date: 2 May 1999 09:46:53
Message: <372C4A11.46E4B77D@netvision.net.il>
me
