POV-Ray : Newsgroups : povray.binaries.images : Waterfalls Server Time
28 Jun 2026 22:37:32 EDT (-0400)
  Waterfalls (Message 1 to 6 of 6)
Subject: Waterfalls
Date: 28 Apr 1999 17:09:42
Message: <37276b06.0@news.povray.org>
This is a feasibility study NOT a finished pic. I wanted to see if it was
worth pursuing the idea
I would be grateful for your comments and advice before I continue.
Mick
Download 'waterfall.jpg' (130 KB)
Preview of image 'waterfall.jpg'
Subject: Re: Waterfalls
Date: 28 Apr 1999 17:49:27
Message: <37277457.0@news.povray.org>
This looks like its going to be tricky, but if you can pull
it off it will be one of the great pictures of the year... go
for it!
Mick Hazelgrove <mha### [at] mindaswinternetcouk> wrote in message
news:37276b06.0@news.povray.org...
> Mick
Date: 28 Apr 1999 18:54:28
Message: <37278394.0@news.povray.org>
How did you do the water?  It looks like you replicated the same water
pattern at each level of the falls.  If possible I'd suggest you make the
pattern at the edge of each fall different as well as the water pattern as
it falls from one level to the next.
Will you be putting any mist at the base of each fall?  What about using the
dispersion and photon patch with the sun light source at an angle so that
you get a rainbow in each mist at the base of each fall?  I was going to do
something like that but haven't taken the time yet ...
It's a good start.  I eagerly await the final version.
Jim
Check out my web site http://www.kressworks.com/
It'll blow your mind (politically), stimulate your senses (artistically)
and provide scientific insights beyond compare!
Be sure to read the Warp maintained POV VFAQ:
http://iki.fi/warp/povVFAQ.html
Mick Hazelgrove wrote in message <37276b06.0@news.povray.org>...
>Mick
Date: 29 Apr 1999 06:44:42
Message: <372833AF.869F94F1@no13.net>
The concept is definitely worth pursuing further. Is it one HF or two ?
> Mick
regards
Nathan O'Brien
no1### [at] no13net
http://www.no13.net
Date: 29 Apr 1999 12:48:31
Message: <37287f4f.0@news.povray.org>
Thanks
Two but the final pic will have one per fall
Mick
Nathan O'Brien <no1### [at] no13net> wrote in message
news:372833AF.869F94F1@no13.net...
was
> > Mick
> >  [Image]
> regards
> Nathan O'Brien
> no1### [at] no13net
> http://www.no13.net
Date: 29 Apr 1999 16:31:30
Message: <3728B329.EAF42257@geocities.com>
It looks really good so far. The green water doesn't look right to me,
IMHO I would make it blue and clearer, if possible. Keep up the good
work.
		Kyle
> Mick
