POV-Ray : Newsgroups : povray.binaries.images : Another fractal Server Time
18 Jan 2026 07:40:17 EST (-0500)
  Another fractal (Message 1 to 8 of 8)
Subject: Another fractal
Date: 27 Apr 1999 15:44:18
Message: <37260582.0@news.povray.org>
Mike Metheny
lon### [at] vtedu
mik### [at] loneshepherdcom
http://www.loneshepherd.com/
"When one's words are no better than silence, one should keep silent."
Download 'fractal1.png' (303 KB)
Preview of image 'fractal1.png'
Subject: Re: Another fractal
Date: 27 Apr 1999 16:30:55
Message: <37260F33.DBA68BB0@bahnhof.se>
hey... Cute:-)
hmm, can you all distribut the sources for the fractals ?? It'd be a nice
"fractal archive" in pov... *smiles*
Mike Metheny wrote:
> Mike Metheny
> lon### [at] vtedu
//Spider
                "Marian"
        By: "Sisters Of Mercy"
Date: 27 Apr 1999 16:35:36
Message: <37260D61.EE2CFD7B@pacbell.net>
Now, that is cool. Borg snowflake?   ;-]
KB-
Mike Metheny wrote:
> Mike Metheny
> lon### [at] vtedu
>    fractal1.png    Type: PNG (image/x-png)
>                Encoding: x-uuencode
Date: 27 Apr 1999 16:52:06
Message: <37261566.0@news.povray.org>
Fractals and POV really are a wonderful mix, no?
I suspect this is in reality 6 copies of a 2D-fractal forming the cube.
Right?
Margus
Mike Metheny wrote in message <37260582.0@news.povray.org>...
>Mike Metheny
>lon### [at] vtedu
Date: 27 Apr 1999 18:37:34
Message: <37262e1e.0@news.povray.org>
<<Fractals and POV really are a wonderful mix, no?
Right?>>
You are correct sir.  actually, I started out with a fractal I used to draw
by hand on occasion, (seen below)  and for the cube combined 4 of these per
side; for 24 fractal shapes to create the actual box.  Each segment is a
cylinder capped by 2 spheres; the above image took close to 5 hours to
render. . .I wonder if it would be faster to use one box in said instance?
Also I had to make the width of the segments fairly large; they look kinda
funny at lower iterations. . .what was happening is that I thought my code
was faulty cause several segments (pixel wide i guess) were missing in the
render unless the thickness was increased greatly.  Anyway, once I clean up
the source for the fractal itself, and turn it into a macro (which was my
original intention, my first try at macros) but right now it's just a while
loop.
Mike Metheny
lon### [at] vtedu
Download 'fractal1(5).jpg' (30 KB)
Preview of image 'fractal1(5).jpg'
Date: 27 Apr 1999 19:47:50
Message: <37263e96.0@news.povray.org>
Mike Metheny wrote in message <37262e1e.0@news.povray.org>...
At this size, there would be little visible difference. So I suggest you go
with boxes (or just cylinders, because they are easier to position). Should
be a lot faster.
Margus
Date: 27 Apr 1999 21:44:23
Message: <372622CC.39C47B73@ndirect.co.uk>
I like it.  What's this one called?
Steve
Mike Metheny wrote:
> Mike Metheny
> lon### [at] vtedu
Date: 27 Apr 1999 22:26:46
Message: <372663d6.0@news.povray.org>
<<I like it.  What's this one called
Hmmmmmm. . .doodles de Mike?
This is just one of the simplest ways to introduce fractals to someone, by
taking a line segment, splitting it up, and using equal size segments to
create a shape, then repeat.    I'll do another one along the same lines in
2d that will be a more complicated split up line segment, just for
experimentation.
Mike Metheny
lon### [at] vtedu
