POV-Ray : Newsgroups : povray.binaries.images : Nuke_um ! Server Time
7 May 2026 17:42:02 EDT (-0400)
  Nuke_um ! (Message 14 to 23 of 33)
Subject: Re: Nuke_um !
Date: 20 Apr 1999 04:16:57
Message: <371C29A9.93CAA514@aol.com>
Number 3. 3rd times a charm, with a bit of tweaking.
I used the number 2 image combined with a 3rd render, having better
absorption, by using layered image_map textures with transmit and filter
on a white 'background'.
I still wasn't entirely happy with the contrast of that render so I
opened it into PSP and adjusted it there; not much, but much better.
Probably could have gotten a good finish to do the same though I used no
light.
Speaking of light, I used two in the top of the explosion cloud. One
point light and one a 'spotlight' above that and pointing down with a
'radius 15 falloff 30 tightness 1'.
Don't think I said before but the air cloud and ground rings are simply
textured torii, no media in them. It was too slow that way.
Bob Hughes wrote:
> Here's the ground shockwave addition. Funny Margus would mention an ior
> in it. I thought of that while adding it in (higher pressure air,
> thicker, denser, so higher refraction? sounds good) though I only used
> it in the outer ring and no noticeable difference.
> I still need to add a better absorption to the mushroom to mask out the
> background, or rather, give it better thickness. I enhanced the
> atmosphere shockwave a bit and removed the inner media object as well,
> it was just messing it up anyway. Speedier render of course, around an
> hour and a half I think. Closed POV before looking.
> May be back with a third (and final?).
> Bob Hughes wrote:
> > GrimDude wrote:
> > > Hmm, animating it may prove difficult.
> > You bet. Took 2h 46m to render this one, with AA on, on a 233MMX cpu. I
> > used a double instance of the object though and it would have probably
> > taken only 1h 45m I guess. I did so many s-l-o-w test renders at 160x120
> > I gave up at this point with a 320x240 res. See what you think,
> > realistic or not. I believe it's lacking a lot still. Namely better
> > color differentation.
> > Disclaimer: nuking of any form is not necessarily endorsed by the maker
> > of this image nor implied to be by the newsgroup proprietors. But you
> > may want to check with the original creator and poster(s) as to their
> > beliefs.
> > How's that for legal mumbo-jumbo?
> >  omniVERSE: beyond the universe
> >   http://members.aol.com/inversez/homepage.htm
> >  mailto:inv### [at] aolcom?Subject=PoV-News
> >  [Image]
Download '3nuke.jpg' (25 KB)
Preview of image '3nuke.jpg'
Date: 20 Apr 1999 04:43:27
Message: <371C3043.15B3BBA0@pacbell.net>
> light.
  Ok Bob. I'm ready to take my source back now so I can add the
finishing touches. Thanks for taking the tim....
   Seriously I would like to see what you have done with the media.
I'm not so sure I would have resorted to the buried light source but
in this game whatever achieves the desired goal is acceptable. If you
would prefer not to make it public you are welcome to send it to me
privately, or not at all is an option too. You have piqued my curiosity
now and that can be a terrible itch for me to try to scratch.
 From a purely technical point of view the symmetrical shape of the
upper dome is all wrong at least when compared to some of the earlier
photographed images of aerial detonations. The top should not be nearly
as flat and symmetrically round as the lathe object I made and there is
quite a bit of turbulence to the formation of the upper levels that
give this away as a computer construct. For scenes that the cloud
will not be in a position to be examined with such scrutiny I doubt
that it would matter all that much.
  Take a look at the image below. The image on the left is a shot of
the Nagasaki detonation well after the plane had turned and the image
on the right is the famed Trinity detonation. Both exhibit different
behaviour so who knows how the current weapons appear having the
benefit of state of the art design and manufacturing facilities to
produce them with.
Ken Tyler
mailto://tylereng@pacbell.net
Download 'nuke_um2.jpg' (15 KB)
Preview of image 'nuke_um2.jpg'
Date: 20 Apr 1999 04:46:41
Message: <371C3123.8D7E9263@pacbell.net>
> produce them with.
 Correction: Switch my left/right descriptions to match the actual
photos position in the image provided. Sorry for the misdirection
on my part.
Ken Tyler
Date: 20 Apr 1999 07:00:20
Message: <371C5032.8158C816@ica.uni-stuttgart.de>
> produce them with.
The biggest difference between the trinity test and the later bombing
has been the height of the detonation point. While the trinity test used
a tower with a height of about guessed 30 or 40 meters while the dropped
bombs were detonated at height of (if I remember correctly) 500 meters
to maximize the damage done by the shockwave (as if that had been
necessary!).
The mushroom cloud should build up nontheless even at the trinity site
because this is caused by convection of the heated air. The pic you
showed was taken in a early stage of the explosion.
Even modern weapons, designed to produced special shockwaves etc. will
show a mushroom cloud if they are fused in the vicinity to ground.
Marc
Marc Schimmler
Date: 20 Apr 1999 07:14:23
Message: <371C533D.B0F28C62@aol.com>
I thought that looked wrong somehow, see it correctly now.
The lathe is great though, it's more the problem with getting a
turbulent look with media that makes it difficult to use. This is a
classic example of how well a turbulence for objects themselves would be
of good use.
Well, I actually meant to add that script in with my uploaded image,
slipped my mind, as I hastily ran through all these posts and replies at
n.p.o.
So I was thinking of emailing it to you, signed off before writing the
email. Now I can get it put here (watch out for line wrap) and you'll
see just how sloppy my pov making can be.
//BEGIN
 global_settings {
 max_trace_level 10
camera {location<0,0,-9> look_at y*2.5}
//sphere {0,1 pigment {rgb 1}}  //measuring stick used to judge size
//ground
plane {y,.125 pigment {rgb<.8,.7,.5>} finish {ambient .3 diffuse .7
phong .5 phong_size 1} rotate -3*x}
// evening
sky_sphere { //0,1 hollow //if sphere instead
    gradient y
color_map { [0.0 color rgb<0.9,0.5,0.475>] [1.0 color
rgb<0.2,0.45,0.65>] }
  } //finish {ambient .75 diffuse .25}  //if sphere
  //scale 100  //if sphere
  #declare Shroom =
  lathe{
  quadratic_spline
  40,
  <0.0000,0.0000>,<0.7501,0.0000>,<0.7500,0.0000>,<0.7908,0.0102>,
  <0.8266,0.0408>,<0.8266,0.0918>,<0.7960,0.1530>,<0.7448,0.1938>,
  <0.6734,0.1938>,<0.5868,0.1734>,<0.4846,0.1836>,<0.4286,0.1734>,
  <0.4030,0.1326>,<0.3520,0.1020>,<0.2756,0.0816>,<0.2244,0.1122>,
  <0.1990,0.1734>,<0.1480,0.2756>,<0.1276,0.4286>,<0.1122,0.6836>,
  <0.0920,1.0000>,<0.0920,1.1836>,<0.0970,1.2654>,<0.1224,1.1530>,
  <0.1428,1.1224>,<0.1990,1.0714>,<0.2756,1.0408>,<0.3776,1.0612>,
  <0.4488,1.1020>,<0.5154,1.2040>,<0.5460,1.3674>,<0.5106,1.5200>,
  <0.4494,1.5716>,<0.3780,1.6024>,<0.3522,1.6134>,<0.3060,1.6236>,
  <0.2644,1.6340>,<0.1480,1.6444>,<0.0714,1.6546>,<0.0102,1.6656>
  sturm hollow }
#declare DD=.125  //emission and absorption multiplier
#declare D=3  //densities multiplier
//the blast cloud
#declare Nuke =
union {
  object { Shroom pigment{rgbf 1}  //capable of shadow
    interior {
      media {
       absorption <.4,.5,.6>*.75*DD
       emission rgb <.6,.5,.4>*.33*DD
        scattering { 2, rgb <1,.9,.8>*.125*DD extinction .1 }
         density { spherical frequency 4 color_map { [.1 rgb
<.5,.35,.25>*2*D][.5 rgb <1,1,1>*2*D] }
           scale 1
            warp { turbulence .6 lambda 2 omega 1.0 octaves 4 }
            rotate 0*-y translate 3*y
          } // end of density
         density { cylindrical frequency 2 color_map { [.3 rgb
<1.5,1.25,1.25>*3*D][.6 rgb <.15,.1,.125>*6*D] }
           scale .15
            warp { turbulence .9 lambda 2 omega 1.0 octaves 4 }
            rotate 0*-y //translate 2*z
          } // end of density
         density { gradient y frequency -2 color_map { [.3 rgb
<1.25,1.25,1.5>*.5*D][.6 rgb <.125,.1,.15>*1.5*D] }
           scale 3
            rotate 0*-y translate -3*y
          } // end of density
         intervals 6
           samples 1, 1
          variance 0.1
        confidence 0.9
       } // end of media
      media {
       absorption <.4,.5,.6>*1*DD
       //emission rgb <.6,.5,.4>*.25*DD
        //scattering { 2, rgb <1,.9,.8>*.125*DD extinction .1 }
         density { spherical frequency -4 color_map { [.1 rgb
           scale .1
          } // end of density
         density { cylindrical frequency -2 color_map { [.3 rgb
           scale .015
          } // end of density
         density { gradient y frequency 2 color_map { [.3 rgb
           scale .3
          } // end of density
         intervals 3
           samples 1, 1
          variance 0.1
        confidence 0.9
       } // end of media
      } // end of interior
     scale 3
   // rotate y*120
  } // end of object
#declare DD2=.25  //emission and absorption multiplier
#declare D2=2.25  //densities multiplier
//interior //not used
  object { Shroom pigment{rgbt 1}
    interior {
      media {
       absorption <.3,.5,.7>*.75*DD2
       emission rgb <.7,.55,.45>*.25*DD2
        scattering { 3, rgb <1,.9,.8>*.125*DD2 extinction .2 }
<.5,.5,.5>*2*D2][.5 rgb <1,1,1>*2*D2] }
           scale 1
          } // end of density
<1.5,1.5,1.5>*3*D2][.6 rgb <.1,.1,.1>*6*D2] }
           scale .15
          } // end of density
<1.5,1.5,1.5>*.5*D2][.6 rgb <.1,.1,.1>*1.5*D2] }
           scale 3
          } // end of density
         intervals 2
           samples 1, 4
          variance 0.01
        confidence 0.9
      } // end of media
      fade_distance 2 fade_power 1
     scale <2.9,2.9,2.9>
   // rotate y*120
  } // end of object
//internal light
light_source {<0,4,0> color rgb <1.5,1.45,1.4>*.66
	area_light <3,0,0>,<0,0,3>,3,3 jitter adaptive 0
	fade_distance 4 fade_power 2
	media_attenuation on
light_source {<0,5,0> color rgb <1.5,1.25,1.2>*.5
	//area_light <3,0,0>,<0,0,3>,3,3 jitter adaptive 0
	spotlight point_at 0 radius 15 falloff 30 tightness 1
	fade_distance 3 fade_power 3
//air cloud
torus {4,1 hollow scale <1,.25,1>
		pigment {spherical frequency 2.9 //rgbt 1}}
			color_map {
				[0 color rgbf 1]
				[.4 color rgbf <1.1,1,1,.7>]
				[.7 color rgbf <1.05,1,1,.4>]
				[1 color rgbf <1,1,1,.9>]
		} scale 5.05 } finish {ambient .66 diffuse 1 phong .1 phong_size 10}
     translate 5*y
//ground cloud
difference {
torus {4,.5 hollow scale <1,.75,1>}
torus {4,.5 scale <.9,1,.9> translate .25*y}
		pigment {spherical frequency 2.9 turbulence .1 lambda 2 omega 1 //rgbt
1}}
			color_map {
				[0 color rgbf 1]
				[.4 color rgbf <1,.9,.95,.8>]
				[.7 color rgbf <1,.925,.9,.6>]
				[1 color rgbf <1,1,1,1>]
		} scale 5.05 } finish {ambient .75 diffuse 1}
   scale <.95,.33,.95> rotate -3*x translate .125*y
//shockwave
difference {
		pigment {spherical frequency 2.9 turbulence .02 lambda 1.75 omega 1.5
//rgbt 1}}
			color_map {
				[0 color rgbf 1]
				[.6 color rgbf <1,.925,.95,.85>]
				[.7 color rgbf <1,.95,.975,.65>]
				[1 color rgbf <1,1,1,.95>]
	interior {ior 1.01}
   scale <.95,.125,.95>*1.75 rotate -3*x translate .125*y
}  //end union
Nuke  //the main blast cloud
//END
Date: 20 Apr 1999 09:17:50
Message: <371c706e.0@news.povray.org>
Bob Hughes wrote in message <371C533D.B0F28C62@aol.com>...
>of good use.
You can make turbulent objects with the Isosurface patch, provided you have
the equation for the object you want to make turbulent. The torus equation
should be there. If not, it's really quite simple - but I don't know it by
heart.
The turbulence function is called noise3d and has to be added to the object
equation.
Margus
Date: 20 Apr 1999 11:18:58
Message: <371C8CCC.90C600B3@pacbell.net>
> Marc
> Marc Schimmler
  I have little to argue with your statements and did not mean to imply
that a mushroom cloud would be absent in a modern weapon. Quite contrary
to that I would think the effeciency of the modern versions would create
a more unifom shape than the earlier types. The majority of nukes in the
modern US arsenal are no where near as radioactive as the earlier types
due to the effeciency at which they consume the radioactive isotopes
during detonation.
  My father worked in the military aerospace and weapons industry his
whole life and there were a couple of underground tests that he was
invoved with. His presence was needed to set up and monitor special
blast hardened electronics equipment that was exposed to the shock
wave of the blast.
  He mentioned one time that they were allowed back into the tunnels
within two hours of the blast to retrive their equipment and needed
no protective equipment to do so. The delay was needed so the surfaces
of the tunnels could cool enough to be entered. He also mentioned that
while it was safe to go in afterwards, the equipment that they went to
retrieve had fused itself into the rock floor of the tunnel. They were
forced to use pry bars to remove it from the rock as a good 1/4 inch
or so of the rock surface had turned into a glass carbonaceous like
substance. Anyway knowing that they can control the radioactive after
effects to that high degree of precision I see no reason that they
can't design them to have a nice, pretty, and well behaved mushroom
cloud too.
Ken Tyler
Date: 20 Apr 1999 11:32:06
Message: <371C8FE3.B6B52F09@ica.uni-stuttgart.de>
> during detonation.
> wave of the blast.
> cloud too.
I think the beauty of the cloud has never been a primary development
target! :-)
The behaviour of the cloud depends on so many factors like the
environment under the blast area or in the case of ground fusing the
shape of the surroundings that the design of the weapon is only
secondary.
Well I hope that I never have the chance to see this kind of clound in
real. For the simulation your cloud is more than sufficient! <g>
Marc Schimmler
Date: 20 Apr 1999 19:58:02
Message: <371D07D1.E2C4CCC9@home.com>
> >of good use.
> heart.
> equation.
Could you or someone else give me the home page url for the isosurface patch?
> Margus
Date: 20 Apr 1999 20:01:54
Message: <371D08BA.11B4A515@home.com>
I am in no way pro nuclear weapons just the opposite I think they are horrible
but still it would be quite the experience of a life time to witness an above
ground nuclear blast. At a safe distance of course :-)
> > during detonation.
> > wave of the blast.
> > cloud too.
> target! :-)
> secondary.
> Marc Schimmler
