POV-Ray : Newsgroups : povray.binaries.images : Updated electric guitar Server Time
7 May 2026 17:17:51 EDT (-0400)
  Updated electric guitar (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Updated electric guitar
Date: 12 Apr 1999 03:48:52
Message: <37119504.665761C6@pacbell.net>
Bob Hughes wrote:
> I like it a lot.
> You need to try a larger depth (+R) for the antialiasing to get those
> strings to turn out better though. Speaking of strings... did you
> texture (or model) them with the ridges (forgive me, I'm music
> illiterate) in the lower note strings.
Why neither method was used. This is so realistic looking, that he was
able to go down to the music store and buy strings for it, then came
back and reached into the screen and installed them in place. Reality
in a virtual sense.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 12 Apr 1999 11:39:45
Message: <371203E6.8DB088DF@ndirect.co.uk>
This is looking really good.
One thing that is still missing is something for the strap to
hook onto.
Steve
Fabien Mosen wrote:
> Here's an updated version of my electric guitar model.
> The neck is thinner (thus, easier to play), but the junction
> between the neck and the head is still not very good (it's hardly
> CSG-able).  The bridge (no tremolo) is much more detailed,
> and now placed at the right distance (distance between nutshell
> and 12th fret is equal to distance between 12th fret and bridge).
> Knots are a little more ineresting too.  The body received some kind
> of feline 2-tones sunburst finish.
> For those who asked how I made the chamfered body, I used 2 macros
> that makes "beveled" pie-parts and negative pie-parts (bended towards
> the outside, I can't explain better (no, really, I can't ;)).
> #macro BevelPie(Center,Height,Rad,AngFromX,AngTot,Bevel,Hole)
> intersection {
> union {
>   cylinder {<0,0,0>,<0,Height,>,Rad-Bevel}
>   cylinder {<0,0׫,0>,<0,Height-Bevel,>,Rad}
>   torus {Rad-Bevel Bevel translate y*Bevel}
>   torus {Rad-Bevel Bevel translate y*(Height-Bevel)}
> plane {z,0 rotate y*AngFromX}
> plane {z,0 inverse rotate y*(AngFromXɸᎢ)}
> cylinder {<0,-.01,0>,<0,Height.01,0>,Hole.01 inverse}
> translate Center
> #end
> #macro BevelPieNeg (Center,Height,Rad,AngFromX,AngTot,Bevel,Hole)
> intersection {
> union {
>   difference {
>         cylinder {<0,Bevel,0>,<0,Height-Bevel,0>,Radẉ}
>         cylinder {<0,0,0>,<0,Height,0>,Rad}
>   difference {
>         cylinder {<0,0,0>,<0,Height,0>,Radẉ}
>         cylinder {<0,0-1,0>,<0,Height,0>,Rad׫}
>   torus {Rad׫ Bevel translate y*Bevel}
>   torus {Rad׫ Bevel translate y*(Height-Bevel)}
> translate Center
> #end
Date: 12 Apr 1999 14:03:22
Message: <371226A9.94A6E898@ida.utb.hb.se>
I would never play this guitar, for three reasons:
- It's a 21 fret neck. (I hate to bend a minor 3:rd to reach that high E
when soloing over a E minor progression)
- The cut-away is made on the wrong side for a right-handed player (i.e,
me.). Makes it even harder to reach that high E.
- No humbuckers. I can live with single-coil, but only if they are Seymor
Duncan pickups (or EMG) with high output. Just to let you know.
-  Mikael (equally lousy guitar player and programmer)
Mikael Carneholm
Dep. of Computer Science
http://www.studenter.hb.se/~arch
E-mail: sa9### [at] idautbhbse
Download 'us-ascii' (1 KB)
Date: 12 Apr 1999 15:57:47
Message: <37124203.EC5706BF@compuserve.com>
> - It's a 21 fret neck. (I hate to bend a minor 3:rd to reach that > high E
21 frets, like my Strat 57 reissue; there's much fine music to play
between fret 1 and 21, you know...
(and about that E, just use harmonics...)
Makes it easier to reach the lower strings with the thumb.  Anyway,
there is fine music to play between frets 1 and 17...
Ever heard about _stacked_ humbuckers ?  They looks (and mount)
the same as single coils, and avoid the _ugly_ appearance of
these big humbuckers...
Cheers,
Fabien.
Date: 12 Apr 1999 18:53:23
Message: <37126C8C.1B433EB@home.com>
I really your guitar, especially how you were able to get that nice beveled
edge! Now I know nothing about electric guitars so if what I am saying sounds
completely insane just ignore it, but isn't an "electric" guitar supposed to
have an output jack somewhere on it to hook it up to an amplifier?
> intersection {
> union {
>   cylinder {<0,0+Bevel,0>,<0,Height-Bevel,>,Rad}
> plane {z,0 inverse rotate y*(AngFromX+AngTot)}
> cylinder {<0,-.01,0>,<0,Height+.01,0>,Hole+.01 inverse}
> translate Center
> #end
> intersection {
> union {
>   difference {
>         cylinder {<0,Bevel,0>,<0,Height-Bevel,0>,Rad+Hole}
>   difference {
>         cylinder {<0,0,0>,<0,Height,0>,Rad+Hole}
>         cylinder {<0,0-1,0>,<0,Height+1,0>,Rad+Bevel}
>   torus {Rad+Bevel Bevel translate y*Bevel}
>   torus {Rad+Bevel Bevel translate y*(Height-Bevel)}
> translate Center
> #end
Date: 12 Apr 1999 19:37:24
Message: <37126FC1.8D02C98F@ndirect.co.uk>
I think that the output point on this model would probably be on
the edge of the guitar on the side that ce can't see.
Steve
> > intersection {
> > union {
> >   cylinder {<0,0+Bes-,0>,<0,Height-Bevel,>,Rad}
> > plane {z,0 inverse rotate y*(AngFromX+AngTog-)}
> > translate Center
> > #end
> > intersection {
> > union {
> >   difference {
> >         cylinder {<0,Bevel,0>,<0,Height-Bevel,0>,Rad+Hok-}
> >   difference {
> >         cylinder {<0,0,0>,<0,Height,0>,Rad+Hok-}
> >         cylinder {<0,0-1,0>,<0,Height,0>,Rad+Bes-}
> >   torus {Rad+Bes- Bevel translate y*Bevel}
> >   torus {Rad+Bes- Bevel translate y*(Height-Bevel)}
> > translate Center
> > #end
> >  [Image]
Date: 13 Apr 1999 10:29:27
Message: <3713461B.800CE83@ida.utb.hb.se>
Hi Fabien;
I am sorry, I just wanted to surprise people by showing that I know something about
electric guitars (and also indicate that I <used to> play some before realised that
I was too mathematically minded too actually _make_music_ ).
It's a great image, and I even thought I could help by indicating that the body
should be rotated 180 degrees to be playable for a right-handed player (since the
neck is a right-handed neck).
Once again: good modelling/texturing!
- Mikael.
Mikael Carneholm
Date: 13 Apr 1999 19:27:26
Message: <3713C634.90C65598@tiac.net>
I had a piano teacher once who was also a math teacher, and he
maintained that music is most closely related to math...
Certainly music is made of patterns that are expressed as fractions ie.
a 3rd above the root, or a quarter note, half note etc.
Date: 13 Apr 1999 20:27:47
Message: <3713D1F0.E08500C9@ecs.soton.ac.uk>
You ever read the Douglas Adams' (Hitch-Hiker's Guide) novel 'Dirk
Gently's Holistic Detective Agency?' It's got some great ideas about
fractal music - making music out of numbers the way fractal pictures are
generated.
Yeah, my POV-Ray guitar (work in progress... slowly) uses the same
algorithm for calculating fret distances as the two real guitars I've
built  - although with the amount of time I have spare ATM (or rather
the lack of it...) the POV-Ray guitar's going to take longer than the
real one did... :)
Cheers,
D.
Dylan Beattie          dmb### [at] ecssotonacuknospam
Pt II Computer Science,    University of Southampton
http://www.ecs.soton.ac.uk/~dmb197/     ICQ:34865704
Date: 13 Apr 1999 20:53:21
Message: <3713DA51.2495C137@tiac.net>
>built  -
I tried building my own guitar back in high school shop class. I didn't
do that great a job but I learned a lot in the process. The neck is
toughest
part.
