POV-Ray : Newsgroups : povray.binaries.images : Realism Test Server Time
7 May 2026 17:19:28 EDT (-0400)
  Realism Test (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Realism Test
Date: 11 Apr 1999 01:13:47
Message: <3710224D.3041B88C@geocities.com>
The problem has shown up in the past and it does not seem to be
resticted to .png output. I've attached all of the associated files.
Ken wrote:
> Chris Maryan wrote:
> > BTW: Anyone know why the background is patchy in the attached .png? It
> > seems to happen very often in my images.
> I have never seen that behaviour before in 4 years of using the program.
> I also have not used the .png file output option and it might be related
> to that. Another possibility is with all of the default setting that moray
> has a tendancy to set for you. I use the standard pov defaults except
> in very rare cases as they keep consistancy from scene to scene.
>   I would like to try rendering your code and see if it manifests itself
> on my system with tga output. If you provide the rest of the scene file
> you used such as camera and lighting I will check to see if I can reproduce
> it and will get back to you with the results. Also If you have moray created
> ini file I would like to see what's in that as well.
> Ken Tyler
Chris Maryan
mailto:cma### [at] geocitiescom
Will work for cash.
Email me if you are interested in donating
to the Chris Maryan needs money fund.
We will also accept donations to the Chris
needs a Pentium III or SGI workstation
fund and the Chris needs a car fund.
Download 'trial_1.ini.txt' (2 KB) Download 'trial_1.pov.txt' (3 KB) Download 'us-ascii' (2 KB) Download 'trial_1.mdl.dat' (3 KB)
Date: 11 Apr 1999 02:30:32
Message: <37103353.C9B62FEF@usb.ve>
Chris Maryan wrote:
> Camera settings are not where realism fails in most images, neither is
> radiosity or lighting. I have followed almost every image posted here
> and in the IRTC and the one thing that always bothers me is textures. If
I agree with you
> you want to improve realism, consider spending time on getting the
> phong/specular highlights, the diffuse and ambient settings right. For
> example, in your image, you might consider playing around with the
> settings to improve the depth shown by the shading, your spheres look
> rather flat. This would probably be best remedied by decreasing the
> ambient. Also consider increasing the brightness of the highlights in
> your textures. Everything else falls into place naturally once you have
> the textures looking right. What you have is an excellent start, keep up
> the good work.
Don't forget brilliance for a very final touch.
Date: 11 Apr 1999 04:00:06
Message: <371046EE.84D6D0CC@pacbell.net>
 Chris,
 I am happy (sad ?) to report that regardless of what I tried I could
not repeat the blotchy pattern that you are seeing when rendering the
same scene. I tried it with the included .ini file, with different
output image file formats, turned radiosity on and off, tried it
with the .ini file and the global settings commented out, several
combinations with and without AA, with the global settings used but
no ini file, and with both the global settings and the .ini file not
used. I basically ran out of possible combinations to try to reproduce
the blotchy appearance but failed at every attempt.
  The only thing I can think of that I did try, but failed because
I have an older version, is to render the file while inside Moray
itself. There might be a bug in the way that Moray is working with
Pov as an external rendering process. You did not mention if this
behaviour manifests itself when you render directly within Pov and
have Moray shut down but I suspect you like most Moray users seldom
use Pov as a stand alone program.
 I would suggest we get another Moray user to try the .mdl file and
see if they can reproduce the same problem you are seeing. If they
can duplicate the problem it's time to talk to Lutz about how to
correct this abhorrent behaviour you are observing.
  You might try to render it directly in Pov to see if the output
is the same. If you can't reproduce it directly in Pov but it comes
back in Moray it is something to get worried about.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 11 Apr 1999 04:00:25
Message: <371049BB.3CF0CDD9@home.com>
Perhaps this is related to the problem I was having with the degradation of my JPEG
images when
they were posted. I know this this has to do with the way Netscape displays image.
> > Ken Tyler
> Chris Maryan
> Will work for cash.
>    trial_1.INI    Type: INI File (application/x-unknown-content-type-*inifile)
>               Encoding: base64
>    trial_1.pov    Type: POV-Ray scene file
(application/x-unknown-content-type-POV-Ray.Scene)
>               Encoding: base64
> //  Texture Include file.
> //  This file was generated for POV-Ray V3.1 by
> //  NOTE: Do *NOT* remove the comment lines containing '$MRY$'.
> //        To make Moray not re-export the texture, change
> //        the '$MRY$' to '$MRX$'.
> // ********  TEXTURES  *******
> // Textures from previous exports [MRY]
> // Textures exported in this run [MRY]
> //  $MRY$: 'T_Wood10'
> #declare _auto_name_no_1_ =
>    texture  // txt_84
>       pigment
>          wood
>          color_map
>             [ 0.0     rgbft <1.0, 0.85, 0.5, 0.0, 0.0> ]
>             [ 0.5     rgbft <0.9, 0.7, 0.46, 0.0, 0.0> ]
>             [ 0.7     rgbft <0.9, 0.7, 0.46, 0.0, 0.0> ]
>             [ 1.0     rgbft <1.0, 0.85, 0.5, 0.0, 0.0> ]
>          turbulence 0.02
>          octaves 4
>          lambda 3.0
>          ramp_wave
>          scale  0.175
>          rotate    <2.0, 2.0, 0.0>
>       finish
>          ambient 0.3066
>          phong_size 0.0
>          specular 0.155633
>          roughness 0.014533
>    texture  // txt_85
>       pigment
>          wood
>          color_map
>             [ 0.0     rgbft <1.0, 0.45, 0.1, 0.8, 0.0> ]
>             [ 0.5     rgbft <0.85, 0.65, 0.4, 0.4, 0.0> ]
>             [ 0.7     rgbft <0.85, 0.65, 0.4, 0.4, 0.0> ]
>             [ 1.0     rgbft <1.0, 0.45, 0.1, 0.8, 0.0> ]
>          turbulence 0.02
>          octaves 4
>          lambda 2.8
>          ramp_wave
>          scale  <0.2, 0.2, 0.2>
>          translate    <0.0175, 0.0175, 0.0175>
> #declare T_Wood10 =
>    material  // T_Wood10
>       texture { _auto_name_no_1_ }
> //  $MRY$: 'Material1'
> #declare Material1 =
>    material  // Material1
>       texture
>          pigment
>             checker
>                color rgb <0.9, 0.9, 0.9>
>                color rgb <0.1, 0.1, 0.1>
>          finish
>             ambient 0.301867
>    trial_1.mdl    Type: MorayW Document
(application/x-unknown-content-type-MorayWin.Document)
>               Encoding: base64
Date: 11 Apr 1999 04:03:09
Message: <37104A5F.D1E9DA52@home.com>
I would be willing to try and render the image out of Moray. Just post the
mdl in moray.binaries.
>  Chris,
> Ken Tyler
Date: 11 Apr 1999 04:05:50
Message: <37104844.DEC7E6E@pacbell.net>
The .mdl is at the bottom of Chris's last message ( the one I responded to).
Ken Tyler
Date: 11 Apr 1999 04:08:14
Message: <37104B90.495A6B0D@home.com>
Ah yes there it is, my eyes must be going or something. Maybe raytracing too
long.
> Ken Tyler
Date: 11 Apr 1999 04:33:09
Message: <37105163.BDF33F51@home.com>
I downloaded the moray mdl file and tried rendering it on my computer but like
Ken I to could not reproduce this effect. I also tried playing around with the
rendering settings in moray without being able to reproduce it. Perhaps if you
posted the exact settings you used to render the image, including the
radiocity settings.
Chris Maryan wrote:
> Slight improvement with the brightness. I think your diffuse and
> brilliance might be too high, try the default settings of 0.6 and 1.0
> respectively, as for ambient, I find the default of 0.1 to be
> unrealistically low for typical situations, try 0.2-0.3. One of the
> problems seems to be the contrast between the bright and dark parts of
> the image, raising the ambient should fix this. In the example below, a
> subtle highlight really helps the texture (after all, most wood surfaces
> have some degree of polish), look at the specular and roughness
> settings.
> I fiddled around with something similar and came up with the attached
> code. Sorry, jpg, just png, I all my conversion programs seem to be
> crashing lately. Mine might be a little too dark. This is the code for
> the wood (based on one of the textures in the Moray library, I added the
> finish settings):
>    texture  // txt_84
>       pigment
>          wood
>          color_map
>          turbulence 0.02
>          octaves 4
>          lambda 3.0
>          ramp_wave
>          scale  0.175
>       finish
>          ambient 0.3066
>          phong_size 0.0
>          specular 0.155633
>          roughness 0.014533
>    texture  // txt_85
>       pigment
>          wood
>          color_map
>          turbulence 0.02
>          octaves 4
>          lambda 2.8
>          ramp_wave
> Chris Maryan
> Will work for cash.
Date: 11 Apr 1999 09:40:44
Message: <37109862.38E97B5B@compuserve.com>
Your default texture has a normal of bumps 0.3, and this is not overridden in
your plane texture. The splotches are caused by this normal. I would remove this
default texture statement, or remove the normal from it.
> > Ken Tyler
> Chris Maryan
> Will work for cash.
>    trial_1.INI    Type: application/x-unknown-content-type-inifile
>               Encoding: base64
>    trial_1.pov    Type: application/x-unknown-content-type-POV-Ray.Scene
>               Encoding: base64
>    texture  // txt_84
>       pigment
>          wood
>          color_map
>          turbulence 0.02
>          octaves 4
>          lambda 3.0
>          ramp_wave
>          scale  0.175
>       finish
>          ambient 0.3066
>          phong_size 0.0
>          specular 0.155633
>          roughness 0.014533
>    texture  // txt_85
>       pigment
>          wood
>          color_map
>          turbulence 0.02
>          octaves 4
>          lambda 2.8
>          ramp_wave
> #declare T_Wood10 =
>       texture
>          pigment
>             checker
>          finish
>             ambient 0.301867
>    trial_1.mdl    Type: application/x-unknown-content-type-MorayWin.Document
>               Encoding: base64
Date: 11 Apr 1999 14:45:47
Message: <3710E078.98351411@geocities.com>
Default texture? Bumps? That would definately explain things but where
is this default texture declared? Also, why doesn't it show up in the
renderings from the polyray plugin for Moray (does polyray even support
bump maps)?
Chris Maryan
Will work for cash.
