POV-Ray : Newsgroups : povray.binaries.images : Music Server Time
16 Jun 2026 20:27:43 EDT (-0400)
  Music (Message 11 to 15 of 15)
Subject: Re: Music
Date: 9 Apr 1999 18:15:38
Message: <370E69CC.CA7C8B94@ndirect.co.uk>
I used to play the Clarinet and am English, but don't know the
names of any of the parts that you mentioned either, and the
clarinet has those parts too.
Steve
PS: Maybe that cork bit and the bit that rests on your thumb
don't have names.
Spider wrote:
> Ok, I'll pick up the image and commpare to my sax.
> First, I don't know what sort of saxophone you are trying to build here, but I
> assume it is and alto (compared to the viola and the horn)
> 1)
> at the bottom, it feels very "cruched" or something, not the smoothness (may be
> the light/shadows)
> 2)
> There is a *cursing his bad english* "thing" for the thumb that should be
> visible.
> 3)
> A cork piece where the *cursing his bad english* (don't know the english name)
> mouthpiece(?) is connected to the sax.
> 4)
> Too wide angle at the end.
> 5)
> Pull the end upwards a bit. it goes to about 1/2 the instruments lenghth
> 6)
> Put it closer to the sax as well
> 7)
> No way to control the instrument. Finger placing is where?
> 8)
> I don't have a way to show you the delicate linage of the controlling parts.
> sorry.
> Thomas Lake wrote:
> > Spider wrote:
> > > Let me say this.. I play the saxophone, and that instrument you have there looks
> > > good, if it is further from the camera... same goes for that horn...
> > > the level of detail is too bad(My opinion)
> > What do you mean by this? First I don't play any musical instruments so there are
bound
> > to be a few mistakes that a person who is aquatinted with the instrument will pick
up
> > but I thought that I modeled quite accurate instruments. Perhaps if you could tell
me
> > exactly what is missing? I'm not finished so I will be adding more things to the
Music
> > Store, more instruments, if this is what you mean.
> > > Sorry, but I had to point it out here.
> > > Thomas Lake wrote:
> > > > I have been working on this image for the past couple of days now. Its
> > > > not finished yet, still quite a lot of work to do. But I thought, why
> > > > not post it. A few things I should mension. The weird pattern on the red
> > > > bezier patch is supposed to make it look rippled but didn't turn out
> > > > quite right. The interments were modeled in Rhino then exported to
> > > > Moray.
> > > >  [Image]
> > > //Spider
> > >         [ spi### [at] bahnhofse ]-[ http://www.bahnhof.se/+AH4-spider/ ]
> > > What I can do and what I could do, I just don't know anymore
> > >                 "Marian"
> > >         By: "Sisters Of Mercy"
> //Spider
>                 "Marian"
Subject: Re: Music
Date: 9 Apr 1999 20:53:42
Message: <370E91BA.DB2963DC@pacbell.net>
> Cheers
> Steve
> don't have names.
 I'm not sure what you guy's are refering to in regards to the "thumb"
part but I suspect you are referring to the finger rests (trumpet talk}.
Thumb rest for sax talk ? The cork is simply referred to as a gasket or
mouth piece gasket. Other parts a finger or thumb might come in contact
with are valve levers, valve buttons, and spit valve release levers.
On the end of the sax it is referred to as the bell and not that horn
shaped thingy at the end of that curvy part.
Ken Tyler
mailto://tylereng@pacbell.net
Subject: Re: Music
Date: 9 Apr 1999 21:17:26
Message: <370E9462.F296D842@pacbell.net>
Yep, the cork is called a "gasket", the buttons where your fingers go are
called "keys", the round things that cover the holes are called "pads", the
part that holds the reed is a mouthpiece, the metal clamp that holds the
reed to the mouthpiece is a "ligature", the "neck" is a seperate piece that
connects the mouthpiece to the "body" and some call the "body" a "torso",
the horn thingy is really the "bell", the thumb thingy is a "thumb rest" and
the whole package is referred to as a "horn".
There you go, a little saxual anatomy    ;-]
> > Cheers
> > Steve
> > don't have names.
> Ken Tyler
Subject: Re: Music
Date: 10 Apr 1999 02:43:36
Message: <370EABF3.D14006DE@bahnhof.se>
Ok, thanx.
I knew all the nnames in swedish, but English... nope.
I think i'll save this for future referrence(in the paper-bin or some other
place where I know where it is ;-)
> > > Cheers
> > > Steve
> > > don't have names.
> > Ken Tyler
//Spider
                "Marian"
Subject: Re: Music
Date: 10 Apr 1999 11:49:55
Message: <370F6501.39B10ECD@ndirect.co.uk>
Thanks Ken, I'm glad someone is thinking clearly.
Steve
> Ken Tyler
