POV-Ray : Newsgroups : povray.binaries.images : Dune Buggies Revisited (71K - 1024x768) Server Time
29 Jun 2026 10:04:53 EDT (-0400)
  Dune Buggies Revisited (71K - 1024x768) (Message 1 to 10 of 14)
Subject: Dune Buggies Revisited (71K - 1024x768)
Date: 8 Mar 1999 20:09:43
Message: <36e474d7.0@news.povray.org>
I got to the point where I really started to hate the other picture I posted
(Subject: Dune Buggies), so I reworked a couple things.
Cman
Download 'buggyinsand.jpg' (72 KB)
Preview of image 'buggyinsand.jpg'
Subject: Re: Dune Buggies Revisited (71K - 1024x768)
Date: 8 Mar 1999 22:38:20
Message: <36E496F0.41AA8AE8@pacbell.net>
> Cman
  That is som very good modeling on the buggy bodies. The tires on the
 other hand. Ok I know that you know, I just wanted you to know, that
 I know you knew.
  I have a presnt for you. Those tires were bothering me so much that
 I hacked out a couple of possible solutions for you. The small image
 pretty much tells it all and the script is short so enjoy.
 Please have them installed before you post again.
   // This is the single scaled torus on the right
         torus{.8,.4 rotate 90*x scale<1,1,1.7>
       pigment{rgb .05}
        finish{ambient .3 specular .41}
               rotate 45*y
               translate x*2.3
  // This is the single scaled and intersected fat slick
  // tire on the left
  intersection{
         torus{.76,.4 rotate 90*x scale<1,1,1.7>}
      cylinder{z*-1,z*1,1 open }
       pigment{rgb .05}
               rotate 45*-y
               translate x*-2.3
  // This is the CSG'd, front wheel type, treaded tire in the middle
  // and laying down in front
  #declare Tire_With_Tread =
  difference  {
  intersection{
         torus{.45,.3 rotate 90*x scale<1,1,1.4>}
      cylinder{ z*-1,z*1,.65 open}
    difference{
         union{
      cylinder{z*-.007,z*.007,.69 translate z*-.250}
      cylinder{z*-.007,z*.007,.69 translate z*-.150}
      cylinder{z*-.007,z*.007,.69 translate z*-.075}
      cylinder{z*-.007,z*.007,.69 translate z*    0}
      cylinder{z*-.007,z*.007,.69 translate z* .075}
      cylinder{z*-.007,z*.007,.69 translate z* .150}
      cylinder{z*-.007,z*.007,.69 translate z* .250}
      cylinder{z*-.1,z*.1,.63 }
  intersection{
         torus{.4,.27 rotate 90*x scale<1,1,1.4>}
      cylinder{z*-1,z*1,.5 open}
      cylinder{z*-1,z*1,.3 }
       pigment{rgb .05}
  object{Tire_With_Tread scale<1.2,1.2,.75>rotate 65*y translate z*-1.5
  finish{ambient .3 specular 1}}
  object{Tire_With_Tread scale<1.2,1.2,.50>rotate 95*x translate<.25,-.75,-3>
  finish{ambient .3 specular .64}}
Ken Tyler
mailto://tylereng@pacbell.net
Download 'tires.jpg' (9 KB)
Preview of image 'tires.jpg'
Date: 9 Mar 1999 00:36:25
Message: <36e4b359.0@news.povray.org>
Now, no disrespect to your tires Ken, but I think for the dune buggies he'd
be looking for some more rugged type tires, whereas yours look more like
something to be used on highways and in cities.  Here's about 20 minutes of
fooling around with toruses.  Some tweaking is necessary to make them look
just how you want'em, but i think something along these lines (with some
decent texture) would work well.
code attached.
Mike Metheny
lon### [at] vtedu
http://loneshepherd.ml.org/
"When one's words are no better than silence, one should keep silent."
Download 'tire.jpg' (20 KB) Download 'tire.pov.txt' (1 KB)
Preview of image 'tire.jpg'
Date: 9 Mar 1999 03:49:37
Message: <36E4E06B.2D3A2612@aol.com>
I like all the tires. However... I believe he mentioned a track. So
could be paved, or could be dirt. Either way, how can he lose now?
> code attached.
> Mike Metheny
> lon### [at] vtedu
> #include "colors.inc"
> #include "stones.inc"
> camera{location <5,15,-20>
>        look_at<0,0,0>
> light_source{<1000,1000,-1000> White}
> sky_sphere
>   pigment
>     gradient y
>     color_map { [0.0 color rgb <0.7,0.7,1.0>] [1.0 color blue 0.5] }
> #declare base = torus{5,2scale <1,1.1,1>}
> #declare halft =
> difference{
> torus{2,.5 rotate 90*x scale 1.3*x}
> box{<-5,-5,-5><0,5,5>}
> #declare tire=
> difference{
> object{base pigment{Gray50}}
> #declare i=1;
> #while(i<25)
> object{halft pigment{Gray60} rotate 25*x translate<5.1,0,0> rotate 15*i*y}
> #declare i=i+1;
> #end
> object{tire rotate <90 90,0> translate <-6,0,3>}
> object{tire rotate <90 90,0> translate <6,0,3>}
> object{tire rotate <90 90,0> translate <-6,0,25>}
> object{tire rotate <90 90,0> translate <6,0,25>}
 mailto:inv### [at] aolcom?PoV
Date: 9 Mar 1999 04:22:19
Message: <36E4E6ED.96CBA0A5@aol.com>
If you're going to be out in the desert, you want something to give you
more traction on the dunes (and any hostiles you may encounter). :)
camera {location <0, 4, -10> look_at <0, 2, 2>}
light_source {<10, 15, -30> color White}
background {color White}
#declare evil_tire =
difference {
union {
superellipsoid {<1, .3>
rotate 90*x
scale <2, 1, 2>
pigment {color rgb <.1, .1, .1>}
finish {phong .5 phong_size 30 ambient 0 diffuse .8}
normal {gradient y scallop_wave bump_size 1 scale .3}
#declare tread = union {
#declare this = 0
#while (this < 360)
cone {<1, 0, 0>, .2, <3, 0, 0>, 0
rotate <0, this, 0>
#declare this = this + 22.5
#declare that = 0
#while (that < 1.5)
object {tread
rotate that*15*y
translate (-.7+that)*y
pigment {color rgb <.5, .5, .5>}
finish {ambient 0 phong 1 phong_size 20}
#declare that = that + .2
cylinder {<0, -3, 0>, <0, 3, 0>, 1.5}
pigment {color White}
finish {phong 1 phong_size 20 diffuse .6 ambient .1}
object {evil_tire}
object {evil_tire rotate <90, -30, 0> translate <-6, 3, 5>}
object {evil_tire rotate <90, 40, 0> translate <5, 4, 3>}
object {evil_tire rotate <90, 60, 0> translate <-2, 2, 6>}
Download 'tire.jpg' (28 KB)
Date: 9 Mar 1999 04:29:32
Message: <36e4e9fc.0@news.povray.org>
<<If you're going to be out in the desert, you want something to give you
more traction on the dunes (and any hostiles you may encounter). :)>>
Ouchie!
Mike Metheny
lon### [at] vtedu
Date: 9 Mar 1999 19:14:32
Message: <36e5b968.0@news.povray.org>
Thanks for the tires guys!!!!
The ones from Ken would do good for the track, and the ones from Mike M
would be good for the sand!!!
If you haven't seen the ones from Mike, they are killer (pun intended)!
Cman
Bob Hughes wrote in message <36E4E06B.2D3A2612@aol.com>...
he'd
of
look
>> code attached.
>> Mike Metheny
>> lon### [at] vtedu
>>  [Image]
>>        look_at<0,0,0>
>> sky_sphere
>>   pigment
>>     gradient y
>> #declare halft =
>> difference{
>> #declare tire=
>> difference{
>> #declare i=1;
>> #while(i<25)
15*i*y}
>> #declare i=i+1;
>> #end
> omniVERSE: beyond the universe
>  http://members.aol.com/inversez/POVring.htm
Date: 9 Mar 1999 19:17:14
Message: <36e5ba0a.0@news.povray.org>
I remember some movie around 10+ years ago with trucks and cars that had
tires that were probably like that (as well as other weapons too!)
All I can say is if one of those blow out, watch out!!!
Cman
Mike wrote in message <36E4E6ED.96CBA0A5@aol.com>...
>difference {
>union {
>rotate 90*x
>scale <2, 1, 2>
>#declare this = 0
>#while (this < 360)
>rotate <0, this, 0>
>#end
>#declare that = 0
>#while (that < 1.5)
>object {tread
>rotate that*15*y
>#end
>object {evil_tire}
Date: 9 Mar 1999 19:25:26
Message: <36e5bbf6.0@news.povray.org>
Thanks a lot for the comments on the buggy modeling!  I sat down with a
peice of graph paper and used my drafting skills from college, and built
them based on some pics I found on the net.
I also know bout them tires, and by the time I got this pic to where it is,
I decided to let them go.  The buggies are eventually going on a race track
that I plan to animate.
Cman
Ken wrote in message <36E496F0.41AA8AE8@pacbell.net>...
posted
>> Cman
> I know you knew.
>       pigment{rgb .05}
>               rotate 45*y
>               translate x*2.3
>  // tire on the left
>  intersection{
>       pigment{rgb .05}
>               rotate 45*-y
>               translate x*-2.3
>  difference  {
>  intersection{
>    difference{
>         union{
>  intersection{
>       pigment{rgb .05}
>Ken Tyler
Date: 9 Mar 1999 20:45:34
Message: <36E5CDE3.F83D5ED@pacbell.net>
> Cman
  It was intended as a fun exersize in what can be done to a torus
to make it more tire like in appearance.  I was quite pleased with
the grooved tire version. I now need to work on a mehtod of adding
angles to the groove and variations in the cut of the tire. Still need
to add the GoodYear tire logos as well.
Ken Tyler
