POV-Ray : Newsgroups : povray.binaries.images : Molecular electron density using media Server Time
20 May 2026 23:36:26 EDT (-0400)
  Molecular electron density using media (Message 1 to 6 of 6)
Subject: Molecular electron density using media
Date: 7 Mar 1999 21:55:07
Message: <36e33c0b.0@news.povray.org>
Here's my first attempt at using media to render molecular electron density.
I have learned a new appreciation for the work SLOW in doing this rendering.
I'd like to ask all the media wizards, how can I get this to render much
faster than 20 minutes?  I've included the pov and df3 files in the attached
zip archive.  Any help would be greatly appreciated.  I need this to render
much faster for general application development and debugging purposes.
Once the application is done, rendering times of 20 minutes  would be no
problem.
Also, thanks to Stephen Lavedas and Ken Tyler for some help in figuring out
how to directly generate the df3 file from my isosurface rendering code.
Jim
Download 'oxide.jpg' (28 KB) Download 'testout_B.zip' (40 KB)
Preview of image 'oxide.jpg'
Subject: Re: Molecular electron density using media
Date: 7 Mar 1999 22:04:12
Message: <36e33e2c.0@news.povray.org>
Oh yeah, bet you didn't know molecules were furry, did you?
Jim
Date: 8 Mar 1999 01:01:26
Message: <36E36776.663C6A4F@aol.com>
I got 2 min 19 sec for a 160x120 res rendering as is.
I changed the variance to 1/100 and confidence to 0.9 and got a 38 sec.
render, or almost 1/4 the time.
Not much noticeable difference in appearance I think.
And dropping intervals and samples down is like lightning speed by
comparison if you are into the media grain sort of thing ;)
'intervals' is the major speed factor next to the minimum samples
number. As long as these two stay low, ie. intervals 5 samples
1,whatever then your okay. But you'll certainly have that peppered look!
Actually the samples maximum makes little difference in speed.
> problem.
> Jim
 mailto:inv### [at] aolcom?PoV
Date: 8 Mar 1999 11:27:31
Message: <36e3fa73.0@news.povray.org>
Thanks!
My 20 min was at 640x480 no aa.  Your hints should really help.
Jim
Check out my web site http://www.kressworks.com/
It'll blow your mind (politically), stimulate your senses (artistically)
and provide scientific insights beyond compare!
Be sure to read the Warp maintained POV VFAQ:
http://iki.fi/warp/povVFAQ.html
Bob Hughes wrote in message <36E36776.663C6A4F@aol.com>...
density.
rendering.
attached
render
>> problem.
out
>> Jim
> omniVERSE: beyond the universe
>  http://members.aol.com/inversez/POVring.htm
Date: 8 Mar 1999 13:01:08
Message: <36E410D3.DB7F1E17@virginia.edu>
What about using the other use of the df3 files?  You could test using
the surface properties (the other demo file, density.pov I think) the
render on that one was MUCH faster than galaxy.pov....
Steve
> problem.
> Jim
>    testout_B.zip    Type: Zip Compressed Data (application/x-zip-compressed)
>                 Encoding: x-uuencode
Date: 8 Mar 1999 17:04:40
Message: <36e44978.0@news.povray.org>
Hmmm ...  I didn't notice that one.  I'll give it a shot!
Thanks!
Jim
Stephen Lavedas wrote in message <36E410D3.DB7F1E17@virginia.edu>...
>Steve
density.
rendering.
attached
render
>> problem.
out
>> Jim
>>  [Image]
