POV-Ray : Newsgroups : povray.binaries.images : Dan's double density algorithm? (16kB) Server Time
21 May 2026 03:06:10 EDT (-0400)
  Dan's double density algorithm? (16kB) (Message 1 to 2 of 2)
Subject: Dan's double density algorithm? (16kB)
Date: 7 Feb 1999 17:50:14
Message: <36be18a6.0@news.povray.org>
In a separate post about flames and media, Dan gave advice for getting a
density of y(1-y) which is attached at the end.
I tried Dan's algorithm and I think that instead I got y^2.
My code is:
interior {
         media {
               emission rgb 1 //<0.75,0.75,0.75>
               intervals 30
               samples 10, 10
               confidence 0.9999
               variance 1/1000
               density {
                      gradient y
                      translate -y
               density {
                       gradient y
Applying this to an object at hand, attached below, I think that you can
see that it clearly looks like y^2, not y(1-y).
-------BEGIN QUOTE FROM DAN CONNELLY----------------
But I can explain densities.
Basically each density statment in series multiplies the net density by
its values.
So
density {
  gradient y
results in density, over the interval y from 0 to 1, equal to y.
But :
density {
  gradient y
density {
  gradient y
results in density, over the interval y from 0 to 1, equal to y^2.
(this would be better done using poly_wave 2)
And,
density {
  gradient y
  translate -y
density {
  gradient y
yields density of y (1 - y) over the same interval.
So "shaping" the media is a matter of using the densities which
apply the appropriate zero boundary conditions with the appropriate
transitions.
Dan
Download 'us-ascii' (4 KB)
Subject: Re: Dan's double density algorithm? (16kB)
Date: 7 Feb 1999 22:30:27
Message: <36BD08C1.97B10708@flash.net>
Whoops!  My fault.....
that should be "translate y", not "translate -y".
I made the classic mistake of translating the observer rather than the
field.... what I want is the interval from (-1,0) to be "boosted" to
(0,1), which requires a +1 translating.
Sorry...
Dan
"Greg M. Johnson" wrote:
> In a separate post about flames and media, Dan gave advice for getting a density of
> My code is:
> interior {
>          media {
>                intervals 30
>                samples 10, 10
>                confidence 0.9999
>                variance 1/1000
>                density {
>                       gradient y
>                       translate -y
>                density {
>                        gradient y
http://www.flash.net/~djconnel/
