POV-Ray : Newsgroups : povray.binaries.images : More pov icons (13 KB) Server Time
19 Jun 2026 15:40:30 EDT (-0400)
  More pov icons (13 KB) (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: More pov icons (13 KB)
Date: 30 Jan 1999 06:04:26
Message: <36b2e73a.0@news.povray.org>
Mike Metheny wrote:
>To view these one piece of shareware that will work is MicroAngelo, a set
of
>tools for creating, editing, and viewing icons.  As to where to d-load, hey
>you can search on HotBot or ask Ken as easy as I can :>
... or have a look at IconS: http://nmsf.sscc.ru/neuro/freeware.html
its just a little (Windows) freeware for extracting icons from all
kind of icon-holding file format.
Just my two rappen.
        - Marco
Date: 30 Jan 1999 09:51:52
Message: <36B31B70.202CA8E2@bahnhof.se>
Microangelo :
Version 2.1 (All time fav.) : http://floach.pimpin.net/utils/ma21.zip
And then the homepage : http://www.impactsoft.com
beat ya to it ;-)
//Spider
Mike Metheny wrote:
> To view these one piece of shareware that will work is MicroAngelo, a set of
> Mike Metheny
> lon### [at] vtedu
> http://loneshepherd.ml.org/
> "When one's words are no better than silence, one should keep silent."
Date: 30 Jan 1999 12:14:24
Message: <36b33df0.0@news.povray.org>
GrimDude wrote in message <36b27548.0@news.povray.org>...
>Wow! After that introduction I was looking forward to seeing your work! :)
>Unfortunately, for some reason I don't have anyway to view them? :(
For Win95 users, right click on any desktop icon, select properties, then
hit the "change icon" button.
Eric
"Truth derives its strength not so much from itself
as from the brilliant contrast it makes with what is
only apparently true." --- Emanual Lasker
http://www.geocities.com/SiliconValley/Heights/2354/
Date: 30 Jan 1999 23:07:28
Message: <36B3D6C0.B8C4A94A@hiwaay.net>
Marc van den Dikkenberg wrote:
> Um...
> How can one see the icons supposedly inside the .icl file?
Rename povicons.icl to povicons.dll, then change the icon as others
have described.
Avoids your having to go to needless expense for an icon editor,
especially when Microsoft has a perfectly good free icon editor
somewhere on their site -- search for "imagedit" and also "aniedit"
for their free animated cursor editor).
Bob & Kelly Crispen
cri### [at] hiwaaynet
A polar bear is just a rectangular bear in a different coordinate system.
Date: 31 Jan 1999 11:12:28
Message: <36B480D5.F5587098@aol.com>
Thanks much for the lead, Bob, or Kelly.
> have described.
> Bob & Kelly Crispen
=Bob
Date: 31 Jan 1999 16:23:41
Message: <36B4C9A9.23330040@hiwaay.net>
Oops.  I'm gonna have to remember to fix the sig on each message.
Btw, the expense for MicroAngelo or something similar is only
"needless" as I described it before if you only do icons once
in a blue moon like I do.  As you may have discovered if you've
found the Microsoft editor -- I couldn't find it myself just
now, but I only spent a couple of minutes -- it's "basically
works but not that nice".
Bob Crispen
Subject: How to use them ANYWAY!
Date: 31 Jan 1999 16:31:53
Message: <36b4cbc9.0@news.povray.org>
I finally got to thinking about this. LOL!
Just save the icl file to an appropriate directory, then right click on your
Pov shortcut, properties, change icon, Browse, and then locate the *.icl
file.
It will then allow you to choose any of the icons.
GrimDude
vos### [at] arkansasnet
Date: 31 Jan 1999 23:15:18
Message: <36b6293f.34005046@news.povray.org>
On Fri, 29 Jan 1999 14:58:48 +0100, "Rune S. Johansen"
<run### [at] get2netdk> wrote:
>A while ago GrimDude posted a nice improvement of
>the two color pov icon. (The treat was called
>"Pov Icon".)
>Strongly inspired I made some icons myself all from
>scratch though.
>I've attached an iconlibrary with 3 icons.
>One for the program (the one with a red frame),
>one for .pov files (checkered floor with spheres),
>and one for .inc files (only spheres).
>I didn't make one for .ini files because
>they are used by many other programs also.
>The icons should work with only 16 colors, but they
>look better with more.
>Any comments?
>P.S. The icons aren't Disney advertisings ;)
>Rune S. Johansen
>http://hjem.get2net.dk/rsj
I like the floor-and-balls and use it for the SuperPatch. Here's my
DSWPov icon (attached). It;s a 64x64 pixels, in case you use large
icons (MS Plus!).
Peter
Download 'dswpov.ico.dat' (13 KB)
Subject: Re: How to use them ANYWAY!
Date: 1 Feb 1999 23:32:50
Message: <36B67FD4.1ACF404@hiwaay.net>
> file.
Yup.  The only reason to name it from .icl to .dll is that, at least
in my build of Win95, it defaults to showing only .ico, .exe, and .dll
files ("Icon files").  It just saves a step.
Bob & Kelly Crispen
Date: 4 Feb 1999 16:29:10
Message: <36ba1126.0@news.povray.org>
>>"Pov Icon".)
>>scratch though.
>>Any comments?
>>Rune S. Johansen
Thank you!
>Here's my DSWPov icon (attached).
>use large icons (MS Plus!).
>Regards,
>Peter
I think it is a very nice icon.
It's a little more original than mine :)
However, some parts of the icon is
transperant where it shouldn't be.
I guess you made the icon in a paint
program and saved as .bmp and then
changed it to .ico? At least the same
thing happens to me when I do so.
Rune S. Johansen
