POV-Ray : Newsgroups : povray.binaries.images : Lighthouse Scene Server Time
12 Jul 2026 21:19:40 EDT (-0400)
  Lighthouse Scene (Message 32 to 41 of 51)
Subject: Re: Lighthouse Scene
Date: 8 Feb 1999 06:43:00
Message: <36BECD82.B5A44763@pacbell.net>
Mark Palmquist wrote:
> Sorry about posting the image in the post, in netscape how to attach
> pictures?,  not in the menus that I could find.
When in the composer window of netscape there is a
toolbar available with send, quote, address, ATTACH, etc...
Hit the attach button and a dialog will pop up asking if you want
to attach a file, address card, or a web page, Choose file and
a standard directory search dialog pops up. You need only
find your file and send the message. The program does the rest.
Ken Tyler
tyl### [at] pacbellnet
Date: 8 Feb 1999 12:25:55
Message: <36BEC187.B26BCAFB@bahnhof.se>
How to :
Edit->Preferences ->Mail&News->Formatting->
	*Use plain text editor
	*Convert into plain text
As for attachments, there is a button next to Adress and options, as
well as a tab beneath the address fields.
it can also be reached thru View-> *Attachments
//Spider
> I agree, this was mostly an image for the 'beam' the lighthouse was for
> reference only.
> Spider wrote:
> > Very nice image, and I agree with you on the light, but I'd make it go
> > even further out, since it is not a very good comparison wiht the
> > lighthouse and the length of the beam..
> > Can you please post with all images as attachments, and with only plain
> > text when you send ?
> > There has been much argumants about this erlier, and several of the
> > people on the newsgroup has readers that don't support html, or pay by
> > the minute, and therefore is put at an disadvangtage when you post like
> > this..
> > //Spider
> > > I was inspired by your post to start playing with media, I came up
> > > with the following scene (very sparce) with what I think the beam
> > > should look like.
> > > Would anyone like to comment on the beam effect?  any ideas are
> > > welcome.
> > > [Image]
> > > the source:
> > > //begin*******************************
> > > // Persistence of Vision Ray Tracer Scene Description File
> > > // File: lighthouse.pov
> > > // Vers: 3.1
> > > // Desc: spotlight/media interaction test
> > > // Date: 02/07/99
> > > // Auth: Mark Palmquist
> > > // uses bricks.inc by Jeff Lee
> > > #include "colors.inc"
> > > #include "metals.inc"
> > > #include "glass.inc"
> > > camera {location < 0, 16, -600>
> > >   right 4/3*x
> > >   up y
> > >   direction z
> > >   angle 65
> > >   look_at <0, 105, 0>
> > > light_source { <150, 500, 500>
> > >   color rgb 2
> > >   media_interaction off
> > >   //shadowless
> > > #declare Lightbulb = union {
> > >     merge {
> > >       sphere { <0,0,0>,1 }
> > >       cylinder { <0,0,1>, <0,0,0>, 1
> > >         scale <0.35, 0.35, 1.0>
> > >         translate  0.5*z
> > >       texture {
> > >         pigment {color rgb <1, 1, 1>}
> > >         finish {ambient .8 diffuse .6}
> > >       scale <0.4, 0.4, 0.5>
> > >       texture { T_Brass_1A }
> > >       translate  1.5*z
> > >     //rotate -90*x
> > >     scale 2
> > > #declare beam=
> > > union{
> > >   light_source { <0, .1, 0> color rgb<1, 1, 1>*4
> > >     spotlight
> > >     point_at <0, 10, 0>
> > >     radius 1
> > >     falloff 8
> > >     media_attenuation on
> > >     looks_like {Lightbulb}
> > >   cone {<0,0,0>, 0, <0,1000,0>, 360 open hollow interior {media
> > >       intervals 43
> > >       absorption .01
> > >       scattering {1, rgb 0.02}
> > >       samples 1, 10
> > >       confidence 0.9999
> > >       variance 1/1000
> > >       ratio 0.9
> > >      pigment{Clear}
> > >   rotate <0,0,-93>
> > > #declare newBrickMidtone=colour rgb <0.60,0.60,0.60>
> > > #declare newBrickHighlight=colour rgb <0.75,0.70,0.70>
> > > #declare newBrickLowlight=colour rgb <0.35,0.35,0.35>
> > > #include "bricks.inc" //Author: Jeff Lee
> > > #declare lighthouse=
> > > union{
> > >   object { beam translate <12.1,110,0>}
> > >   cone {<0,0,0>, 20, <0,100,0>, 15 texture { T_newBrick scale
> > > <1,2,18>}}
> > >   merge{
> > >     cylinder{  100*y,  120*y,  12 texture {T_Glass3}}
> > >     difference {
> > >       sphere { 120*y, 12}
> > >       box { <-15,100,-15>  <-15,120,-15>}
> > >       texture {T_Brass_3C}
> > > object {lighthouse translate <-200,0,0>}
> > > //end*******************************
> > > Darcy Johnston wrote:
> > > > Well, some time ago, I posted an image depicting my model of the
> > > > Hatteras
> > > > lighthouse. Here it is again in a scene.
> > > > Please let me know what you think of it.
> > > > Thanks,
> > > > Darcy
> > > > djo### [at] inamecomNOSPAM
> > > > http://www.geocities.com/SiliconValley/Sector/4317
Date: 8 Feb 1999 12:25:58
Message: <36BEC1CF.62188089@bahnhof.se>
Spiders are always right, they are insects!
//Spider
Bob Hughes wrote:
> I see you're keeping the tilted lighthouse though ;)
> Spiders may be right, and maybe not. The beam crosses nearly
> perpendicular, I would suppose, to the observer due to the perspective
> camera angle. This would be seen as a much diminished beam at such a
> point. Are you using 'scattering' type 5? If not, you might want to try
> it out, and set 'eccentricity' to greater than 0.
> > should look like.
> > welcome.
> > [Image]
> > the source:
> > // Vers: 3.1
> > // Date: 02/07/99
> >   right 4/3*x
> >   up y
> >   direction z
> >   angle 65
> >   look_at <0, 105, 0>
> >   color rgb 2
> >   //shadowless
> >     merge {
> >         translate  0.5*z
> >       texture {
> >       translate  1.5*z
> >     //rotate -90*x
> >     scale 2
> > #declare beam=
> > union{
> >     spotlight
> >     point_at <0, 10, 0>
> >     radius 1
> >     falloff 8
> >       intervals 43
> >       absorption .01
> >       samples 1, 10
> >       confidence 0.9999
> >       variance 1/1000
> >       ratio 0.9
> >      pigment{Clear}
> >   rotate <0,0,-93>
> > union{
> > <1,2,18>}}
> >   merge{
> >     difference {
> >       sphere { 120*y, 12}
> > > Hatteras
> > > Thanks,
> > > Darcy
>   http://members.aol.com/inversez/POVring.htm
> =Bob
Date: 8 Feb 1999 12:39:49
Message: <36BF2127.7FB7F930@pacbell.net>
Spiders are not insects !
Well maybe the Spider that hangs out around here is an
insect but real spiders are not.
 Spiders are arachnids. There is a fundamental difference
the most recognizable of which being the number of legs.
Insects can be identified by having six legs and the spider
with eight. There are other differences like mandibular
construction and specialize silk glands but they are not as
easily identifiable.
Ken Tyler
Date: 8 Feb 1999 13:50:03
Message: <36BF30A8.6F2ABC50@bahnhof.se>
I bow to your great wisdom, Ken.
Sorry, but I should have said, netweavers .-)
But, you are right, there are sipders that don't weave as well..
//Spider
> Ken Tyler
Date: 8 Feb 1999 19:53:26
Message: <36bf8706.0@news.povray.org>
Mark Palmquist wrote in message <36BE9295.A319DC04@earthlink.net>...
>Yes, Darcy did create the original image, I hope this will clear that up.
>Sorry Darcy if they thought it was my scene originally.
Not a problem. I'd also like to thank you for offering your code to help
with the light problem I was having. Thing have been hectic around here
lately and I haven't had a chance to really try and fix the scene. With your
help, I'm sure to have it licked much sooner.
Thanks again to everyone,
Darcy
Date: 9 Feb 1999 21:43:21
Message: <36C0F3B2.FF9A23E4@earthlink.net>
Thank's everyone, had the toolbar hidden, now has paperclip icon, DOH :)
> Ken Tyler
Date: 11 Feb 1999 21:04:17
Message: <36C38BB5.21454A09@diac.com>
Whoa! A lighthouse!  I've been working on one also... check it out..
Download 'scene.jpg' (63 KB)
Preview of image 'scene.jpg'
Date: 11 Feb 1999 22:45:41
Message: <36C3A3B3.1D797EDF@aol.com>
The perspective camera causes a lot of distortion, had you thought about
using a smaller 'angle' or larger 'direction' coupled with a more
distant camera? The beam appears too dense at the brightest point, to me
anyway.
Good looking image though. Yours is showing more visible scenery than
the other two lighthouses posted here so far and the model looks good
but Darcy's wins my vote for the texturing award.
 mailto:inv### [at] aolcom?PoV
Date: 11 Feb 1999 23:36:36
Message: <36C3AF74.AAB47594@hiwaay.net>
> Would anyone like to comment on the beam effect?  any ideas are welcome.
I really like that, especially the way the beam disperses.
Worry about the allegedly leaning lighthouse and the overall
brightness (and, to add a little obligatory quibbling, the
rocks that the lighthouse should be sitting on) later.  Nail
down that beam!
And if everybody else here hates it, give it to me.
Bob & Kelly Crispen
cri### [at] hiwaaynet
Son, there's two things you've got to choose between: sex and the saw.
Sex, well, nobody knows anything about that.  But the saw is family.
