POV-Ray : Newsgroups : povray.binaries.images : Cognac Glass Server Time
22 Sep 2025 07:28:54 EDT (-0400)
  Cognac Glass (Message 1 to 10 of 19)
Subject: Cognac Glass
Date: 10 Mar 1999 13:09:52
Message: <36E6C207.4D987AFD@aol.com>
I'm having lots of fun with Nathan's new patch.  He and Ron should get a
kick out of this one (or anyone else who's read Jensen's papers).
There's a few artifacts that I think may be there because the glass is a
mesh. I'm still unsure of the brightness on the base, but I suspect it
may be that odd phenomenon of light getting brighter before the
fade_distance is reached.  Not sure though.
Took about 2 hours of fiddeling to come up with this, most of which was
learning how to use the patch - word to the wise: don't use photons on
infinite objects!
Render time was 38 minutes at 640x480 and AA 0.3.
-Mike
Download 'cognac.jpg' (40 KB)
Preview of image 'cognac.jpg'
Subject: Re: Cognac Glass
Date: 10 Mar 1999 13:22:45
Message: <36E6B872.922477AF@kolumbus.fi>
> infinite objects!
> -Mike
What a dashing image! Can the patch be gotten from somewhere now?
Date: 10 Mar 1999 13:31:19
Message: <36E6B967.A1DBBC54@pacbell.net>
Look for yesterdays announcement in povray.programming from Nathan Kopp.
Hey Mikey ! Good stuff. I have a similar project under way. Time
to start dusting off all of those old glass objects that never quite
made it into a scene because the caustics were wrong.. <g>
Ken Tyler
mailto://tylereng@pacbell.net
Date: 10 Mar 1999 13:47:04
Message: <36e6be28.0@news.povray.org>
Did I expect a glass image? Yes :) I'm doing a brandy glass, BTW.
The brightening of the light is something to investigate. Try this: make a
glass sphere with ior 1. A strange effect. Now do ior 1.1. The caustic seems
far too bright and sharp. I'll investigate this a bit more before I start
bugging Nathan...
Margus
Mike wrote in message <36E6C207.4D987AFD@aol.com>...
>infinite objects!
>-Mike
Date: 10 Mar 1999 14:44:33
Message: <36e6cba1.0@news.povray.org>
Is the foot of the glass flat? If so, what happens if you make it hollow?
Just an idea.
ingo
Met dank aan de muze met het glazen oog.
Date: 10 Mar 1999 18:18:51
Message: <36e6fddb.0@news.povray.org>
I love the caustics.
About the glass: it seems awfully thick (tough cognac glass
I suppose?); is that necessary to achieve the clearly
visible caustic effect, or does it work with thin refractive
objects as well?
Julius
Date: 10 Mar 1999 18:32:56
Message: <36E700F3.CF4492F6@Kopp.com>
I'm pretty sure I know why it is overly bright, but I'm not sure right now
exactly how to fix it.  Here's the problem:
     |______________|    glass
------------------------ ground
If the glass is just above the ground, photons will get deposited on
both surfaces.  But they are gathered independly from the scene geometry,
so you end up getting double the photons that you should get.  If you
set the "ignore_photons" flag in the glass, it shouldn't store photons
on the glass, so that should work as a workaround for now (speeds the
render time, too),
Sorry I didn't include any demo scenes.  Once you get a good shooting
density & gather density combination, you can usually just reuse that code
to get started with a new scene.
One way to get rid of artifacts is to increase the jitter amount.  If
that doesn't fix it, it probably is because your glass is a mesh.
Looks great, by the way!
-Nathan
> infinite objects!
> -Mike
Date: 10 Mar 1999 18:35:01
Message: <36E7016F.72E68084@Kopp.com>
what strange effect?
> bugging Nathan...
If it's too sharp, try a larger gather radius.  I've done all sorts of
tests with the brightness, so it _should_ be correct.
-Nathan
Date: 10 Mar 1999 20:15:56
Message: <36E717C6.7FE4B077@bahnhof.se>
now this is SOOOO great...
i have downloaded, three times.. (hmm, when NS says 502k of 270, something is
wrong) but not installed yet.. I'll get at it :-)
> infinite objects!
> -Mike
//Spider
( spi### [at] bahnhofse ) [ http://www.bahnhof.se/~spider/ ]
#declare life = rand(seed(42))*sqrt(-1);
Date: 10 Mar 1999 20:31:09
Message: <36E71AD9.C75418B2@ndirect.co.uk>
Rather NS than MS!
Steve
(as you can all see I've now got hold of the new browser version
settingw):
> > infinite objects!
> > -Mike
> >  [Image]
> //Spider
> ( spi### [at] bahnhofse ) [ http://www.bahnhof.se/+AH4-spider/ ]
