POV-Ray : Newsgroups : povray.binaries.images : A new twist on an old HF Server Time
29 Jun 2026 11:44:18 EDT (-0400)
  A new twist on an old HF (Message 1 to 7 of 7)
Subject: A new twist on an old HF
Date: 4 Mar 1999 08:04:24
Message: <36DE842C.7A8BAD23@pacbell.net>
In an attempt to create a new method of generating HF's with realistic
variations in texture, color, and topography I came up with a procedure
that seems to work with some success. In this image there are about 35
copies of one HF randomly distributed and scaled within a loop. There were
3 different HF versions the only difference being that of the texture
used. The rest was in a way left to nature to decide how it would turn out.
As it is with any new approach this one has bugs, random weirdness, and
an occasional surprise or two that needs to be worked out but so far I am
pleased with the results.
Your comments are welcome.
Ken Tyler
mailto://tylereng@pacbell.net
Download 'alcove3.jpg' (44 KB)
Preview of image 'alcove3.jpg'
Subject: Re: A new twist on an old HF
Date: 4 Mar 1999 08:15:56
Message: <36DE8788.B94E689C@ica.uni-stuttgart.de>
Ah, this site is so much nicer than c.g.r.r. :-)
I like what I see.
I wonder if these scattered points in the background are caused by the
overlaying of the HF's (two triangles at the same position)?
Marc
Marc Schimmler
Date: 4 Mar 1999 08:23:30
Message: <36DE88C5.B048A089@pacbell.net>
> I like what I see.
> Marc
> Marc Schimmler
  It's hard to say. The image used for the HF was poorly designed and
certainly never intended for the way it was used here. I guess that
speaks volumes for the possibilites of this process. It could be a jumble
of micro HFs gathered together. The way the loop is constructed there is
no telling what ended up where, of what size, or which textured version.
Like I said nature runs it's coarse with this process. :)
Ken Tyler
Date: 4 Mar 1999 14:56:47
Message: <36dee57f.0@news.povray.org>
Ken wrote in message <36DE88C5.B048A089@pacbell.net>...
>> I like what I see.
>> Marc
>> Marc Schimmler
This is a major advance in the use of HFs. It gives a truly real sense of
landscape - I suspect the choice of HFs could be crucial to the final
effect - the rather liquid section at the front looks rathe out of place but
the stalactite? grooves are superb. Keep on with it - it has enormous
potential.
In fact I might use the idea - with your permission of course:-)
Mick
Date: 4 Mar 1999 15:22:25
Message: <36DEEAE3.F50F5D13@pacbell.net>
> potential.
  Agreed. One thing that many people overlook with height fields is the
incredibly low amounts of memory they use. I had one image I did that
had over 2000 HF's I was using as leaves on a tree. The memory his was
less that 20 megs. In a scene with 30-60 HF's it's well under 10 megs
and the render time is very fast because it is an internally generated
mesh object. Unlike the standard mesh object you can also perform CSG
operations on HF's which further adds to it's charm.
  Then comes the big bonus - looking at Mr. Kress's image posted today
you can see that it is also possible to recreate fine art using HF's.
  What an unsung hero the Hf object is. What glorious days loom ahead
for the nobel and unappreciated height field object. It's day is at
hand and all shall know it's utility and subtle power ere this
millennium is gone and past.
Permission granted.
> Mick
Ken Tyler
Date: 4 Mar 1999 15:51:44
Message: <36DEF1E5.BA4B9903@metrolink.com>
Um, Ken?  You may wish to go have a lie down somewhere.....
pondering heightfields for his latest endeavour,
|Colin Scott McDonald                                  Metro Link, Inc.|
|                veni, vici, volo in dominum redirre                   |
|sco### [at] metrolinkcom                                  www.metrolink.com|
Date: 4 Mar 1999 23:52:18
Message: <36DF618C.2F07B8A1@bahnhof.se>
Great job on the hf's. and, you forgot to add that it is in proportion to the
size of the image. I have a HF+imagemap here that _only_ takes 30mb to render...
and there's no other objects...
> Ken Tyler
//Spider
( spi### [at] bahnhofse ) [ http://www.bahnhof.se/~spider/ ]
#declare life = rand(seed(42))*sqrt(-1);
