POV-Ray : Newsgroups : povray.binaries.images : invisable but reflecting Server Time
5 May 2026 08:11:31 EDT (-0400)
  invisable but reflecting (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: invisable but reflecting
Date: 15 Nov 2000 21:20:31
Message: <chrishuff-7846A8.21204515112000@news.povray.org>
In article <3a13385f$1@news.povray.org>, "Adam Roben" <yod### [at] homecom>
wrote:
> Now, I may be completely off-base on this, but it seems to me that
> there is a much simpler way to do this than using no_image, etc.  Put
> a dark-red sphere out of the camera's view.  Resize it so that it
> appears to be the same size as the marble and green spheres when
> looking from the mirror sphere's position.  Then reposition the
> dark-red sphere so that it appears to be inbetween the marble and
> green spheres.  Doesn't this seem possible?
Possible in some cases...but easier?!?
It will probably take a bit of trial and error to get right. It won't
work with some mirror surfaces or if you have a heavy normal, and it
will only work with the camera position you designed the scene with. And
if you have another mirror behind everything...and what about shadows?
The bounding method is fairly simple, works in nearly all cases, can be
set up without guesswork, and will not require redoing the scene every
time you move something. It will also work with oddball mirrors(torii,
CSG, multiple flat mirrors, etc.)
The no_image, no_reflection, etc. keywords are the simplest and easiest
solution...just add the keyword to the object and you get the intended
result. You can't get any simpler than that...
Christopher James Huff
Date: 15 Nov 2000 21:58:55
Message: <522.353T1495T12424216PeterC@nym.alias.net>
Jerome M. Berger wrote:
>       Or else he used a bounding box to make the middle sphere visible from
>the mirror but not the camera
        Yup.  That's what I did.  I put the bounding sphere for the
red sphere around the *reflecting* sphere.  This works (as you saw)
but I am not entirely happy with it because it clobbers the shadow.
It would be cool for the invisable sphere to cast a shadow as well
as being reflected in the mirror.
        BTW, that was done in (official) Povray 3.1, no fancy MEGA
tricks.
Pete
Date: 16 Nov 2000 04:44:58
Message: <3A13AC9A.41E79420@tapasmail.net>
	Bound it with a union of:
* a sphere around the mirror, like you have
* and a sphere whose center is at the same place as the light source and
with a very small radius...
	This way it should be reflected and cast a shadow (and AFAIK this can't
be done with any combination of no_image, no_reflection...)
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 16 Nov 2000 06:54:38
Message: <3A13CB0C.E3F75F94@atos-group.com>
Simply using no_image, you would still have shadow and reflection...
Date: 16 Nov 2000 09:32:19
Message: <3A13EFF1.9D087C8E@tapasmail.net>
	I thought no_image removed also the shadows?
Subject: Re: invisable but reflecting [jpeg 16kbu]
Date: 17 Nov 2000 02:38:07
Message: <3A14E06F.10F4DF7A@atos-group.com>
Well, look at this quickie (not as good as the initial poster of this thread)
The 'colors' of each finite object indicate the use of
no_shadow, no_image and no_reflection
Alas, the superellipsoid would be cyan...
Download 'l.jpg' (16 KB)
Preview of image 'l.jpg'
Date: 17 Nov 2000 09:54:34
Message: <3A1546A8.717373B3@enst.fr>
	All right, I shouldn't speak about what I haven't tried...
Date: 17 Nov 2000 20:18:51
Message: <134.355T57T13393274PeterC@nym.alias.net>
which only works in Mega POV, correct?
Date: 17 Nov 2000 20:18:53
Message: <381.355T1801T13384982PeterC@nym.alias.net>
>can't be done with any combination of no_image, no_reflection...)
        That worked!  Thanks!
Date: 20 Nov 2000 05:33:03
Message: <3A18FDDF.3F6CAA39@enst.fr>
	Correct, does that mean you're not using MegaPov? You don't know what
you're missing...
