Hi all:
Here are some attempts to replicate the results of Mael HDRI patch
with regular image_maps, ambient and radiosity. This is not a try to
invalidate the need for a patch, but only a search for a way to do it
with any POV-Ray scene. I liked very much the tests done by Gilles and
others, but I wanted to do it with something more than a limited set of
premade HDR maps. And as the only camera that I have is POV...
In my usual lazy-curious way of thinking, I figured that the important
part here was not the H but the DR. That is, the image used needs to
have a dinamic brightness. The problem, as Ive said, is that on a
regular photo (or POV image), the sun and a sheet of paper are both rgb
1. But with POV, the scene for the map can be carefully created with a
"pseudo-dinamyc" brightness, making light sources much brighter than the
other objetcs on the scene. That is how I've setup the light for a
spherical shot on the "office" scene, using the resulting image as the
fake HDRI for the "reflective balls" scene.
Well, not as spectacular as real HDRI, but I needed to keep busy the
CPU with something while writting the docs for the next version of
ligthsys...
Jaime Vives Piqueres
http://www.ignorancia.org
Download 'test-dri-3.jpg' (11 KB)
Download 'test-dri-4.jpg' (11 KB)
Preview of image 'test-dri-3.jpg'
Preview of image 'test-dri-4.jpg'
Impressive! The first one really looks real! I guess it works...
I don't really grasp what you're doing. Are you
using several dozens of lightsources and some are
really bright (where actual lamps are) and others are
more dim (just for bright surfaces etc), or are you
doing something different?
And how exactly do you prepare it, by hand, or by
some ingenious POV-trace-find-color-put-lightsource
way?
See, I'm nosy. :-)
Tim
> ligthsys...
On Mon, 30 Dec 2002 11:33:22 +0100
> way?
No, it is a simple image_map, no light sources:
sphere{0,.5 hollow
pigment{
image_map{png "office" map_type 1 interpolate 2}
finish{ambient 1}
scale 10e5
The only other trick is using radiosity with a recursion limit of 1
and a brightness of 10. The important part for the result is how the
scene for the map shot is setup. In this map scene the lights must be
much brighter than any ohter object, so when mapped on the second scene
the pixels corresponding to the more bright parts behave as"faked"
light sources. The rest of the map also contributes to light the scene,
but much less than these "spots".
Hope it is clear enough... I'm not really good at explaining my fuzzy
mental process. I'm noisy too...
in news:200### [at] ignorancia org Jaime Vives
> sphere{0,.5 hollow
> pigment{
Is it a 8 bit/color image or 16 bit/color?
Ingo
On 30 Dec 2002 07:25:25 -0500
It's a 16 bit png converted from the tga output from POV.
I see two problems. Povray doesn't output 16 bit tgas and
doesn't use the low byte of 16 bit pngs. You might as well
used 8 bit files.
_____________
Kari Kivisalo
On Mon, 30 Dec 2002 18:50:43 +0200
> used 8 bit files.
Well, you are right, as usual. :)
I've done the experiment without even thinking about how many bits of
color I was using. As I said, I tought that this was not the important
thing. I only looked at it to answer to Ingo.
Anyhow, I've just tried it again directly with the tga, to be sure,
and the result is the same, of course. So, you must be right and POV
only reads 8 bits from the PNG. But, there is a format in wich POV
reads more than 8 bit for a image_map? ...I've tried with different
formats at 8 and 16 bits, but the results look always the same (with
the exception of the crash with TIFF and the "multicolor" results
with PPM).
in news:3E107963.9E8741A9@luxlab.com Kari Kivisalo wrote:
> Povray [...] doesn't use the low byte of 16 bit pngs.
Ah, never realised that :(
Ingo
It's easy to test.
// test.pov
// +fn16 +kff2
global_settings{assumed_gamma 2.2}
camera{
orthographic location -z up y right x
direction z look_at 0 translate <0.5,0.5,0>
#declare M=64; // up to 256 the gradient should be smooth
#if(clock<0.5)
plane{z,0 pigment{gradient y color_map{[0 rgb 0][1 rgb 1]}}
finish{ambient 1/M}}
#else
plane{z,0 pigment{image_map{png "test1.png"}} finish{ambient M}}
_____________
Kari Kivisalo
