"ABX" <abx### [at] abx art pl> wrote in message
news:d0vd6vcbe7gl6kc7p7ti374dek94gfsal3@4ax.com...
> On Wed, 5 Mar 2003 20:22:29 -0500, Greg Edwards
> <edw### [at] hotmail comremovethis> wrote:
> > A bit more...
> > camera{location 2*y-.9rotate -9*z direction z/1.5look_at
y}global_settings{
> > max_trace_level 99ambient_light 10}#macro P(o,c)plane{y,o
pigment{c}finish{
> > diffuse 0}}#end object{P(9,blue 1)}object{P(-1,rgb
1)}box{1+9*y,-y-1pigment
> > {rgb 1}finish{ambient.005diffuse 0reflection.95}}sphere{0,.99finish{
> > reflection 1}}sphere{0,1pigment{red 1}finish{ambient
0reflection{1metallic}
> > }no_reflection} // Greg Edwards, 2003
> I feel this can be shortened (in particual camera) but this is already
shorter
> and does not produce warning.
> camera{direction z/1.5location 2*y-.9rotate-z*9look_at y}global_settings{
> max_trace_level 99ambient_light 10}#macro p(c,d,a,r)pigment{rgb c}finish{
> diffuse d ambient a reflection{r#end plane{-y,-9p(z,0,.1,0)}}}plane{y,-1p
> (1,.0.1.0)}}}box{-y-1y*9+1p(1,.0.005.95)}}hollow}sphere{.0.99p(no.6.1on)}
> }}sphere{0,1p(x,.6,0,1)metallic}}no_reflection} // Greg Edwards, 2003
> Please, note sig is supposed to represent author. How reflective spheres
> represent your person ? :-)
He's an oddball? That would work for me.
On Thu, 6 Mar 2003 10:21:36 -0500, Greg Edwards
> I've often felt isolated from others in the group often, this is what I'm
> trying to represent in the scene.
You will be isolated even more with such a long sig :-) While writing sigs
is fun and educational, your version is far from acceptable length. Please
do not use it. Force yourself to make another sig which fits rules. Have fun
with it :-)
ABX
>>> A bit more...
> y}global_settings{
> pigment{c}finish{
> shorter
Right on! :-)
camera{location 2*y-.9rotate -z*9direction z/1.5look_at y}global_settings{
max_trace_level 99ambient_light 10}#macro P(o,c)plane{y,o pigment{c}finish{
diffuse 0}}#end object{P(9,blue 1)}object{P(-1,rgb 1)}box{1+9*y,-y-1pigment
reflection 1}}sphere{0,1pigment{red 1}finish{ambient 0reflection{1metallic}
> with it :-)
> ABX
Fits the rules? I don't recall any rules for what can go in your signature.
IIRC, the Shortest Code Contest allows for a maximum of 500 bytes which
this easily fits in. The actual signature is 416 bytes but could easily be
condensed to 382 if I removed the line breaks and took out the comment.
Having fun with it is what I did! :-)
On Thu, 6 Mar 2003 11:44:06 -0500, Greg Edwards
http://www.uwasa.fi/~ts/http/signatur.html
You are mistaken. Shortest Code Contest never mentioned it makes rules for
signatures. It was not Shortest Signature Contest. In particular please look
at one rule in Shortest Code Contest: "MAX size: 500 bytes (arbitrarily
chosen as twice the size of one very competent sig file posted to p.g.)".
That's the most important :-)
ABX
>>> A bit more...
>>> camera{location 2*y-.9rotate -9*z direction z/1.5look_at y}global_settings{
>> I feel this can be shortened (in particual camera) but this is already shorter
>> ABX
> trying to represent in the scene. Also, abstract scenes are just my style
>:-) You can't really see that the red ball is all alone but that's because
> I couldn't place it outside the 2x2 area of the mirrors.
One more thing, when I said "the group," I meant groups in general, not
this newsgroup. I was just really rushed when I posted that message and I
couldn't think of a better word.
BTW, I've done a super shrink job on my sig. (this one is now 375 bytes)
max_trace_level 99ambient_light 10}#macro G(V,E)pigment{V}finish{diffuse 0
ambient .1-E/10reflection{E metallic}}#end#macro O(N,T)plane{y,N G(T,0)
hollow}#end#macro C(A)sphere{0,A#end O(9,blue 1)O(-1,rgb 1)box{1+9*y,-y-1G(
rgb 1,.95)hollow}C(.99)G(rgb 1,1)}C(1)G(red 1,1)no_reflection}// Greg E
You have repeated things I already shortened in this thread. Have you
noticed them ? :-)
ABX
> noticed them ? :-)
> ABX
Yes I did and I also realized that your version of the pigment macro took
an unnecessary diffuse value which is always zero and I believe my
auto-ambient takes a few less bytes in the long run.
PS. Funny how we're arguing over bytes! :-)
>> noticed them ? :-)
>> ABX
Whoops, forgot to give you credit! The texture macro was your idea!
How's this for indecision? I've compacted my old signature down to 4 lines
of 75. (302 bytes)
camera{location 2*y-.9direction z/1.5look_at y rotate#macro G(V,E)plane{y,V
O(E,0)}#end-z*9}max_trace_level 99#macro O(N,T)pigment{rgb N}finish{diffuse
0ambient 1-T reflection{T metallic}}#end#macro C(A)sphere{0A#end G(9z)G(-1,
1)box{1+9*y,-y-1O(1,.95)}C(.99)O(1,1)}C(1)O(x,1)no_reflection}// Greg E
light_source#macro G(E)sphere{z+E*y*5e-3.04rotate-z*E*6pigment{rgbt#end{
20*y-10#local n=162;1}#while(n)#local n=n-.3;G(n)x}}G(-n).7}}#end//GregE
