POV-Ray : Newsgroups : povray.binaries.images : One last Time! (77+26KBU) Server Time
5 May 2026 09:28:13 EDT (-0400)
  One last Time! (77+26KBU) (Message 11 to 20 of 28)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: One last Time! (77+26KBU)
Date: 2 Nov 2000 13:38:50
Message: <chrishuff-2CDE6D.13415802112000@news.povray.org>
In article <01c044f0$1483ddc0$727889d0@daysix>, "H. E. Day"
<Pov### [at] aolcom> wrote:
> There is only one drawback to this weapon, which is it's inability to
> function in a vacuum.
In that case, at short range you can just thrust backwards until your
enemy follows you into the trail of ions your thrusters leave behind.
You would quickly run out of fuel that way though...and this looks like
a ground-based vehicle.
Or fire rockets which leave a relatively dense trail of ions. Or just
use the lasers themselves...if they can ionize air to a high enough
degree to carry and direct an electrical current, they are probably
pretty powerful. (what portions of the spectrum are best absorbed by
air?)
Faraday cages might be a problem, you would probably want *some* kinetic
energy weapons. Bullets, high velocity rockets, something a bit more
effective than your beak.
Christopher James Huff
Date: 2 Nov 2000 13:45:18
Message: <chrishuff-56641B.13482502112000@news.povray.org>
In article <3A01A8B7.FD4DD154@pacbell.net>, lin### [at] povrayorg
wrote:
> No. If the object being attacked is well shielded or grounded the weapon
> is useless because the energy is shunted away doing no damage. Commercial
> airlines, for example, are specifically designed to take several direct
> lightning strikes throught the life of the aircraft which causes no damage
> to them.
Lightning doesn't have a powerful laser ionizing the air between it's
origin and it's target...insulative shielding would have to be some kind
of ceramic to block the laser as well. And grounding can be a bit
difficult in mid air.
The best defense against this weapon would probably be a Faraday cage
with highly reflective ceramic armor, with a very good ground. It might
work well on large numbers of people, though. Mob control drones? Royal
guard?
It now looks about human-height, still far too small for someone to be
inside in my opinion.
Date: 2 Nov 2000 13:49:13
Message: <3A00F1AE.3A1F11F1@igiles.net>
How about very large feathers trailing off from the back of each wing
section. Feathers much larger ( like 2 or 3 times the length of the wing
sections) would give the wings the proportion that they seem to need,
provide better balance, and look really cool. :)
Jay Raney
Date: 2 Nov 2000 14:03:26
Message: <3a01ba7e$1@news.povray.org>
Doubtful, since rocket exhaust would be pretty hot, and with no surrounding
air it just sprays off and diffuses into the void. That wouldn't leave
enough atoms to ionize.
> air?)
You would have to take a flouride excimer laser at 150nm. That would be
ultra violet and not visible anymore. One day people might even be able to
build them smaller than the size of three
refrigerators :) (sure would look kind of clumsy on H.E's mech)
Date: 2 Nov 2000 16:22:25
Message: <chrishuff-EEF203.16253202112000@news.povray.org>
In article <3a01ba7e$1@news.povray.org>, "Daniel Schwen"
> surrounding air it just sprays off and diffuses into the void. That
> wouldn't leave enough atoms to ionize.
I meant fire special rockets which leave a trail dense enough to carry
the current for a short time before dissipating. The entire goal of the
rockets would be to get to the target as fast as possible and leave a
relatively dense ion trail, they wouldn't even need a payload. The range
would still be limited though. Or they could trail a fine wire that
would be vaporized to produce the needed channel.
Or you could confine ions with magnetic fields, but if you can get
magnetic fields that powerful and that well controlled you probably have
much better ways to blast your prey.(spray them with antimatter?)
> be ultra violet and not visible anymore. One day people might even be
> able to build them smaller than the size of three refrigerators :)
I was thinking of some kind of ultraviolet laser...but three
refrigerators? This thing looks like it's slightly smaller than one
kitchen refrigerator...and it has two lasers. Maybe some kind of
one-shot laser...a high-power chemical laser. Oh, well...if this
civilization has the ability to generate the power in a package that
small, they can probably make a smaller laser too. :-)
As for the visibility thing, you would probably see a bright white flash
before the actual charge is released as the laser ionizes the air. Those
red lines must be targeting lasers. :-)
Of course, with the wire rockets idea(and possibly with the rockets
alone), you don't even need a laser.
Date: 2 Nov 2000 18:28:19
Message: <01c04525$17655fc0$727889d0@daysix>
| Mob control drones? Royal guard?
Angels.  Don't worry, I'll explain, just not here. :)
Correct.  They are around 10-12 feet tall.  They are full automated.  And
quite smart.
H.E. Day
Date: 2 Nov 2000 18:29:16
Message: <01c04525$3a530640$727889d0@daysix>
| No.
Aww, Ken, can't you just play along?  :-)
H.E. Day
Date: 2 Nov 2000 18:51:56
Message: <3A01FE61.3ABEF145@pacbell.net>
"H. E. Day" wrote:
> | No.
Bzzzzzt....
Date: 2 Nov 2000 19:40:32
Message: <chrishuff-B1AEDA.19433902112000@news.povray.org>
In article <01c04525$17655fc0$727889d0@daysix>, "H. E. Day"
Ok...
> quite smart.
They look around 6 feet to me...maybe a smaller, wingless or folded
winged, 4-6 foot version, with some feathers the same size as the ones
on the big version, and a few smaller feathers that are of the same type
as the big ones. I think that will make the feathers on the large one
look larger, making the whole thing look the proper size.
Ok, that wasn't very clear: make smaller feathers that look the same as
the large feathers to make the large feathers look larger.
They could operate in threes, one large one assisted by two smaller
ones. In battle, the smaller ones could scout ahead, go areas too small
for the large one, do repairs, etc.
They could also serve as "police" in cities. Their size and lack of
wings would make them more able to maneuver through crowded streets,
relatively open buildings, and other tight areas.
Date: 2 Nov 2000 20:18:18
Message: <3A02129F.5932667C@pacbell.net>
Huh?
