POV-Ray : Newsgroups : povray.binaries.images : Help with light problem? Server Time
17 Jul 2026 04:36:22 EDT (-0400)
  Help with light problem? (Message 1 to 9 of 9)
Subject: Help with light problem?
Date: 4 Sep 2000 12:49:01
Message: <01c01690$aa7b8fa0$ae1ba1d0@mk>
See attached pic.  Notice the superellipsoid doesn't show up?
How can I fix this without changing the lighting of the scene dramatically?
Code follows.
#version unofficial MegaPOV 0.5;
global_settings { assumed_gamma 2.2 radiosity {}
photons{count 40000    autostop 0    jitter .4}
#include "textures.inc"
#include "woods.inc"
#include "metals.inc"
#include "stones.inc"
#include "glass.inc"
#declare A=<0,60,0>;
#declare B=<-50,50,-30>;
#declare Random=seed(tick_count)
   location B
   look_at
   <0,0,0>}
light_source {
<-50,51,-30>
//notice the light is to the far left, but shows up the most on the right
side of the floor.
color White*1.5
//area_light <-20,0,-20>,<20,0,20>,5,5
//photons { refraction on reflection on}
#declare Row = union {
#declare Count = 0;
#while (Count < 10)
height_field{
 tga "HFTest"
 translate -.5
 scale <10,.5,80>
 texture{
 //image_map {tga "HFTest"}
 T_Wood10 //turbulence .1
 translate Count*rand(Random)*4*<1,1,1>
 rotate z*rand(Random)*20
 normal {
 bump_map {tga "HFTest"}}
 finish{phong .3 phong_size 20}}
 translate -2.25*y translate z*80.3*Count
#declare Count = Count + 1;
}//end row union
#declare Planks1 = union {
#declare Count = 0;
#while (Count < 5)
object {Row translate <20.1*Count,0,40>}
object {Row translate <10,0,0> translate <20.1*Count,0,0>}
}//end Planks1 union
#declare Wall =
height_field{
 tga "HFTest2"
 translate -.5
 scale <500,.3,500>
 texture{
 pigment {White}
// and here's the problem piece .... why doesn't it show up?
superellipsoid {
<0,0> scale <1,3,100> translate <40,1,0>
texture {T_Wood1}
finish {phong 1 phong_size 300}
object {Planks1 translate <-50,0,-50>}
object {Wall rotate <0,0,90> translate <50,-30,50>}
Download 'HFTest2.bmp.dat' (226 KB)
Subject: Re: Help with light problem?
Date: 4 Sep 2000 13:24:08
Message: <39B3DAF5.EA69B3B9@schunter.etc.tu-bs.de>
> superellipsoid {
> texture {T_Wood1}
I think the parameters of the superellipsoid must not be 0.
Date: 4 Sep 2000 15:05:04
Message: <39B3F22C.31802C44@kyrre.net>
Don't mean to be bitchy, but it's a good idea to strip your code for all
unnecessary parts when you try to find what's wrong. If you still don't find
it, posting a minimum scene makes it easier for the people here to help you.
Also, jpg is preferred..
ICQ 74734588
Date: 4 Sep 2000 15:52:03
Message: <chrishuff-1BBBCC.14534404092000@news.povray.org>
In article <01c01690$aa7b8fa0$ae1ba1d0@mk>, "CreeD" <meshe@nqi.net>
> dramatically?
As someone else mentioned, that is a lot of code to demonstrate a simple
problem. You could have trimmed it down to a simple checkered plane and
your superellipsoid.
As for your problem:
superellipsoid {<0, 0>
This may be a problem later. According to the POV-Ray documentation,
"The roundedness value Round determines the roundedness of the edges and
has to be greater than zero and smaller than one."
This isn't your real problem, though. The problem is here:
texture {T_Wood1}
finish {phong 1 phong_size 300} <---this makes a new texture layer!
I assume you tried to change the finish of the T_Wood1 texture, but what
you really did was make a layered texture, putting a different finish on
the second layer, which used the default texture for it's pigment and
normal. Since the default pigment is opaque black, your superellipsoid's
wood texture gets covered up with a black texture using the finish you
specified.
To change the finish of the T_Wood1 texture, you need to put the new
finish *inside* the texture block:
texture {T_Wood1
Christopher James Huff
Date: 4 Sep 2000 16:27:42
Message: <39B405FB.668058E8@schunter.etc.tu-bs.de>
> texture {T_Wood1}
> specified.
> texture {T_Wood1
I first thought you were right, but with
superellipsoid {
<0,0>
texture {T_Wood1
it stays black because of the the zero parameters.  It doesn't matter in the
end, because both things should be changed.
Date: 4 Sep 2000 17:16:27
Message: <39b4112b@news.povray.org>
that one heafty light problem.....
Date: 4 Sep 2000 18:57:08
Message: <chrishuff-A39507.17584904092000@news.povray.org>
wrote:
> See attached pic.
Yes, I see it. One tiny bit at a time. :-)
Please don't post .bmp files, use JPEG files instead. I was able to get
this 228K .bmp down to 9.1K with little noticeable degradation, and down
to about 5K while still quite clearly showing your problem.
Date: 9 Sep 2000 16:36:06
Message: <01c01a9e$526b69e0$371ba1d0@mk>
Sigmund Kyrre Aas <sig### [at] kyrrenet> wrote in article
<39B3F22C.31802C44@kyrre.net>...
find
you.
I don't take it personally.
Believe it or not, that was sorta stripped down, but I guess I could have
gone further.
Date: 9 Sep 2000 16:37:30
Message: <01c01a9e$850005a0$371ba1d0@mk>
> texture {T_Wood1
all I can say is,
"aaaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhhhhhhh."
Thank you.
