POV-Ray : Newsgroups : povray.binaries.images : blob words : Re: blob words Server Time
22 Jan 2026 23:53:40 EST (-0500)
  Re: blob words
Date: 30 Jan 2022 16:25:00
Message: <web.61f70177b6d4eb89ea8869266cde94f1@news.povray.org>
hi,
> I have a couple of suggestions.  If you know the surface radius of each
> component, you can create a union of spheres, and take the center of the
> union.  Function RE_fn_Blob_surface_radius() in roundedge.inc can
> calculate the surface radii.
>   <https://github.com/CousinRicky/POV-RoundEdge>
yes, I can specify the radii, so, excellent, thanks, will check out the code.
> Alternatively, you can go brute force with trace() or inside(), and take
> the center of all the successful hits.  inside() would take longer than
> trace(), due to being volumetric, but it would allow you to compute a
> rough center of gravity, rather than just computing the center of the
> extents.
ah, there's the rub.  what I want, ideally, is to find the one point in a blob
which, when placed at origin, would allow me to rotate "the hell out of it" :-).
 unfortunately my maths/knowledge is .. abysmal, I do not (even) know whether
that specific point is the centre of the extents (what I meant by geometric
centre) or the centre of gravity.
regards, jr.
