POV-Ray : Newsgroups : povray.binaries.images : Isosurface from magnitude of complex function with domain coloring : Re: Isosurface from magnitude of complex function with domain coloring Server Time
13 Jan 2026 09:04:41 EST (-0500)
Date: 25 Dec 2021 20:35:00
Message: <web.61c7c50f6041c670bbb338f289db30a9@news.povray.org>
> Very nice.
Thank you Bill !
> I was consulting the stuff that Paul Nylander wrote.  I'm assuming yours are
> similar.
I'm not very familier wit Paul Nylander's work. Those macros seem like a good
start for a library for complex calculations. But the Pow() macro could need
some work to allow for the exponent to also be a complex number.
I did not create macros to do the calculations, but arrays of functions and
macros that assemble functions into new functions. For each complex operator
there's two functions; one for calculating the real part and one for calculating
the imaginary part.
> I made these two to just keep track
> #macro Argument (Re, Im)
>  atan2 (Re, Im)
> #end
> #macro Modulus (Re, Im)
>  sqrt (pow (Re, 2) + pow (Im, 2))
> #end
I like your Modulus() macro better than the Abs() macro, because it does not
rely on the underlying implementation of how the complex numbers are
represented. I think that as few as possible of the macros should depend on the
underlying implementations. Btw.: Why have you chosen to have a different
atan2() call in your Argument() macro than in the Arg() macro ?
> I worked those out from the macros in colors.inc.  A little challenging at first
> to turn that whole thing into a function.  ;)
Yes, that's a bit of a struggle.
> This is looking great!  I'm sure there are a lot of other interesting complex
> surfaces to be explored.
I've started on a Github repository for my library. It's here:
https://github.com/t-o-k/POV-Ray-complex-functions
Please note that this is a work in progress, so some features hasn't been added
yet and much of it may change.
> I'm also wondering how hard it would be to use mod()
> to have an infinite array of those "black hole vortices" on a plane - in either
> a rectangular or an alternating/hexagonal arrangement...
That's an interesting idea: to have a mod() operator that can handle complex
values. But I don't know how to implement that...
Tor Olav
http://subcube.com
