hi,
"Bald Eagle" <cre### [at] netscape net> wrote:
> Thomas de Groot <tho### [at] degroot org> wrote:
thanks.
> > am not too sure about the "tint", and ask
> > > for suggestions for a 'rgbf' colour value that would go well with the defaults.
> Typical highlight/background colors might be white, green, orange, yellow, blue,
> magenta, etc.
> I usually use examples from well-developed software packages or presentations to
> draw inspiration when I hit a mental / aesthetic block.
> Maybe open up LibreOffice / OpenOffice Calc and see what works, or just do a web
> image search for "spreadsheet" and see what works.
"block" yes, good advice. I did just that, Google Images "spreadsheet", and
found pretty much every colour used for highlighting. :-)
decided to use '<.65,.65,.9,.975>', another blue.
> Depending on what the final render application is, you may want to consider
> adding rgbt 1, or not rendering the background box at all, to allow for
> transparent backgrounds with that +ua setting.
good point. have not tried yet with alpha-channel, but made a todo note.
> I could also envision a need for an rgbf color, say if someone was using a table
> to annotate an image or something like that.
> Heck. Tabulated () could be used to make a chess game animation, highlighting
> the current piece and destination square / options.... ;)
regards, jr.
