POV-Ray : Newsgroups : povray.binaries.images : Applying textures to a spherical heightfield section afterwards? : Re: Applying textures to a spherical heightfield section afterwards? Server Time
5 Dec 2025 19:38:42 EST (-0500)
Date: 15 Sep 2020 13:40:00
Message: <web.5f60fadb57afda216e3057d70@news.povray.org>
> =?UTF-8?Q?J=c3=b6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmxde> wrote:
> http://wiki.povray.org/content/Reference:Mesh2
> > But I have no uv_indices, just uv_vectors!
> My guess is that you may be missing a section of data.
> Perhaps POV-Ray creates uv-index data where it is missing, (<0, 0>?) and that
> doesn't jive with whatever it needs to do.   Or it's just a bad/misleading
> error.
Bill,
I have a suspicion that Yadgar does not read my replies, so I'll reply to you
instead.
Yadgar's problem is likely, like Jerome Grimbert explained, the unnecessary (?)
texture indices in his face_indices block. (I believe that Jerome Grimbert meant
to write "uv_vectors" when he wrote "uv_indices".)
POV-Ray complains, rightfully but not very comprehensible, when it reaches the
index to the first texture; because there is no texture_list block before the
face_indices block (as shown on the documentation page Jerome Grimbert linked
to).
What I find interesting though, is that it IS possible to combine UV-mapping and
a texture list: One can place several UV-mappable textures in the texture list
and then refer to each of them in the face_indices block thereafter.
I suspcet that this may be useful if one has several image map tiles that are to
be UV-mapped to different regions of the mesh.
Here's a complete scene that renders without problems if one provides an image
for the UV-mapping:
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7 =======
global_settings { assumed_gamma 1.0 }
default {
        finish {
            diffuse 0
            ambient color Black
            emission color White
#declare Earth_Slice_n42e044 =
    mesh2 {
        vertex_vectors {
            25
            <  2884.8178, -40532.7525,  56082.6582>,
            < -9171.5619, -40308.4150,  44746.1601>,
            <-21188.6401, -40084.4363,  33366.7545>,
            <-32877.9350, -40230.5532,  21652.1961>,
            <-44580.6796, -40306.6256,   9952.5033>,
            < 13057.8787, -23755.4346,  45548.1452>,
            <  1330.1334, -23909.1988,  33947.0299>,
            <-10630.4449, -23708.0951,  22585.0805>,
            <-22695.4630, -23321.5223,  11326.5482>,
            <-34370.6821, -23387.2495,   -329.0233>,
            < 23221.9340,  -6962.3006,  35022.9578>,
            < 11316.8721,  -6836.8635,  23677.4411>,
            <  -399.8051,  -6905.9531,  12137.8952>,
            <-12333.4551,  -6640.1561,    818.8397>,
            <-24333.2326,  -6238.3055, -10436.7932>,
            < 33304.7484,   9943.2953,  24581.8979>,
            < 21837.6885,   9539.8892,  12858.6481>,
            <  9658.4610,  10127.7787,   1866.7320>,
            < -1845.2730,   9879.2958,  -9816.8170>,
            <-13884.9949,  10384.4651, -20958.2292>,
            < 43363.8318,  26887.7446,  14165.4121>,
            < 31606.8161,  26914.8515,   2812.8338>,
            < 19694.9660,  27199.3287,  -8382.2095>,
            <  9001.1538,  25928.0627, -20815.7556>,
            < -2940.1603,  26357.8266, -31979.7411>
        normal_vectors {
            25
            < 0.5096, -0.6575, -0.5550>,
            < 0.5112, -0.6702, -0.5381>,
            < 0.4969, -0.6771, -0.5429>,
            < 0.5235, -0.6600, -0.5389>,
            < 0.5386, -0.6507, -0.5352>,
            < 0.5223, -0.6637, -0.5354>,
            < 0.5175, -0.6623, -0.5418>,
            < 0.5150, -0.6604, -0.5465>,
            < 0.5212, -0.6557, -0.5463>,
            < 0.5283, -0.6507, -0.5454>,
            < 0.5265, -0.6504, -0.5475>,
            < 0.5258, -0.6582, -0.5388>,
            < 0.5125, -0.6571, -0.5527>,
            < 0.5174, -0.6584, -0.5466>,
            < 0.5010, -0.6580, -0.5621>,
            < 0.5376, -0.6595, -0.5254>,
            < 0.5256, -0.6511, -0.5475>,
            < 0.5208, -0.6458, -0.5582>,
            < 0.5231, -0.6730, -0.5229>,
            < 0.4809, -0.6849, -0.5474>,
            < 0.5475, -0.6387, -0.5406>,
            < 0.5205, -0.6327, -0.5733>,
            < 0.5518, -0.6599, -0.5099>,
            < 0.5125, -0.6946, -0.5048>,
            <-0.5136, -0.6801,  0.5232>
        uv_vectors {
            25
            <0.000000, 0.000000>,
            <0.250000, 0.000000>,
            <0.500000, 0.000000>,
            <0.750000, 0.000000>,
            <1.000000, 0.000000>,
            <0.000000, 0.250000>,
            <0.250000, 0.250000>,
            <0.500000, 0.250000>,
            <0.750000, 0.250000>,
            <1.000000, 0.250000>,
            <0.000000, 0.500000>,
            <0.250000, 0.500000>,
            <0.500000, 0.500000>,
            <0.750000, 0.500000>,
            <1.000000, 0.500000>,
            <0.000000, 0.750000>,
            <0.250000, 0.750000>,
            <0.500000, 0.750000>,
            <0.750000, 0.750000>,
            <1.000000, 0.750000>,
            <0.000000, 1.000000>,
            <0.250000, 1.000000>,
            <0.500000, 1.000000>,
            <0.750000, 1.000000>,
            <1.000000, 1.000000>
        face_indices {
            32
            < 0,  1,  5>,
            < 1,  6,  5>,
            < 1,  2,  6>,
            < 2,  7,  6>,
            < 2,  3,  7>,
            < 3,  8,  7>,
            < 3,  4,  8>,
            < 4,  9,  8>,
            < 5,  6, 10>,
            < 6, 11, 10>,
            < 6,  7, 11>,
            < 7, 12, 11>,
            < 7,  8, 12>,
            < 8, 13, 12>,
            < 8,  9, 13>,
            < 9, 14, 13>,
            <10, 11, 15>,
            <11, 16, 15>,
            <11, 12, 16>,
            <12, 17, 16>,
            <12, 13, 17>,
            <13, 18, 17>,
            <13, 14, 18>,
            <14, 19, 18>,
            <15, 16, 20>,
            <16, 21, 20>,
            <16, 17, 21>,
            <17, 22, 21>,
            <17, 18, 22>,
            <18, 23, 22>,
            <18, 19, 23>,
            <19, 24, 23>
#declare pApproxLook = <-3295778.3537, 4308723.8277, 3353808.4183>;
object {
    Earth_Slice_n42e044
        uv_mapping
            image_map {
                png "AnImage.png"
                gamma srgb
                map_type 0
                interpolate 2
                once
    double_illuminate
    translate pApproxLook
#declare pMin = min_extent(Earth_Slice_n42e044);
#declare pMax = max_extent(Earth_Slice_n42e044);
#declare pCtr = (pMin + pMax)/2;
    location 10000*<0, 10, 8>
    look_at <0, 0, 0>
    translate pCtr + pApproxLook
background { color Gray30 }
Tor Olav
http://subcube.com
https://github.com/t-o-k
