POV-Ray : Newsgroups : povray.binaries.images : Homebrew heightfields : Re: Homebrew heightfields Server Time: 18 Jun 2019 07:08:52 GMT
Date: 23 Mar 2019 08:26:19
in news:XnsAA1B5C2AAB745seed7@news.povray.org ingo wrote:
> I.i.r.c you can also declare a macro (with trace) as __Fuv. You may
> have to fiddle a bit with that though.
Had a quick look. TwoVarSurf part of makesmesh.inc has to changed a bit
for that, file below. It doesn't change anything for existing scenes, but
makes it possible to declare the macor __Fuv and use that together with
TwoVarSurfCalc().
Also added the documentation that is missing in the distribution.
// former "twovar.inc"
TwoVarSurf(__Fuv, Urange, Vrange, Iter_U, Iter_V, FileName): Builds a
mesh2 surface of
           a function with two variables (u,v).
__Fuv    : the function to be turned into a mesh2.
Urange   : A 2-D vector that gives the boundaries of u.
Vrange   : A 2-D vector that gives the boundaries of v. These are the
ranges
           within whitch the surface is calculated.
Iter_U   : Sets the resolution of the mesh in the u range.
Iter_V   : Sets the resolution of the mesh in the v range.
FileName : The name of the file to whitch the mesh will be written. If is
an
           empty string (""), no file will be written.
           If the file extension is 'obj' a Wavefront objectfile will be
written.
           If the extension is 'pcm' a compressed mesh file is written.
           If a file name is given, the macro will first check if it
already exists.
           If that is so, it will try to parse the existing file unless
it's a '*.obj',
           '*.pcm' or '*.arr' file as POV-Ray can not read them directly.
In this case a new
           mesh will be generated, but the existing files will _not_ be
over-written.
Use:
   #include twovar.inc
   #declare __Fuv=function(u,v){(10*sin((u^2+v^3)^0.5))/(2+cos((u^2+y^2)^
0.5))}
   object {
      TwoVarSurf(<-6,6>,<-6,6>,20,20,"")
      uv_mapping
      pigment{checker color rgb <0,0,0.2> color rgb <1,0.85,0.85> scale
0.5}
      finish{specular 0.4}
      rotate <-110,45,0>
#macro TwoVarSurf(__Fuv__, Urange, Vrange, Iter_U, Iter_V, FileName)
   #ifdef(__Fuv) #undef __Fuv #end
   #declare __Fuv= function(u,v){__Fuv__(u,v)}
   TwoVarSurfCalc(Urange, Vrange, Iter_U, Iter_V, FileName)
#macro TwoVarSurfCalc(Urange, Vrange, Iter_U, Iter_V, FileName)
   #declare Build=CheckFileName(FileName);
   #if(Build=0)
      #debug concat("\n Parsing mesh2 from file: ", FileName, "\n")
      #include FileName
      object{Surface}
   #else
      #local Umin=Urange.u;
      #local Umax=Urange.v;
      #local Vmin=Vrange.u;
      #local Vmax=Vrange.v;
      #local dU=Umax-Umin;
      #local dV=Vmax-Vmin;
      #local iU=dU/Iter_U;
      #local iV=dV/Iter_V;
      #local NumVertices=(Iter_U+1)*(Iter_V+1);
      #declare NumFaces=Iter_U*Iter_V*2;
      #debug concat("\n Calculating ",str(NumVertices,0,0)," vertices for
", str(NumFaces,0,0)," triangles\n\n")
      #local VecArr=array[NumVertices]
      #local NormArr=array[NumVertices]
      #local UVArr=array[NumVertices]
      #local Count=0;
      #local I=0;
      #while (I<Iter_V+1)
         #local V=RangeMM(I,0,Iter_V,Vmin,Vmax);
         #local J=0;
         #while (J<Iter_U+1)
            #local U=RangeMM(J,0,Iter_U,Umin,Umax);
            #if(J=0)
               #local P0=<U,V,__Fuv(U,V)>;
               #local P2=<U-iU,V,__Fuv(U-iU,V)>;
            #else
               #local P0=P1;
               #local P2=P0;
            #local P1=<U+iU,V,__Fuv(U+iU,V)>;
            #local P3=<U,V+iV,__Fuv(U,V+iV)>;
            #local P4=<U,V-iV,__Fuv(U,V-iV)>;
            #local B1=P4-P0;
            #local B2=P2-P0;
            #local B3=P3-P0;
            #local B4=P1-P0;
            #local N1=vcross(B1,B2);
            #local N2=vcross(B2,B3);
            #local N3=vcross(B3,B4);
            #local N4=vcross(B4,B1);
            #local Norm=vnormalize((N1+N2+N3+N4));
            #local VecArr[Count]=P0;
            #local NormArr[Count]=Norm;
            #local UVArr[Count]=<(U-Umin)/dU,(V-Vmin)/dV>;
            #local Count=Count+1;
            #local J=J+1;
         #debug concat("\r Done ", str(Count,0,0)," vertices : ",str(100
*Count/NumVertices,0,2)," %")
         #local I=I+1;
      BuildWriteMesh2(VecArr, NormArr, UVArr, Iter_U, Iter_V, FileName)
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
