POV-Ray : Newsgroups : povray.binaries.images : workbench_train_02.png : Re: workbench_train_02.png Server Time
29 Mar 2026 22:43:57 EDT (-0400)
Date: 12 Dec 2023 11:59:02
Message: <65789156$1@news.povray.org>
On 12/11/23 07:59, Cousin Ricky wrote:
> I'm fine with yanking shorthand updates.  I never use the technique
> anyway, so I would not miss them; and since it uses a seemingly
> ambiguous syntax to merely duplicate functionality of less confusing
> code, I would discourage other people from using it.
> On the other hand, I would not require all finish{}, normal{} and
> pigment{} blocks to be enclosed in a texture{} block.  This is too
> useful and too often used in existing code to be discontinued.  I don't
> know if you had this in mind, but I'm just trying to keep my position clear.
Thanks both for the feedback. I'll need to think about all this some
more and play with more varieties of code.
-------- Thinking aloud
Our current documentation for pigment has this:
A pigment statement is part of a texture specification. However it can
be tedious to use a texture statement just to add a color to an object.
Therefore you may attach a pigment directly to an object without
explicitly specifying that it as part of a texture. For example instead
of this:
object { My_Object texture {pigment { color Red } } }
you may shorten it to:
object { My_Object pigment {color Red } }
Doing so creates an entire texture structure with default normal and
finish statements just as if you had explicitly typed the full texture
{...} around it.
Note: an explicit texture statement is required, if you want to layer
pigments.
It looks to me from the code that the documentation is lying some. That
second shorter form is doing a shorthand update (albeit by another path
through code for complicated reasons...).
In other words, when we write:
what happens is the default texture is copied as the starting texture
and then the pigment{} aspect is updated to "color Red".
When we write the 'supposedly compatible' shorter form:
We are updating the pigment aspect of the texture already attached to
My_Object. This might be the default texture - if no explicit texture
has been specified for My_Object - or it might be updating the pigment
aspect of whatever explicit texture was most recently attached to
My_Object(a)
(a) - I'm ignoring some complicating factors for the sake of a simpler
description.
We can update aspects of a texture ID for both texture{} and
interior_texture{} with the form:
     #declare Txtr00 = texture { pigment { color rgb <1,1,1> } }
     object { My_Object
         texture { Txtr00 pigment { color <1,0,0> } }
         interior_texture { Txtr00 pigment { color <1,1,0> } }
and this what I was toying with for consistency.
I'm understanding you to be saying you'd like to keep the shorter form.
I do see it in some of the code you've written. I use the short form
myself often enough too - and no doubt a great deal of exiting SDL makes
use of this shorter form...
I'll look again at making interior_texture{} behavior consistent with
texture{}. This wouldn't fix the consistency issue we are talking about
here with dual pigment{} updates, but it's probably the most compatible
way to go.
Bill P.
