Op 24/01/2022 om 11:51 schreef William F Pokorny:
> On 1/23/22 07:49, Thomas de Groot wrote:
>> Very nice one! More images should "fall out"...
> Thanks! :-)
> It's on my todo list to aim more often for more complex images! For
> whatever reason I always drift back into chasing things in the code.
> Attached is another test image. The one where I first turned up the
> POV-Ray issue with 'too large for our exr reader' channel values in the
> exr HRDI sky_sphere file.
> The three spheres are using different normal 'micro' pattern bump sizes.
> Further the scene uses povr's intensity_max control in both the
> reflection block and with the metallic in the overall finish block. The
> latter keeps all the reflected colors in a 0-1 channel range where the
> AA still works.
> Most puzzling to me is the upper left sphere where I made the micro
> bump_size large (1.5 I think). It happens once bump_size values get over
> the usual 0.5 limit where normals can start to invert in one or more of
> the x,y,z directions due the perturbation values being so large compared
> to the raw normal values(a). Where perturbed normal inversions occur,
> the result starts to look more like a milky glass. I don't completely
> understand why...
> Bill P.
> (a) Only a few of povr's normal patterns prevent such inversions - and
> micro doesn't.
That milky glass effect is quite nice imo, while the lower right sphere
seems strongly overdone. Food for thoughts... especially the milky glass.
