POV-Ray : Newsgroups : povray.binaries.images : Ambient and cast shadows on metallic textures : Re: Ambient and cast shadows on metallic textures Server Time
30 Jul 2026 06:33:42 EDT (-0400)
Date: 25 Nov 2021 13:28:04
Message: <619fd5b4$1@news.povray.org>
On 2021-11-25 3:33 AM (-4), Thomas de Groot wrote:
> Thanks for this.
You're welcome.
> There is a catch. The Clipka Grimoire tells us (1) to use high quality
> radiosity with metallic finishes, and (2) that ambient is/ disabled/
> when using radiosity, from version 3.7 onwards.
Naturally.  This post was intended primarily for non-radiosity scenes.
But an important co-issue of the ambient discussion is whether metallic
textures should have a diffuse component, and this is relevant whether
or not radiosity is used.
Of course, if you are using radiosity with 3.6.* or earlier, you should
explicitly set all ambients to zero.  If you have no glow-in-the-dark
objects, you can to this with global_settings { ambient_light 0 }.
Otherwise, you should use a #default statement, so that you can retain
the ability to set ambients on the glowing objects.
