POV-Ray : Newsgroups : povray.binaries.images : Questions about photons : Re: Questions about photons Server Time
10 Nov 2026 13:12:30 EST (-0500)
Date: 11 Sep 2021 03:00:12
Message: <613c53fc$1@news.povray.org>
On 06/09/2021 01:38, Alain Martel wrote:
> In that scene, only the first mirror should be set as target. If there
> is a second target object in a location where no photon can reach it,
> then, the photons destined for that extra target are lost.
> If you have two target, one behind the other, and even if the first
> target object is fully transparent, then, that first object will
> intercept and block all the photons shot at the second object.
Each  mirror as this settings :
photons { target refraction off reflection on collect off }
> Also, does the projector object restrict the beam ? That's another thing
> that may cut down the number of photons shot.
No, the light source for the beam is out of the "projector".
> Also, if you have a second light, each light will attempt to shot it's
> half of the requested photons. Any light_source that you don't want to
> shot photons absolutely need this photon block :
> photons{reflection off refraction off}
I have an other light source. Kind of "global illumination" for the
scene. for her  setting is :
photons { refraction off reflection off } media_interaction off
> ALL light_source except the shadowless ones have this default photons
> block :
> photons{reflection on refraction on}
Yes, there is only one light source for the laser with
    photons { refraction on reflection on }
> For the dimer part, it's probably related to the media used. Looks like
> you used type 5 with a negative eccentricity, probably between -0.25 and
> -0.5. Try using an isotropic scattering media.
> Try using type 1 (isotropic) or 4 (Rayleigh).
The global media is defined like this :
box {
  <32, 0, -1>, < -1, 6, 32> // 28>
  hollow
  texture { pigment { color rgbf 1 } }
  interior {
   media {
    scattering {
     1,
     color White
     extinction 0
    method 2 // uniform
    intervals 2
    samples 4
   photons { target }
Kurtz le pirate
Compagnie de la Banquise
