POV-Ray : Newsgroups : povray.binaries.images : Upgrading POV-Ray's include files - a few remarks : Re: Upgrading POV-Ray's include files - a few remarks Server Time
7 Jul 2025 16:14:31 EDT (-0400)
Date: 1 Mar 2021 03:06:12
Message: <603ca074@news.povray.org>
Op 28/02/2021 om 14:52 schreef Bald Eagle:
>> I am currently browsing through the include files to see if I can give a
>> meaningful contribution to their upgrading to 3.7+ standard. Over time,
>> some have been added to or partly upgraded, some are in am almost
>> pristine state going back to version 3.1.
> Thanks, Thomas.
> I still have a few include files from Friedrich Lohmueller that I was working
> through to tighten up the code and try to explain what was going on.
>> The fundamental question is: What do we want?
> Short answer: you really can't ever tell.
> You may want to somehow include all three.
> CloudySky1
> CloudySky2
> CloudySky3
> Or maybe put all 3 versions in a macro with a version argument, and use #switch
> to pick which one gets used.
Indeed. This was one of the options I was thinking about. However, as
you correctly mentioned below, these files are (probably) mostly used as
reference and learning items, and their value resides in the first place
to their use by new users. So, I would prefer to update/-grade the files
to 3.7.1 standards. In the process, some files will probably need more
serious tweaking than others or be completely rewritten. A #switch kind
of system may then be advisable indeed, as you write below (and above).
> Very long version:
And I appreciate your effort. I am not going to comment in detail just
now, but keep this in the background as reference.
> I try to keep in mind that these files are accessed for usage, reference, and
> learning.
> So, the way I (try to) approach my stuff, is a chaotic mix of the following:
> 1. The simplest bare-bones example whose text can be used in the copy-paste
> mechanism of the Insert Menu.
> Because Whether I'm tired or forgetful, or whatever - I approach this part from
> a New User perspective, and just want to plug in some working code from the GUI.
> The only "extra" here, is that for something like a macro, I like to write a
> working line of code or two to illustrate its actual usage in a scene.
> 2. Since these might be used as a reference to how certain features work, or as
> the basis for the development of new SDL, or just as a historical record of
> POV-Ray development, I like to get rid of "magic numbers", give things
> meaningful identifiers, and perhaps restructure the formulas and code a bit so
> that it's neat, clean, and easy to follow.
> Author, date, version number, revision comments, etc.
> This might comprise a completely separate "meta-version" of the code, which has
> #debug statements enabled by #if_def (Verbose), etc.
> One thing I've toyed with but haven't really fleshed out and used extensively,
> if to come up with a naming scheme for almost everything, so that 400 lines into
> some complicated scene code, I can get a clue about what's going on, and jump a
> few steps ahead in the debugging process.
> f_Identifier - function
> v_Identifier - vector quantity
> s_Identifier - scalar quantity
> C_Identifier - color
> P_Identifier - Pigment
> T_Identifier - Texture
> L_Identifier - a loop variable: #for (L_Identifier, 0, 10)
> If Verbose is defined (boolean), I may send some comments to the debug stream
> showing that a macro has indeed been invoked, and has exited.  That's just
> because a scene with a large number of nested things can get pretty crazy,
> trying to figure out where things went wrong.  Looking at the debug stream, I
> can count the number of opening and closing statements and see where things went
> off the rails.
> For complicated formulas, or ones that probably won't have obvious meaning, a
> few comments on what it does, how it's composed, what the assumed inputs and
> outputs are, and perhaps a reference to the origin of the formula can go a long
> way.
> // based on code / formula for [whatever] - POV-Ray, Graphics Gems, ShaderToy,
> website URL, math textbook, etc.
> // Takes 2 vectors and uses the point-slope formula for a line to....
> // divide both sides by x and cancel out [term] ....
> On rare occasion, just for kicks, I've sent the stepwise solution to the worked
> problem to the debug stream.
> Along those lines, you might not worry so much about which fish to give the
> end-user, and instead include a texture-generating macro that teaches someone
> how a nice sky texture gets generated from first principles.
> Links to the wiki for various features ought to help people quickly grasp what's
> going on and possibly avoid the rehashing of the usual "how do I...", and even
> if they do ask, anyone can just post a quick and simple "Just look at
> m_ExampleMacro () in skies.inc - it _shows_ you how to do _everything_ ...
> If you use "Step" as a macro argument, then you could progressively step through
> the code line-by-line by doing something like
> #if (Step > 0)
> #declare P_SkyBasis = pigment {bozo};
> #end
> #if (Step > 1)
> #declare P_StretchedSky = pigment {P_SkyBasis scale <10, 1, 50>}
> #end
> etc.
> Every increment to step executes ALL of the previous steps.
> Of course, you could use clock as well...
