POV-Ray : Newsgroups : povray.binaries.images : Backside illumination : Re: Backside illumination Server Time
27 Jul 2026 08:51:18 EDT (-0400)
Date: 22 Nov 2020 11:24:39
Message: <5fba90c7$1@news.povray.org>
Am 22.11.2020 um 16:22 schrieb Kenneth:
>> In Norbert Kern's Bluebell Wood discussion, there was mention of the use
>> of basckside illumination by Alain and myself. Here is an example of its
>> use, a 2019 update of a 2012 scene from the Iskander/Gancaloon universe.
>> Backside illumination was applied to the curtains.
>> Thomas
> I have not yet used backside illumination, so I'm curious as to what I should
> see in your scene. I assume that the curtain objects themselves are
> semi-transparent(?), and that the effect is seen as the small triangular light
> patches on the left-side curtain?
> So many tricks to learn, so little time ;-)
As all I know, backside illumination and semi transparency is not the
same. Semi transparency can be achieved by using an alpha-channel within
a png-based texture. Backside illumination is a special calculation of
diffuse reflections.
I used
      finish { diffuse albedo 0.55,0.4 }
in this image:
      http://news.povray.org/5f2ae26d%40news.povray.org
at all of the balloons.
As I understand it, it means that 55 % of the light from front
lightsources is diffuse reflected and that 40 % of light from sources at
the backside of an object can pass through.
Best regards
Michael
