POV-Ray : Newsgroups : povray.binaries.images : Having a try at light distributions : Re: Having a try at light distributions Server Time
15 Mar 2026 05:47:22 EDT (-0400)
Date: 13 May 2019 16:32:46
Message: <5cd9d46e$1@news.povray.org>
Le 19-05-13 à 07:29, Jasper a écrit :
> Hello everyone!
> I am trying to introduce photometric data files of luminaires (i.e. IESNA .ies
> or EULUMDAT .ldt) in Povray to get "correct" lighting distributions. This
> currently works by combining
> (1) a point light source
> (2) a sphere with radius 0.01 and spherical mapping of an image map (.png with
> the alpha channel used for transparency) which represents the lighting
> distribution for different angles.
> However, for large coordinates (e.g. 1e+6), I get unwanted black spots in a
> regular pattern (see attached image on the left).
> Jasper
You may try using a larger sphere when the scale of the scene get larger
than about 1e+4. It may reduce the rounding errors to some extent.
The best thing to do is to limit the size of the scene to be less than
1e+5 if at all possible.
Build your scene around the origin. Don't be afraid of negative numbers.
