POV-Ray : Newsgroups : povray.binaries.images : You know, I like to take things to extremes... : Re: You know, I like to take things to extremes... Server Time: 19 Jun 2019 06:53:22 GMT
Date: 13 May 2019 08:01:56
Jörg "Yadgar" Bleimann wrote on 10/05/2019 07:32:
> Hi(gh)!
> ...so I created a large (101 by 101) and a gigantic (1001 by 1001) maze
> with GIMP (both attached here), color-coded the exit points in red and
> then programmed a small POV script to generate arrays from these PNG
> image files (also attached here)... which in turn are read and processed
> by my improved maze finder, originally from David Gemelli.
> Next will be the walk-through animation (o.k, not for that 1001 by 1001
> behemoth!), and to prepare this, I have to enable real entry points from
> outside, i. e. paths starting at gaps in the outer wall!
> See you in Khyberspace!
> Yadgar
Nice. Now you can populate the maze with people...
Paolo
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
