POV-Ray : Newsgroups : povray.binaries.images : You know, I like to take things to extremes... : Re: You know, I like to take things to extremes... Server Time
13 Mar 2026 22:49:18 EDT (-0400)
Date: 10 May 2019 08:53:28
Message: <5cd57448$1@news.povray.org>
On 5/10/19 1:32 AM, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
> ...so I created a large (101 by 101) and a gigantic (1001 by 1001) maze
> with GIMP (both attached here), color-coded the exit points in red and
> then programmed a small POV script to generate arrays from these PNG
> image files (also attached here)... which in turn are read and processed
> by my improved maze finder, originally from David Gemelli.
> Next will be the walk-through animation (o.k, not for that 1001 by 1001
> behemoth!), and to prepare this, I have to enable real entry points from
> outside, i. e. paths starting at gaps in the outer wall!
> See you in Khyberspace!
> Yadgar
Cool. Been following your maze-with-solution posts as a project I hope
to get to near-ish term is a rock wall maze on rolling terrain as a
single isosurface...
Bill P.
