POV-Ray : Newsgroups : povray.binaries.images : Blurred reflection comparison : Re: Blurred reflection comparison Server Time
23 Mar 2026 21:45:09 EDT (-0400)
Date: 12 Feb 2018 17:05:51
Message: <5a820fbf$1@news.povray.org>
Am 12.02.2018 um 22:27 schrieb Mike Horvath:
>> You need:
>> (1) A way to randomize the reflection. A `normal` statement with a very
>> small scale does nicely.
>> (2) A way to force POV-Ray to shoot a high number of rays per pixel
>> where the randomized reflection is. A small bit of focal blur (with high
>> quality settings) does nicely.
>> Together this gives you nice blurred reflections at a (hopefully)
>> reasonable speed.
> Is this random normal good?
It should do the job. Note that since you're only using one copy of the
bumps normal, there's no need to translate the texture by a random amount.
Also, I'm not sure whether the average normal_map construct will give
you the desired result, or whether you should instead use a sequence of
`normal` statements. See tutorial section 2.3.5.2.2, "Blending Normals".
