POV-Ray : Newsgroups : povray.binaries.images : Comet "Rubber Duck" 67P/Churyumov-Gerasimenko : Comet "Rubber Duck" 67P/Churyumov-Gerasimenko Server Time
24 Mar 2026 15:05:13 EDT (-0400)
Date: 6 Oct 2014 18:17:15
Message: <543314eb@news.povray.org>
Well, everyone kept calling it a rubber duck since Rosetta
sent the first images of the comet shape, so I decided to go
with that theme. BTW, the density of the comet is only about half
that of water so may it could float - if you could wrap it into
a 6 km long yellow insulation bag and prevent it from further
compacting under gravity :)
I downloaded the model from ESA yesterday and spent today playing
with it. Well actually I mostly spent time looking at rubber duck
images and trying to figure out SSLT (this was the first time I
attempted to recreate a specific material).
The duck bill was "borrowed" (or surgically removed) from Gilles
Tran's rubber ducky at
   http://www.oyonale.com/modeles.php?lang=en&page=53
I wasn't really certain whether to go with eyes and bill since
it all seemed to be sliding down uncanny valley, but I found it
more or less tolerable with a subdued color for the bill.
I'm not really happy with the look of the material, it does not
seem very rubber-like to me. Although it did look better on a test
model of an actual rubber duck, so maybe part of it is that the
roughness and edges of the surface defy the expectation.
However, I think mostly my settings are simply incompetent.
I had a hard time getting rid of greenish tints in the darker
areas despite having no dominant green in the scene:
texture
   pigment {color rgb <1,0.7,0.01>}
   normal  {granite 0.05 scale 0.1}
   finish
     specular 0.2 roughness 0.08 metallic 0.5
     subsurface
       translucency rgb 20*<2,0.2,0.02>
interior
   ior 1.52
Looking at samples of rubber duck images it seemed they were
distinctly more reddish in their dark areas, so I tried to use
a yellowish pigment with a strong red translucency effect.
I added partial metallic highlights since they tended to
look more yellowish than whitish in sample images. The normals
were added as faint background structure because the model was
a bit plain in some areas, but they got mostly lost when
rendering with better aa and focal blur.
I found ior 1.52 listed as ior for natural rubber, although I
belatedly realized that most "rubber" ducks are probably no longer
made from rubber. However, Polyvinylchloride that seems to be used
a lot has ior of 1.54 so not much harm done.
Apart from SSLT this uses 2 bounce radiosity. It rendered
at 640x480 with +a0.1 in 2h 9m on an i7-970 with 12 threads).
While not a great render technically I still found it fun
and I hope you have a laugh too :)
Download '67p.png' (219 KB)
Preview of image '67p.png'
