POV-Ray : Newsgroups : povray.binaries.images : colored leaves : Re: colored leaves Server Time
18 Mar 2026 07:38:50 EDT (-0400)
  Re: colored leaves
Date: 16 Mar 2012 03:59:03
Message: <4f62f2c7$1@news.povray.org>
Excellent technique and very beautiful image indeed!
On 15-3-2012 20:29, Norbert Kern wrote:
> Hi,
> i want to share a nice trick.
> [snip]
> So I used an old Poseray version, which opens mesh2 files and is able to save in
> the old mesh formate (Poseray 3.8.7).
Ah this is nice! Might be a good reason to ask FlyerX to add a
mesh/mesh2 save option, with mesh2 as default.
> Then I read the first triangle coordinate and saved the color value derived by
> the projection pattern in a different file. After some copy and paste I had a
> mesh with three different imagemap based leaf textures (red, yellow and green).
I am not entirely sure how you did this but the result is spectacular
and convincing.
> As a demonstration file I used a nice backlit scene inspired by a romantic
> painting I found on the web long time ago.
> Only the two big trees use the projection pattern trick.
